Printer shifts from normal paper tray to mp try
Printer shifts from normal paper tray to mp tray without warning, having told me that the 'normal' tray is empty. what do i do to stop this happening?
    Problem Solver:
  • 5 Answers
Change the tray select from Auto to Tray1 in printer properties.
Hope that solves
Posted on Aug 26, 2010
Kyocera 2020d WONT PRINT Load Mp Tray
load a4 paper in bypass or the mp tray as it is also called
Jun 08, 2017 | Kyocera FS-2020D ECOSYS Monochrome Laser -...
My Samsung CLX-6220FX Printer says the paper is empty in the MP tray
Power the printer off, make sure all the trays are all closed properly, then power it back up again. Your printer is fine, the error will stop after restarting it in a full circle.
Aug 01, 2012 | Samsung CLP-500N Laser Printer
My Samsung CLX6200FX printer flashes a red warning light informing me that my MP tray is empty. After removing traying, re-adjusting length and width tray brackets and filling tray with paper and inserting...
Sounds like the machine is trying to pull from the Manual Feed tree (or MP Tray).
This is actually the tray that you open up from the front. (not the tray you can remove)
Try to put some paper in the manual feed tray (again, not the cassette tray) and if it pulls the paper and prints then job then that was the problem.
This could be configured in one of two places:
The drivers on your computer (or in the program you're trying to print from)
or on the machine itself. If it's a machine setting you can confirm this by pressing the PRINT function button on the printer and you should see on the LCD a list of configuration options, if you see something that says:
MP > Tray1 then it's setup to try and pull from the manual feed
You'll have to go into the menu and find the correct setting. (Usually under Paper options)
If you still have problems leave a comment and I'll try to help you further.
Jun 19, 2011 | Samsung CLX-6200FX Printer
Messege * load mp tray * but tray has plenty of
MP tray is not the cassette it this flap that pulls down above it.
The machine will revert to asking to place paper in its MP tray when the information it is receiving about the document from whatever program tell it that the size is not the same as what the cassette is set to...
so, check page size in of document in word program or whatever you are using
also check paper type and size settings match those you just checked in the printers properties under printers in control panel.
If you put a piece of paper in the MANUAL BYPASS TRAY bot the cassette it will print on that.
To get evverything back to normal, turn off printer, delete jobs in print que, change paper size of document in word/excell/etc is set same as paper type in printer, print again.. all should be good...
p.s. these are good quality printers that why I bother to answer you... cheers
Nov 12, 2009 | Kyocera FS-2000D Laser Printer
MP Tray Paper Empty
"MP" tray is refering to the top fold down tray on the front of printer (bypass tray) You might load paper in the bypass and see what it does?
Aug 18, 2009 | Samsung CLP-610ND + Demo Laser Printer
When asking to print keeps saying load MP feeder cardstock A4 although computer set up to print from tray 1?
depends on the printer, normal home use printer have only 1 tray.
office printer usually have multiple trys. and usually the default for that is tray 2. tray 1 is manual feed.
May 14, 2009 | Office Equipment & Supplies
BROTHER MFC 8440 ERROR "NO PAPER"
Check the paper tray adjustable guides inside the tray; the guides need to fit around the paper snug, when re-inserting the tray if the rear guide is back too far the paper may be shifted towards the front of the tray out of range of the paper sensor so it thinks it's out of paper. I service HP LaserJet printers and most of the time this is the problem. Hope this helps.
Mar 12, 2009 | Brother MFC-8440 All-In-One Laser Printer
Hp laserjet4 printer will not print labels or envelopes
MP LOAD,
PC LOAD, or
LC LOAD
paper size,or
envelope size
The printer received a request for a paper or
envelope size not available in the printer.
MP LOAD: Load MP Tray with the requested
media. If the size is not selected in the printer
control panel, use the [MP[Paper[Size] key to enter
the requested size, or press [Shift] + [Continue] to
draw the requested size from another source, if
available.
Note: If MP LOAD remains in the display, you may
have to clear the buffer by resetting the printer.
Press [Shift] + [Reset].
Feb 12, 2009 | HP LaserJet 4 plus Printer
Lexmark T632 says "Load MP Feeder Letter
Hi Pqpoppa,
Check the paper size setting in the printer. Set it to the paper size you normally use such as A4 and the default tray. Check the default paper size in the printer driver in your computer and the default tray. Finally, check the paper size of the document you are printing. If all these match, it should not try to be smart and ask you to feed paper.
Rgds
S88
Nov 03, 2008 | Lexmark T632 Laser Printer
No Paper Light wont go out
is this still a current issue?
Jul 22, 2008 | Brother MFC-8860DN Printer
126 people viewed this question
jasbo
jasbo
