Question about Sony HDR-SR11E Hard Drive Camcorder
My sony HDR-SR11E touch screen is not work!
I can't use this function.Plz help.
SOURCE: HDR-SR12 - LCD Touch screen not working.
My camera's touch screen on my SR12E also stopped working early this month (July 2010). Just before I had had it for two years.
I tried to backup, and was really struggling since most functions are done via "the touch of the screen".
But after much frustration trying, I found out that the camera also connects to the laptop the same way by pushing the "burn to disk" button. Try also the blue "EASY" button if the other do not work.
When this is done you can start the "SONY program" to choose import media or what it is called inside the program...
Now you will get the normal menu "popping up" so you can choose to backup the content to your computer.
Beware:
What I did further after backing up was to push the "reset" button to try to maybe get the "touch screen function" back in order.
But this only resets all preferences for the camera.
It did not delete what was stored on it.
The result is now that I will have to film in "default mode" (low quality) for the rest of my holidays, and get an irritating "set-up" screen menu prompting me to input the date etc each time I start the camera and at other intervals...
So the rest of my holiday will be in SD and not HD...
It should have been possible to choose the selections (navigate the camera) via your laptop when you end up in a situation like this...and need to change my settings.
Hope my solution were helpful for being able to backup.
I think you still should check with "consumer help" in your country if you can still get a free repair when the screen stops working, since you normally will be more extensively protected by law then what the warranty tell you.
Posted on Jul 26, 2010
SOURCE: Sony Handycam DCR-HC42E TOUCH SCREEN IS NOT WORKING
I think a wire connecting LCD screen with the cam is disconnected. Plz do not attempt to rectify the problem urself. Must see sony workshop.
Posted on Apr 07, 2008
welcomejee
  • 10594 Answers
SOURCE: SONY DCR HC21 touchscreen buttons/functions suddenly not working
yes, seems its flexible wire that is bad.
Posted on Jun 21, 2009
welcomejee
  • 10594 Answers
SOURCE: LCD on Sony HDR HC1 not working
This happens when flexible wire between LCD board and camcorder board got broken or cracked.
Camcorder needs that connecting flexible wire replacement, let me know exact model of Sony camcorder if you need part number of flexible wire.
Thanks.
Posted on Sep 22, 2009
  • 586 Answers
SOURCE: The Touch screen on my Sony HDR-SR12 stopped
A flexible board (seems like a strip in pale yellow color) worn out and it needs replacement.
The detail of part is given below:
187480611 PWB, FP-807 FLEXIBLE
This part number needs replacement.
Thanks
Posted on Mar 02, 2010
Sony hdr-sr11e harddisk format error
If you have formatted the Camcorder drive instead of external drive you will need to go to a Sony Service Center.
Aug 04, 2014 | Sony HDR-SR11E Hard Drive Camcorder
My sony HDR-SR11E`s the touch screen isn`t responding.
My Sony HDR SR-12 had the same problem. The issue is most likely a broken flexible circuit board which runs from the display through the hinge to the main camera body. After seeing the repair costing from $250.00 to $400.00, I determined the camera wasn't worth fixing. Then I found i could buy the circuit board on Ebay for about $30.00. I ordered a circuit board, actually it came with a second board and instructions. It is a fairly tedious repair and took me about 1.5 hours. You need to be fairly mechanically inclined to attempt this repair. Basically you have to disassemble the camera and touch screen, replace the circuit board and reassemble. The cicuir board has to be folded and wrapped around the hinge correctly. I guess the reason they sell two cicuit boards together is to allow you to ruin one on your first try. The boards i ordered had good instructions on how to complete the repair and fold the cicuit boards. I got mine done on th efirst try, so I have another board for when it breaks again. Due to the time required, I can see whay the repair is expensive.
Mar 16, 2014 | Sony HDR-SR12 HDD Camcorder
The touch screen has stoped responding to touch what is the most likely reason, it did this a couple days ago and i calibrated it and that helped for awhile but now nothing works
I have the same problem. Without the LCD working, I cannot retrieve the data from HDD to my computer. I believe that it is a serious design flaw. Fixing the camcoder will cost $300, not really worthy. Does any idea how to retrieve data even Touch screen does not function?
May 29, 2010 | Sony HDR-SR11 Flash Media Camcorder
My sony hd sr-11 touch screen is not responding.
best thing to do with things like that is to go and talk to a real person at the sony shop, or it could be that you have just set the touch screen setting of.
http://finnsharp.daportfolio.com/
Apr 16, 2010 | Sony HDR-SR11E Hard Drive Camcorder
Sony HC7 flip out screen video rolls and no or limited touch scre
You can purchase a new LCD Flex cable for a Sony HDR-HC3 (Same as HDR HC7) from e-bay for 27 US$.
You can also download free service manual from internet that explains simple repair.
Sep 17, 2009 | Sony Handycam HDR-HC7 Mini DV Digital...
How do you fix the touch screen on my hdv 1080i mini dv,
touchscreen problem on the HDR-HC1 is usually caused by a broken flex cable. service manual is a must-have; it illustrates the correct disassembly and replacement procedures for the cables.
Jun 05, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
Need instruction manual for HDR-SR11E in Russian Language
Hi - You can download the manual from the link underlined in blue below:
HDR-SR11E
Russian Sony support here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 16, 2008 | Cameras
Sony HDR-SR11E  Hard Drive Camcorder Logo
152 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
