Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
My D-Link WBR=2310 router is always defaulting back to its internal date and time ( 1 April 2008) even after having captured the computer date-time and saving the settings. The new date appears for a while (less than an hr) but eventually reverts back. What causes this? I am afraid it may be cause me other problems. Rheal
  • Anonymous Mar 17, 2014
    How do you set the time on this EOL router? There doesn't seem to be anything except the time server, and the default date of 05 is way too far out to sync with.
    President:
  • 1,768 Answers
1. go in the router configuration page set the time and date there.
The computer has nothing to do with the router time.
Posted on Apr 29, 2010
Have dlink router 1310 when switched over to jumpstart no longer usable
There are multiple versions of both of your routers, you can click on your version and try there tech info from there. If you have no luck, just post the right versions here and I'll see what I can do for you.
There are multiple revisions of the WBR-1310, each with revision specific drivers, firmware, installation guides, and other resources.
There are multiple revisions of the WBR-2310, each with revision specific drivers, firmware, installation guides, and other resources.
Go to there support page and click on your model.
http://www.dlink.com/products/default.aspx?pid=WBR-2310&tab=3
Dec 22, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
How I can reset my password for d link wbr 2310
How do I change the administrative password on my WBR series router? a_detail.jpg Step 1: Open a web browser and enter the IP address of the router in the address bar (default is 192.168.0.1). Press Enter.
Step 2: The username is admin and by default there isn&acutet a password (blank).
Step 3: Click the Tools tab and then click Admin to the left.
Step 4: Enter a new password in the Admin Password section.
Step 5: Click Save Settings.
D-Link suggests setting a user password to limit access to the device.
If you used the router Set-up CD you may have already set the password for the Admin.
Nov 18, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Cannot connect to the internet through the D-Link WBR 2310
INSTALL WINDOWS XP LATEST UP-DATES, SP3 IS THE LAST UP-DATES PACKAGE, AFTER INSTALLING MICROSOFT XP SP3 UP-DATES, INSTALL THE LATEST FIRMWARE OF YOUR ROUTER, INTO YOUR ROUTER, THEN TRY TO CONNECT, I HOPE IT WILL WORK, ALSO CHECK IF YOUR FIRE WALL IS NOT BLOCKING YOUR ROUTER.
Apr 14, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Reset pass word dlink wbr
to reset your router look underneath or on the backside of your router. there should be a small pinhole.
press that with a pin or stapler for a few seconds and the router will be reset to default
Jan 26, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
WBR 2310 wireless stops working.
Please reset the router and also remove the network from the devices and reconnect with the password.
for more visit www.leadingpcfix.com
Feb 13, 2018 | D-Link RangeBooster G WBR-2310 Wireless...
Dlink wbr-2310 router no wireless working
you have to change your channelk type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 23, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Wbr-2310 error 112
Check your physical connection first. From the modem, it should be connected to the router's Internet port, then your computer must be connected to port 1 on the back of the router. Then do a power cycle, no need to run the setup CD. If it doesn't work, you need to manually configure the router. You may need assistance from D-Link tech support. Call their toll free number
Jun 20, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I have a D Link WBR 2310 router. I had it set up for wireless network on my home laptop. It was always configured for immediate access (no pwd required), secured with wpa. I try to connect with my work...
did you reset to factory defaults or just unplug the router?  If you hit the reset button, you'll have to go in and set everything back up.   Have you tried to connect via webbrowser connected to the router from your home computer?  go to 192.168.0.1 and see if you can connect to the router to see what's going on.
Dec 17, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
WBR 2310 Reset Switch
Try this...
--Uninstall the d-link wizard software from your computer...if it actually installed.
--Shut down the computer and router...make sure they're connected together with the ethernet cable
--Turn on the router first.
--Turn on the computer
--Wait about 2 minutes after the computer starts up
--Go to the command prompt and type in the command "ipconfig". This will give you the computers ip address, subnet mask, and default gateway. To get to the command prompt, click on Start -- Run -- and then type "cmd" and click "Ok"
--The default gateway address should be the address of your router...typically it would be 192.168.0.1...but this will tell you if it's something else.
--If the ip address listed after the ipconfig command is blank or begins with 169.... then your computer is probably not talking to the router...the router or network cable may be defective.
--If the default gateway address is something other than 192.168.0.1 ...try that address in Internet Explorer to see if the router will respond properly. If the router responds, you can configure it directly without using the wizard software. Your D-link documentation (on disc?) will guide you through the manual setup procedure...sometimes referred to as the "alternative" procedure.
--Good luck...and I hope this helps!
Jan 12, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
77 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
