Question about RCA CDRW120 2-Disc CD Recorder
Record in real time, drop markers then burn to cd.
Actually, I am looking for something simple where I can record a live D.J. recording set for approx. 80 minutes, drop markers on them and burn the recording to CD. Is there an inexpensive component that can do this because software gives me glitches?
    Brigadier General:
  • 8,546 Answers
I copy cassettes on my CD-R sometimes and I never know exactly where the cue points will be so I just make the digital source onm a CD-RW with rough manual tracks marks on the first pass with no stops.
Then I digitally copy that CD to another after I find out where the cues should best be placed, marking them manually as they come up. Then I recycle the source CD-RW.
Posted on Apr 28, 2010
What are the steps to record cd to cd
rip your cd on a laptop/pc and put in a blank cd and burn it to that simple option!
Aug 07, 2012 | Teac RW-D250 2-Disc CD Recorder
Does anyone know if it is possible to record from a DJ mixer onto the Yamaha CDR-HD1300 CD Player / Hard-Disk Recorder? -- i.e Can I record a live DJ set straight onto CD? And/or can I record a live set...
The recorder could not care less what the upstream audio device IS or if it's live vs prerecorded as long as the connection works and there is a signal.
Jul 21, 2011 | Yamaha CDR-HD1300 CD Recorder
I expected that the RCA leads from my turntable would just plug into the back of the RCD-W500C, but the manual indicates a somewhat complex cabling arrangement through the amplifier. I have not been able...
Your new cd player/recorder is a "component piece" as is your turntable,cassette player, reel to reel or CD player. Connect it as you would any other component piece of stereo equipment. Set up your recorder to "record" in real time(not high speed or synch record). Your tape recorder records anything that is playing through your reciever to your speakers. So, treat your "CD" recorder as you would a "CASSETTE TAPE" recorder. Play your vinyl record on your turntable and record to CD on your CD recorder ! Pay special attention to the dubbing speed, you will not use "synch or high speed !! Good Luck
Feb 26, 2011 | Audio Players & Recorders
HHB burn it...I record on coaxial from Tascam DAT. 1st five tracks are great but the 6th track sounds horrible like there is a scratchy sounding distorted delay. It does this every once in the while . What...
I had this happen a lot on my Pioneer PDR-509, which is pretty much the same machine, when using marginal mongrel-brand CDR's. It's annoying but I have seen nothing to explain or detect it in real time so something can be re-recorded.
Nov 17, 2009 | HHB BurnIt CDR830 CD Recorder
Set the timer to record
Do you have the remote which came with it? Most VCRs of the last 10 years require the remote to setup a timed record, or for that matter, most of the advanced functions- beyond play/rewind/ffwd, etc.
Assuming you do have the remote, and the correct time is set, and the timed record properly setup, some VCRs require a the On-Timed-Record button to be pushed. This sets the VCR in a wait mode, until the time set for the recording to begin.
Consult your owners manual- an online manual may be available if the printed one is missing.
Mar 04, 2009 | Sharp VC-H812U VCR
Leaves blank TV screen when Return button operated
It sounds as though the unit is actually recording a DVD, but is getting no incoming signal to record. What is your recording source? Satellite and receiver? Antenna? Cable box? In the set-up menu, be sure you have chosen the proper input source; i.e., recording from where? You may be able to access that menu through the Function button on the remote, AFter setting that menu, be sure to press Return to restore the recorder to the ready mode. If you are using the RF input for recording, be sure that is selected as well, as opposed to L1 or L2. The input channel must match the output channel on your receiver, usually channel 3 or four. What is the model number?
Dec 02, 2008 | Sony RDR-GX300 DVD Recorder
No sound coming through when recording from hi fi tape to computer
This is actually simple to do. Connect the line out on your tape player to the line in on your computer. Then download a free program, from the net called Audacity at http://audacity.sourceforge.net/. The program is totally free and works great. Some recording studios use this program. In the middle of the main Window on Audacity set it to record from Line in. This is from the small drop down menu next to the little microphone icon. Then hit the record button on Audacity and play your tape. You can record each song individually or you can record the whole side of the tape at once and separate the tracks when you save them. You can even use this program to clean up the sound on your recordings. I have transferred many of my tapes and records to CD using this process. I hope I have been helpful and good luck
Jul 01, 2008 | Genius Soundmaker Value 5.1
Recording problem
Does it stop at the same time elapsed on the CDr every time? Can you resume recording on the same disc afterwards? What about if you dubb high speed from the internal player?
Jan 12, 2008 | Philips CDR785 3-Disc CD Recorder
Recording
Yes it will record from the tape outputs of an amp. It finalizes at double speed which in this units case is approx. 2 minutes.
Dec 24, 2007 | TDK DA-3826 2-Disc CD Recorder
RCA CDRW120 2-Disc CD Recorder Logo
52 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
