Question about NetGear WGR614 Wireless Router
How do i find my IP address for my router? - NetGear WGR614 Wireless Router
    Problem Solver:
  • 11 Answers
Router should have ip address same as the ip address provided by your isp provider which you can find it at Tejji's ip address
Posted on Apr 30, 2010
    President:
  • 1,851 Answers
192.168.1.1
Posted on Apr 28, 2010
    Sniper:
  • 135 Answers
Hi,You can exactly get any of the IP details with this http://www.whoisxy.com/ site ,here you may visit and get it.It is totally free site.I am using this site only for my IP related help.
Posted on May 04, 2010
How can I change my routers IP address?
You can assign Different Ip-address manually,Or use the Proxy to change the ip-address,by hiding the Original Ip-address or contact the ISP get the Dynamic Ip-address and Change the Ip-address,You can check the Ip-address at here
http://www.ip-details.com/
Jan 23, 2011 | D-Link AirPlus DI-524 Wireless Router
Tip
How to configure a Router?
How to determine the WAN configuration or Interntet configuration of a SOHO Router?
1. Connect the computer to the Modem via Ethernet cable. Make sure you are able to going online 2. After confirming you are online. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway
There are 4 possibilities of IP address you can get
i)Public IP address under PPP adapter. -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP ii) Public IP address under PPP adapter and Private IP address under Ethernet adapter -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP iii)Public IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Click Mac clone on the router's WAN configuration * Power-cycle modem and Router. iv)Just a Private IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Power-cycle Modem and router.
After determining the WAN mode, it is time to configure the Router
1. Connect the Modem to the WAN port of the router. Connect the computer to the LAN port 2. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway. The Default Gateway will the IP address of your router 5. Open a Web browser and type http://192.168.1.1(where this is the default IP of the router. This will be different from each manufacturer) on the address bar. 6. Go to WAN settings or Internet settings and select the options based on the above mentioned possibilities
on Aug 26, 2010 | Computers & Internet
Hi there,\r\nWe have a Linksys WPS54G print server and I'm trying to re-connect it to the new Veridon Fios router. The print server has a default ip address of IP Address:169.254.53.156 but the new router...
The problem is that your printer can't obtain an IP address from your router so it is kicking back the IP address 169.x.x.x which indicates it can't reach the router. You need to go into the IP address configuration on your printer and set a static IP address on the same subnet as the router. For example your router's IP is 192.168.1.1 so set your printer's IP address to 192.168.1.5 and set the default gateway on the printer to the router's IP address (192.168.1.1) next you need to enter in the DNS Server address which is also the router's IP address (192.168.1.1). Once you do that you will be on the same network as your router. From there you can add the printer on your computer through devices and printers if its a Windows pc. Cheers! J the Guru
Oct 16, 2017 | Linksys Computers & Internet
When i try to install my Linksys wireless G, it ask for a password. I don't know it and it won't let me proceed!
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Nov 04, 2010 | Linksys Wireless-G Broadband Router
How to obtain my password and add another laptop to wrt54G
To access the router's web-based setup page using Mac, click here. Step 1:
Step 2:
Step 3:
If you forgot the router's IP address you can:
Aug 23, 2010 | Linksys Wireless-G WRT54G Router
I am trying to set up a new printer to a Linksys router model no WRT300 Ver 2.0. I have lost my IP no and also my Network Security Key, Is there any way to retreive these nos Gordon Stephens
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Step 2:
NOTE
Step 3:
Aug 21, 2010 | Linksys Wireless-G WRT54G Router
Someone has changed my IP address hacked into in my router
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jul 06, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to find router fully ip address?
if your PC still working and connecting to the internet thru this router, then open command prmpt, enter "ipconfig" and read the ip address of the default gateway. at most simple home networks, that is your router.
Jun 06, 2009 | EnGenius EOC-3220+ (EOC3220PLUS)
I can not connect to the local area connection.
1. check your network adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 justcheck the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
hope this will help you
Nov 26, 2008 | NetGear WGR614 Wireless Router
LINKSYS ROUTER
You need to know the ip address of your dvr. It might have a factory set ip address or a dynamic ip address from the router. You can then use this ip address to access your dvr.
If your dvr has a static ip, that static ip should be in the same range as the router's ip address so that the router can communicate with the dvr.
Mar 12, 2008 | Linksys Wireless-G WRT54G Router
NetGear WGR614 Wireless Router Logo
204 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
