Question about Acer AL1917W LCD Monitor
Flat screen monitor
Cant get sound out of speakers
I have a acer AL1917W. The speakers on the monitor do not work. I bought the computer at a pawn shop so i'm not sure if they worked prior to me purchasing the computer. The volume is not muted and is turned all the way up. Please help.
  • 85 Answers
First, make sure that you have all the necessary cables connected, then make sure that they are all connected properly and tightly. Also, make sure that your computer is set to output to the correct output. If that doesn't work, then the speakers are probably broken. That's the exact reason why you don't buy stuff from pawn shops. Cheap, but crappy.
Posted on Mar 24, 2008
Acer AL1917W LCD monitor powers up but no image at all.
The CPU and PSU, have absolutely nothing to do with a monitor.
HERMAN has the correct response. For the info you posted.
When you have a video problem, you post what the motherboard is or what model PC, the graphics card, and what drivers you have installed.
Aug 07, 2012 | Acer AL1917W LCD Monitor
Does the ACER AL1917W have web cam capabilities?
ACER AL1917W is a fine monitor but it doesnt have Web Cam.
You can buy a Web Cam separately and connect it to your computer.
CreativeTECH
Feb 11, 2011 | Acer AL1917W LCD Monitor
Acer AL1917W blinks off in a split-second, twice
remove power to your monitor; then remove the monitor's back cover and, front cover;
when you can see the circuit board check for a buldged can capacitor or, two; replace these by unslodering them and, resoldering the new ones in place digikey.com sells the capacitors (don't forget the position of the capicitors they go in only one way
Jul 22, 2010 | Acer AL1917W LCD Monitor
I have an Acer AL1917W. My computer screen keeps on going black screen and say no signal. HELP!
Make sure your cable is secure, check driver, or you could have a video card thats not working properly
Dec 31, 2009 | Acer AL1917W LCD Monitor
Flat sceen monitors, no sound
did you hook up the sound cable to the computer? and is the sound not muted in the on screen display?
check and advise
Jan 20, 2009 | Acer AL1715 17" LCD Monitor
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Jan 09, 2009 | Acer AL1917W LCD Monitor
Speaker problems
Check to see if its plugged into the GREEN jack on the back of you computer?
Hope thid helps. Bud
Jan 07, 2009 | Acer AL1917W LCD Monitor
Speakers
Click on the speaker icon at the bottom of your display to see if you are MUTED.
Did you intall the drivers?
Plug into the LIME GREEN port on your computer.
Dec 31, 2008 | Mag Innovision InnoVision LT865s 18" Flat...
Acer LCD (AL1917W)
After removing the back cover screws that you saw, ok, there is a screw under the stand holder. Remove the cover that covers the stand holder joints. you can remove it using a flat head screw driver, it is removeable only it appeares stuck to the back cover. After you unscrew, use flat head screw driver and carefully by pushing to the side of the LCD bend. Carefull you might break the cover. Good Luck.
Oct 03, 2008 | Acer AL1917W LCD Monitor
Acer AL1917W LCD Monitor Logo
145 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
