Question about Frigidaire Electric Dryer
Electric dryer just hums. Doesn't turn on. - Frigidaire Electric Dryer
  • Frigidaire Master
  • 43,501 Answers
The humming is often the motor trying to go and for some reason cannot... often a sign of a bad motor
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 28, 2010
4 Suggested Answers
  • 221 Answers
SOURCE: when you press the start button the dryer hums and doesnt turn
check the fuse's and or breaker's to make sure on of them is not blown or tripped, check the belt to make sure it's not broken and check the tensioner, check to see if the drum spin's with little or no friction, if there are no blown or tripped fuse's and belt and tensionet are good the motor may be burned out.
Posted on Apr 18, 2009
  • 277 Answers
SOURCE: ge electric dryer. suddenly stopped working. Will
Hi Stv,
There isn't really major problem, but a problem.
You will need to unplugged your unit and take it apart. Are you handy?
If and when the unit is apart look at the motor and the fan exhaust and see if there is a coin or screw is jamming the motor or the fan
while you are in there you may want to clean it up,
That should be the problrm
Posted on Jul 25, 2010
heatman101
  • 43501 Answers
SOURCE: Whirlpool duet electric dryer turns on but doesn't
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Sep 03, 2011
Frigidare dryer aeq6000es2 doesn't spin, humming noise, burning smell
Hello tancrbtt - It sounds like your unit may have one or more problems. Either the belt slipped off the idle pulley and/or dryer belt and needs replacing, a faulty motor or a common failure between control and motor. Consult a professional to accurately diagnosis the dryer and to assist with the repairs.
Feb 12, 2013 | Frigidaire Electric Dryer
KEYS750LQ0 dryer doesn't start it just hums when I push start
Check the belt. You may have to open the machine up to look. if the belt is ok turn the drum by hand and see if the motor pulley is also turning. While you are in there look for foreign objects that have wedged against the drum preventing it from turning.
Oct 09, 2012 | KitchenAid KEYS850LQ Electric Dryer
I have a Neptune dryer. On big loads, such as towels it doesn't tumble it just hums, although it does heat. What could this be?
they are turned by a large belt that encompasses the entire drum... it could be getting loose, the entire machine has to come apart to find and fix the problem... there is also a spring connected to the motor for tension on the belt this could be the problem as well.
Jul 04, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
My dryer squeaked for awhile no it hums but the drum doesn't turn
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2011 | Roper REX4634KQ Electric Dryer
My drum doesn't turn anymore after I have used the basket. It now does a loud humming sound.
heatman101
Sep 05, 2011 | Miele T9800 Electric Dryer
No the dryer won't start it make a hum sound but the barrel doesn't turn(I check ed the belt it is fine) maybe the starter switch you think. Chris
heatman101
Aug 10, 2011 | Kenmore 62602 Electric Dryer
When i tried to turn on the dryer, i get a humming / buzzing sound and the drum / motor doesn't spin anymore
heatman101
Aug 07, 2011 | GE DWSR463EG Electric Dryer
Clothes dryer don't run
sounds like a bad cycle timer switch
Apr 22, 2009 | General Electric Clothes Dryer Knob -...
Frigidaire  Electric Dryer Logo
71 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
