Question about AO Smith Pool Pump Motor 1HP Square Flange Swimming Pool Pump Energy Efficient motor
We have an 1hp jet pump pulling water from a 3000gal holding tank below the pump and pressure tank. when we prime the system and bleed out the air the irrigation works properly, the pump starts and stops fine, the pressure tank fills with water and the pressure switch properly shuts down the pump. Although when we leave the system for over 12 hrs or till the next cycle the pump blows the cirrcuit breaker on the panel upon start up. We have a foot valve and check valve in the holding tank on the suction line and removed the check valve between the pressure tank and pump so the whole system should stay primmed even if there is a small leak possibly. Why would everything run fine for one cycle and then blow the breaker after it has been sitting. It is wired so the pump and the pressure tank are on seperate cirrcuits from the irrigation controller, therefor any leaks that may persist will drain the pressure tank to its lowest setting and the pump kicks in and fills it back up, but this is not the case.
  • 438 Answers
Depending on the motors style of start-up, if you have a centrifugal type of start winding switch, your motor may be trying to start on the run winding due to a defective contact on the centrifugal switch, if it is a capacitor type starer, you might have a defective capacitor once again the motor is trying to start on the run winding, a way to find out is to be there and listen to the motor when it tries to start and trips the barker, if the motor emits a loud humming noise you have a fault with the start-up winding control device, if the picture supplied with your post is correct the capacitor is the long cylindrical thing at the top of the motor, you can remove this and bring it to a motor shop, they can test this for you
Posted on Apr 28, 2010
My 8 Yr old 1hp jet pump model JRD10 cycles on and off when i try to use hose at facuet?
I think the pressure switch is cycling your pump when there is a low demand. If your system has a pressure tank, it is waterlogged (has no air in it). If you shut down you system, drain the tank, and the restart you system, it should work. Most tanks are made to be pressurized to a certain pressure before starting up your system. Some tanks have a 'tire valve' on them for pressurizing with air.
Oct 29, 2014 | Goulds Pumps Goulds gt10 1 1 Phase...
Problem with pump?
The pump pressure switch should be checked to see what the ON-OFF pressure is set at. Typically the pressure switch is set for 20-40 psi, or 30-50 psi. The pressure tank should be purged as well. With the pump OFF, and the tank drained of water, the air valve on the tank should read approximately 2 psi below the "on pressure". So if the system operates at 20-40, the tank should be pre-charged to 18 psi. If water escapes from the air valve, the internal bladder in the tank is ruptured, and the tank needs to be replaced. A tire air gauge is used to measure the pressure in the tank after the water is emptied from the tank.. A tire air pump or a compressor is used to charge the tank. if a compressor is used, be careful not to over-inflate the tank, as this may cuase the bladder to rupture.
Apr 14, 2014 | Utilitech Plumbing
How do i reprime ?
Close the supply valve to the tank. Open the priming port of the pump, (plug on the upper most part of the casing) pour in water until the pump is filled -up. Close the plug just finger tight. Run the pump. slightly open the plug just to bleed the air with little water. If all water is coming out, the pump motor should cut-off indicating the pump is already primed. Gradually open the supply valve. Pump motor will restart again.
Nov 12, 2012 | Fresh Water Systems WellMate Tank Fittings...
The pump lose prime when we vacuum
The reason the pump will lose prime anytime is because insted of the pump pulling in water, it is now pulling in air from some source. When you set up the pool to be vacuumed, you must be sure to prime the vacuum hose with water before inserting the vacuum hose into your suction. The easiest way to do this is to:
1. attach vac.head unto the vac.pole and 1 end of the vac hose.
2. holding on the the other end of the vac. hose so it doesn't get away from you. slowly lower the the set up into the pool and make sure the pole doesn't get away from you either.
3. now you will notice part of the hose is filled water and part of it is floating ontop of the water with air still in it. Now while sitting on the edge of the pool, pull the hose toward you to where you think the part of it is now full of water. than slowly feed the rest of the hose, hand over hand until the end of the hose and you will see water come out the end, the hose is now totally full of water.
4. This is the tricky part, cuff your hand over the end of the filled hose and with the pump running plug the end into the suction, re: skimmer or suction port.
At this point you might have induced some air into the system and the pump may lose prime or start to lose prime. Go over to the pool equipment and if present, bleed the air out of the filter.
Hope this solves your problem.
Jun 18, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
Had to replace shallow well pump. Bought jet pump (used to have centrifugal pump), and installed it. Had to replace inline check valve, losing well prime. Priming pump does not accomplish the job. ...
Aj, do you have a foot valve on the bottom of the pipe in the well?? The jet pump needs to have a foot valve to hold the water in while priming it... you also have to carefully design the system and prime it in such a way as to eliminate all of the air in the piping. A jet pump will not pull the water and expel the air like a centrifugal pump will...
I think the part you are missing is the foot valve...
heatman101
Jun 09, 2011 | Garden
The pressure tank psi may be too high. To set it you get the system to pressure up and stop then check that water pressure. Whatever that is, is what the tank should be set at. Too much air pressure and the water pressure will suddenly drop before the pump kicks in.
To set the tank properly turn off the pump, drain all water pressure, then set the air pressure in the tank to the same as the water pressure was. Turn it back on and check again.
Apr 14, 2017 | Water Heaters
Have installed a 1/2 HP wayne jet pump, getting water ,
If we go down the list of possible causes, it may help;
  • All fitting on the new pump and jet are tight.
  • No break in the well line
  • FOOT valve operating OK. If the foot valve is not operating correctly, the pump can lose its prime and **** air into the system.
  • New pump has been purged of air(primed adequately)
  • holding tank has appropriate pre charge
  • bladder in holding tank not ruptured.
Jun 20, 2009 | Plumbing
I have a flotec water pump that sits on top of my pressure tank, pump worked ok last season, and when we tried to prime the pump to start this season, it wont pull water up from the well pipe, pump will...
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Apr 06, 2009 | Flotec Corrosion Resistant Shallow Well...
Air in faucets
The tree may have damaged a pipe,which is letting air into the system. I'm suprised you haven't mentioned a leak. It's possible for air to be pulled in thru the motor seal, if suction is high. High suction usually means trouble in the well, a clogged point or a malfunctioning check. Push on pipes and the pressure line to the switch, if they leak water out, air can be drawn in.
Mar 30, 2009 | Jet Plumbing
AO Smith Pool Pump Motor 1HP Square Flange Swimming Pool Pump Energy Efficient motor Logo
198 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
