Question about Olympus Camedia C-4000 Zoom Digital Camera
Lock in choices
When I choose HQ, SHQ, Tiff etc. and I turn my camera off, it switches back to the previous choice. How do I lock the new choice in?
Thank you,
Gordon.
Found a more comprehensive manual then the one sent with the camera which dosn't answer this question
It is a PDF format. In browser type olympus C4000 reference manual, when list comes up look for C4000 PDF click this link, brings up the manual. my answer was on pg. 143. The key to finding this manual was the word reference.
Posted on Mar 25, 2008
Will not scan as pdf file--choices are jpeg, tiff, etc. no c
You have to use the conversion program in your computer first to convert to PDF
Jul 27, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Selected resolution will not save
You need to change the setting in the Menu of ALL RESET from ON to OFF so that it will retain any setting changes that you make. To do this Press Ok button - right arrow to Mode Menu - down arrow to Setup tab - right arrow to All Reset - right arrow and choose Off and then press Ok. This will retain the mode setting until you manually change it again or change all reset back to On.
Aug 21, 2008 | Olympus Camedia C-350 Digital Camera
Image quality in low resolution
SHQ1 and HQ are two different levels of compression to make the file smaller. This will have a great impact on the image quality. Generally on Olympus cameras, this is what those letters mean: TIFF (highest (best) quality) generally not used. Files are HUGE and takes a long time for the camera to save the image to the card. SHQ (super high quality) you probably wouldn't be able to tell the difference between this and the TIFF HQ (high quality) which is lower quality than SHQ SQ (standard quality) which is lower quality than HQ SQ1 (standard quality 1) which is lower quality that SQ SQ2 (standard quality 2) which is lower quality that SQ1 A 2048x1536 only seems large because most people have their monitors set to 800x600 or maybe 1024x768 (that's what I have mine set at). This will seem to make the image REALLY LARGE! It only seems that way because you have to scroll around to see the image. If you want to print images, you'll want all the resolution you can get. If you want to display them on your screen (slide show,WEB page) then you don't need large images. You would just need to resize them down. However, since you may want to both, getting a camera with a higher resolution gives you the choice to do either. Usually, the higher resolution cameras have better lenses and generally take better pictures. On my camera (the Oly 2100), I always shoot at the highest resolution and the least amount of compression (SHQ on my camera). This allows me to do almost anything with the image. Nowadays, camera media (smart cards) are fairly cheap, HD's are DIRT cheap and CD-Rs are very cheap. If the images are "keepers", then I personally would want to start with the best image possible and store the images on CD.
Sep 07, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
Unhappy with the quality of the pictures
Is the white dot in the viewfinder? I could see that getting very annoying so I'd probably send it back. The shots I've taken indoors with the flash on the c2100 have not had any problems with over exposure. There are both exposure and flash compensation settings in the camera, make sure you haven't changed them by accident. If this is your first digital you have to get used to the way the images look, it's not the same as film. At first digial images look "soft" and more grainy, more so if you look at them at 1:1. I usually view them so they are about 8" wide on the screen, or about 1:2. As the number of pixels goes up the difference between different compression levels becomes less noticable. If you shoot in 640x480 mode you'll see a difference between high and normal. At full resolution on some shots you'll get better color on SHQ over HQ. And TIFF is rarely any better than SHQ.
Sep 07, 2005 | Olympus Camedia C-2100 Ultra Zoom Digital...
How can I change the Resolution?
Olympus has its own way of showing the resolution settings. It is OK once you get used to it. Turn the Camera On. (On the back you will see an OK button surrounded by 4 arrows.) Press the OK button to bring up the menu. Press the left arrow button That should bring up a choice of: TIFF, SHQ, HQ, SQ1, SQ2 Use the up/down arrow buttons to move the cursor to SQ1 Then press the right arrow button That should bring up a choice of settings. Use the up/down buttons to select a setting. I suggest you select 2048x1536 (which is 3 megapixels) Then press the OK button. ................ You should think about getting a memory card with a greater capacity.
Sep 06, 2005 | Olympus Camedia C-60 Zoom Digital Camera
Features of each record mode
The details for each record mode are as follows: RAW: RAW data is unprocessed image data in its original state to which white balance, sharpness, contrast, color conversion and other processes have not been applied. CAMEDIA Master can be used to display RAW data and save it in other image formats. A RAW plug-in is also available for Adobe Photoshop which also provides the ability to process images in 32-bit color depth. TIFF: This is the highest-quality mode. images are saved as uncompressed data, which is the best for printing or image processing on a computer. SHQ: This is a high quality mode using the JPEG format. Because the compression rate is very low, high quality images can be stored. HQ: This is a high quality mode using JPEG format, with medium compression. Because the compression rate is higher than SHQ, file sizes are smaller. More images can be saved to a card. The file size can be changed in the 3:2 or Enlarge size mode as well as SHQ. 3:2 Mode: Ordinarily the image aspect ratio is set to 4:3. Due to change the ratio to 3:2, the picture size becomes 2592 x 1728 so that the image can be printed without losing the image borders at a photo lab. 3:2 can be set in the TIFF, SHQ, or HQ mode. SQ1/SQ2: SQ1 is used for resolutions above 1600 x1200 and SQ2 is used for resolutions below 1600 x1200. For both, you can choose high compression to reduce noise or normal compression to save more images.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Features of each record mode...
The details for each record mode are as follows: RAW: RAW data is unprocessed image data in its original state to which white balance, sharpness, contrast, color conversion and other processes have not been applied. CAMEDIA Master can be used to display RAW data and save it in other image formats. A RAW plug-in is also available for Adobe Photoshop which also provides the ability to process images in 32-bit color depth. TIFF: This is the highest-quality mode. images are saved as uncompressed data, which is the best for printing or image processing on a computer. SHQ: This is a high quality mode using the JPEG format. Because the compression rate is very low, high quality images can be stored. HQ: This is a high quality mode using JPEG format, with medium compression. Because the compression rate is higher than SHQ, file sizes are smaller. More images can be saved to a card. The file size can be changed in the 3:2 or Enlarge size mode as well as SHQ. 3:2 Mode: Ordinarily the image aspect ratio is set to 4:3. Due to change the ratio to 3:2, the picture size becomes 2592 x 1728 so that the image can be printed without losing the image borders at a photo lab. 3:2 can be set in the TIFF, SHQ, or HQ mode. SQ1: SQ1 uses the highest compression for resolutions greater than 1600 x 1200. You can choose high compression to reduce noise or normal compression to save more images. SQ2: SQ2 uses the highest compression for resolutions less than 1600 x 1200. You can choose high compression to reduce noise or normal compression to save more images.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
8MB SmartMedia Card
Quality Pixel Resolution Storable images TIFF 1600 X 1200 1 shot 1280 X 960 2 shots 1024 X 768 3 shots 640 X 480 8 shots SHQ 1600 X 1200 5 or more shots HQ 1600 X 1200 16 or more shots SQ 1280 X 960 (HIGH) 8 1280 X 960 (NORMAL) 24 1024 X 768 (HIGH) 13 1024 X 768 (NORMAL) 38 640 X 480 (HIGH) 32 640 X 480 (NORMAL) 82
Aug 31, 2005 | Olympus Camedia D-510 Zoom Digital Camera
SmartMedia Card
D-40 Zoom Memory Card Storage Capacity Quality Resolution # of Storable images TIFF 2272 X 1704 1 or more SHQ 2288 X 1712 5 or more HQ 2272 X 1704 16 or more SQ 2 1280 X 960 49 or more SQ 1 640 X 480 165 or more
Aug 31, 2005 | Olympus Camedia D-40 Zoom Digital Camera
Display show TIFF
TIFF will always show up on the monitor when you scroll to it. If you adjust the Image Quality on the monitor, it will remember your setting even if it shows TIFF when you scroll back to it at another time.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Olympus Camedia C-4000 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
