Question about Kitchen Appliances - Others
What temperture do you set a fryer at to cook fries
  • 43,501 Answers
350- 400 will do fine, but remember to not have much ice on them when you place them in the hot oil as water and hot oil do NOT like each other and the oil will come up and out of the fryer...
heatman101
Posted on Apr 28, 2010
I need an instruction manual for a cooks essentials air fryer
How to Use Your Fryer:
  • Remove all packaging materials, sticker, and labels.
  • Clean the basket and pan with hot water, soap and a non-abrasive sponge. These parts are dishwasher safe.
  • Wipe the inside and outside of the appliance with a clean cloth.
  • Place the air fryer on a flat and even surface.
  • Put the basket in the pan.
  • Plug unit in to an approved wall socket.
  • Place the ingredients in the basket and then put the basket and pan back into the appliance. The fryer LED will light up.
  • Set your cooking time and temperature by either choosing one of the 8 presets or manually set it with the "+" or "-" buttons. See "Cooking Guide" to determine the right time and temperature.
  • Once you have set your cooking time and temperature, press the "Start" Button.
  • The heating icon and fan icon will be blinking and this means that the fryer is starting and is circulating the hot air in the fryer. NOTE: During hot air frying, you will notice that the heating up icon will blink and stays from time to time. When the heating icon is on, it means that the temperature inside the fryer has reached the set temperature. When the heating icon is blinking, it means that the temperature inside the fryer dropped and is below the set temperature and is currently heating up to the reach the set temperature.
  • Some ingredients may need to be shaken halfway through the cooking cycle (see "Cooking Guide"), To do this, pull the pan out of the air fryer by the handle, the air fryer will automatically shut down. Then shake the contents in the basket, then slide the pan back into the air fryer and it will resume the cooking cycle. CAUTION: Do not press the button on the handle during shaking; this will detach the basket from the pan.
  • When the cooking time has been reacher, the air blower will stop in 20 seconds.
  • Pull the pan out of the fryer and place it on a pot holder. The cooking pan is VERY HOT do not put on surface that can burn. NOTE: Oil from the ingredients will gather in the bottom of the pan, so be careful when pulling the pan out of the fryer.
  • To remove the ingredients, press the button on the handle of the pan to detach the basket. DO NOT TURN THE PAN OVER. PLACE ON A POT HOLDER.
  • Upon placing the cooking basket back into the air fryer, the air fryer will automatically go to the previous cooking cycle and will repeat the previous cooking cycle, press the cancel button to stop and reset the air fryer if desired.
Mar 25, 2016 | Kitchen Appliances - Others
How big of turkey will a Morrone TKF 300 A turkey fryer cook.
Turkey Fryer is deep enough to fry a 12 to 14 pound turkey and wide enough to be used as a seafood boiler. Heating element is made of stainless steel. It comes with aluminum bailing basket with adjustable quick drain system, control with safety shut-off and a built in digital control with thermostat and timer. Swing out drain valve for easy draining and clean up. CSA certified.
Deep enough to fry a 12 to 14 pound turkey and wide enough to use as a seafood boiler, the Cajun Injector's Electric Turkey Fryer provides home fried cooking without the mess and hassle of stove top or outdoor methods. Equipped with a 30Qt. aluminum bailing-basket, you can submerge and fry a whole turkey or any other foods you'd like to cook fully covered. When the food is finished cooking, simply lift the basket up with the hanger hook, and allow it to drain over the pan with the adjustable quick drain system. A swing-out drain valve to empties the used oil when its time for clean up and a built-in digital control with a thermostat and timer ensures that the food cooks exactly as you intended. The CSA certified fryer features a clear lid so that you can check on the food without risk of burning and is equipped with a stainless steel heating element for long lasting quality.
Oct 21, 2014 | Grilling
Deep fry cod
I usually set mine for 350. When at temperature I cook just long enough to cook the fish. Maybe two minutes depending on how thick the fish is. I normally do it by sight when a golden brown I remove it.
May 24, 2014 | De'Longhi F34512cz Coolzone Fryer With...
How long do you cook chicken. Does the green light need to come on before you start frying?
The Onwer's Guide for the Rival CF106-W Deep Fryer is available here:
http://www.rivalproducts.com/manuals/MANUALS/CF106-W_43_76030376.PDF
For deep-fried chicken, preheat oil to 360 degrees F. Bread and then fry for 20 minutes or until golden brown and done.
The surest way is to check the internal temperature of the thickest portion using a tip sensitive digital thermometer. The internal temperature of chicken should reach 165 degrees F.
See here for safe cooking temperatures: http://canfightbac.org/en/cookwell/charts/
Feb 05, 2011 | Rival CF106-W Deep Fryer
WHAT TEMPERTURE AND HOW LONG DO YOY FRY CHICKEN LEGS
Hi there.
Try 14 minutes at 340F. For other frying recipes, just visit http://www.t-falusa.com
Regards.
Jan 18, 2011 | Tefal FR401615 Family Pro Deep Fryer
Dont know what u cook in it
Oh dear you can cook anything in a deep fryer. some sugestions french fries, breaded chicken, breaded or tempera mushrooms, cut mozzarella sticks in half and bread by dipping in egg and rolling in your favorite bread crumbs drop in fryer till brown about 3 minutes at 375-400 degrees and you'll have the best fried mozzarella ever. any sliced and breaded vegetable will cook fast and taste great.
Apr 05, 2010 | Kitchen Appliances - Others
Does not heat to 375 degree. cooked but soggy fries. green ready light goes on and off. tried preheating 20 minutes. not much better.
you can fry fries at 325 degrees.pre heat for 25 min. rinse fries with water first, fry for 11-14 min. should be golden and crunchy. Deep fry guy :) Fresh potato recipe after fries are fried sprinkle w/seasoned salt &little red pepper
Sep 07, 2009 | Rival CF275 Deep Fryer
Necso how do you fry chicken?
Chicken should be cooked on high setting 250C
please rate our help to keep free service online
Aug 24, 2009 | Nesco DF-1241 Deluxe Deep Fryer
Presto fry baby
I just got one of these w/Instructions, Says fill oil to fill level line inside. Cooking oil or shortening. Never use more than (2) - 8 ounces cups of cooking oil or (1) pound of shortening. Hope this helps!
Dec 12, 2008 | Presto 05430 FryBaby Deep Fryer
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
