Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Shooting out hot steamy water at intervals.
The water heater made a steamy noise when no water was being used. Later when you turn on the hot water is spits out hot steamy water.
  • Rheem Master
  • 43,501 Answers
You have a bad thermostat...most likely the top one, but it could be the bottom one... if it is the bottom one replace the top one also as it should be kicking the reset button and is not...
The way to tell which one it is, will be to test the elements to see which one is stuck on... it will be the one with the power still going to it... it is not shuttind down on temperature like it should...
heatman101
Posted on Apr 28, 2010
Dryer gets really hot but clothes are still wet
Sounds like the vent is plugged up, that's a fire hazard take it apart and clean it out..
Apr 05, 2014 | Whirlpool Whirpool 3.5cu ft Top Load...
"Infinity 20" probably 8yrs old now. Recently started making a humming noise whilst in use. The noise continues 15secs or so after hot water tap has been turned off.
Sounds like the diaphram in the gas control valve which is not replacable. You would have to replace the gas control valve and I would also suggest replacing the thermocouple. However since the heater is 8 years old you may think about replacing the entire hot water heater. Depending on how much water has gone through it in these past 8 years it will probably rust out soon and then you will be dealing with a flood.
Good luck,
Marty
Nov 08, 2013 | Rinnai Water Heaters
I just had a noritz tankless hot water heater converted from LP gas to natural gas, and had the hot water heater moved outside my garage. Before the gas change over and the move, I could turn on my garage...
One thing that comes to mind right off is did they use proper size orifices when they converted? L.P. uses a much smaller size then natural gas because it runs at a much higher pressure. Just a thought but I had a water heater from the factory for a mobile home that had the nat. gas sticker on gas valve and I hooked it up in town to nat. gas supply. Unfortunately it had L.P. orifices and I was in a hurry to get to another job ,lit it turned burner on and left. Two hours later my customer called to say they didn't have enough hot water. Didn't take long to discover what the problem was and correct it. Thank god for good customers. Hope this helps you. Thanks
Nov 24, 2010 | Bosch Indoor Gas Tankless Water Heater...
Sounds like a squirrel inside water heater
The noise is inherent in electric hot water heaters. It is the noise that the water makes when it is being heated by electric heating elements. Mineral buildup on the elements can make it worse, so changing the elements can help...but will not totally elimenate the noise. When I install a new tank and turn it on all I have to do is listen to it to see if it is working or not...even brand new will make a sound...it is the sound of hot water... :-)
heatman101
Mar 25, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
High pitch noise when water is turned on.
that's a faucet problem, nothing to do with the tank
either replace the faucet washer (The one that's noisy)
or get a diffeent style faucet
Aug 31, 2009 | Water Heaters
Noisy water heater blower
It may just need a new pump coupling. Fairly inexpensive. I don't think you need to replace the whole burner.
Feb 14, 2009 | Fasco Bradford White Hot Water Heater...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
79 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
