Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Renolio bizhub C252 Error code C-3452 Is this the Fusing Roller??? Or how to solve this???
Your problem maybe caused by a thermistor near the pressure roll in the fusing unit (the red roll).
Try the follow procedure and if it doesn't fix call minolta service.
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Posted on Mar 30, 2008
  • chinthaka Oct 13, 2012
    thank u thaknk u thakank u very much
SOURCE:
Error code c-3421 in bizhub c220
Hi
The following site gives error codes for a wide range of printers and their user guides can be obtained as well.
Error Codes Konica Minolta bizhub C220 Code C3421
Your error comes up as follows:-
Code:- C3421
Description:- Fusing heaters trouble (Heating side)
• Detected temperature of the heating roller thermistor/C does not go up a given range of temperature even after a lapse of given period of time at warm up. • Detected temperature of the heating roller thermistor/C does not reach to a given temperature even after a lapse of given period of time after warm up is completed.
Remedy:- 1 Check the fusing unit for correct installation (whether it is secured in position). 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Change fusing unit. 6 Change PRCB. 7 Change DCPU.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 05, 2014 | Office Equipment & Supplies
Error c252
no such code for bizhub c252
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 01, 2014 | Konica Minolta bizhub C250 All-In-One...
Can done one help me to solve tej?a error on The c252 bizhub code c4551
Printer will not print
Jul 27, 2013 | Office Equipment & Supplies
I get a code c3451
C 3451 and C 3452 Fusing warm up malfuntion.Verify the fuser unit and clean the thermistors and the thermofuses and try reset the error code.For reset press following keys:
Utility - Meter count - Details - Stop - 0- Stop - 0 - 1
introduction 0-0-0-0-0-0-0-0 press enter and select the trouble reset(counter windows).
Feb 14, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
Error code c3201 bizhub c203
Fusing motor failure to turn remove the fusing unit. Check for proper operation. If the orange rollers are chewed up replace the fuser unit
try this place for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Aug 02, 2012 | Konica Minolta Bizhub C203
My Bizhub 350 is saying malfunction dectected C3452
This code means you have a fuser warm up failure. The fusing unit uses heat and pressure to "fuse" the toner onto the paper. It is located right where the paper exits the machine. Here is the info directly from the service manual:
The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Most likely you have a thermistor failure in the fuser. You are going to need to call your local service company and have them repair then reset the machine.
Good Luck and Thank You for using Fixya.
Sep 08, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub c350 error code c-0510. What is it? How do I fix it?
C0510 Upper fusing roller abnormally low temp
replace the thermistor in the fuser
Sep 25, 2008 | Office Equipment & Supplies
Konica Minolta bizhub 250 malfunction error 3452
Try shutting dow the unit totally, even try unplugging it from the wall for 15 minutes.
If the error code does not go away, then a technician is needed
Jun 12, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
563 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
