Question about Homelite ZR10926 16 Chain Saw
I lost my manual and need to change the chain on my homelite chainsaw... never had one of these before... stihl and husky are pretty straight forward... this one not so much...
  • carmine_robe May 03, 2010
    i figured it out finally... thanks for your response...
  • dontbother10
    dontbother10 May 11, 2010
    Please contact them and request a new manual. While there request they provide an on-line link to ALL Homelite product OMs please. Homelite/Ryobi.comhttps://register.homelite.com/contact_us...
    Brigadier General:
  • 4,088 Answers
Turn the chain brake off, then remove the side cover (back off the adjustment screw several turns first). Clean the oil ports in the rear of the bar and the area around the oil outlet port. Fit the chain to the sprocket, then work the bar into the chain and pull the bar outward to tighten the chain. Fit the cover back making sure the adjustment tang drops into the large hole in the bar. Run the mounting nuts up finger tight, adjust the chain so that it doesn't droop from the bar, but allows the chain to be turned by hand, then tighten the nuts and recheck chain tension. Hope this helps!
Posted on May 05, 2010
Cant get enought gas
repair - What should I check if my chainsaw fails to start ...
diy.stackexchange.com/.../what-should-i-check-if-my-chainsaw-fails-to-s...
Feb 26, 2013 - Does anybody have any idea what I can do to get my chainsaw started?... Clean carburetor and fuel lines, especially if it may contain old fuel. ... that prevents it from generating enough current to sustain repeated firing of the spark plug as the engine turns. ... Your muffler is pluged up your saw can't exhaust.
Stihl Chainsaw - starts but won't run - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Aug 9, 2006 - Re-chocking (once until it kicks) gets it running again for another 20-30 seconds ... carb body was not letting enough gas through to contunue running the saw at full speed ..... MY STIHL 029 CHAIN SAW BLOWS GAS BACK OUT OF THE .....Can't imagine why shaking the saw around would keep it running. Chain saw won't start
Feb 8, 2012
homelite xl chainsaw
Sep 4, 2009
Husqvarna chainsaw wont start?? HELP
Oct 15, 2006
chainsaw starts then after few cuts shuts down
Mar 30, 2006
More results from forums2.gardenweb.com
chainsaw won't start - any ideas? [Archive] - Straight Dxxe ...
boards.straightdope.com > ... > Main > General Questions
21 posts - ‎11 authors
Jan 31, 2016 | Garden
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Ghening the stihl avt011 chain
If you still can't find after reviewing the follow manual it may be lost.
Instructions for chain adjustments are on pages 21 and 22.
Stihl 010, 011 Operators Manual
Dec 13, 2014 | Stihl Garden
What oil please
Best to use proper chainsaw oil to lubricate the chain cutting in the wood, but at a pinch you can use multigrade car engine oil. Don't use secondhand oil as the added acids,pollutants, etc., from the engine will break down the oil making it less efficient....and leave staining on the wood.
Chainsaw oil can be readily bought from good garden centres.
Hope this helps.
Jul 14, 2014 | Ryobi 18-inch Electric Chainsaw Chain Saws
I need i file for my stihl chainsaw 02-6
They are sold at pretty much any home center or hardware store. You will need the one for a 3/8th chain unless it was changed at some time.
May 27, 2014 | Stihl Garden
We're can I purchase the muffler and everything that goes with it
Any chain saw store should be able to get what you need. Check what kind of saw you have, model number, etc. and then use the internet to find a way to order parts.
Sthil and Husqvarna are two different brands.
Husqvanrna saws are often refereed to as Huskys
Google Search "345 Husky muffler parts":
http://bit.ly/1igUxjF
Google Search "chainsaw parts / Stihl, Husqvarna":
http://bit.ly/1gSCye7
Apr 23, 2014 | Solo 662 667 Chainsaw Muffler W/ Bolts...
Looking for an operator's manaul. Lost mine Need to check Oil to gas ratio
I don't have a manual for you but if your saw is a stihl or husky the ratio is 50-1 .most craftsmen and homelite are 40-1. I hope this helps you. Thanks
Dec 17, 2010 | Garden
Want to fine gas and oil mixture ratio for Homelite 16 inch 33cc
Oil Mix Ratio:
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Stihl & Tanaka; all recommend 50:1.
McCulloch & Poulan; recommend 40:1.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 25, 2010 | Homelite ZR10926 16 Chain Saw
Chain for 24
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Select "Husqvarna; 455; 24"; All; All; All" and make your choice. A couple of things to consider, it only returns 3/8 pitch chain, 0.325 is also available. I ordered a 24" bar for my 359, a Carlton that only takes 81 drive links (82 is normal). I saved $20 by ordering that bar, I just have to be careful when ordering chain. I prefer Stihl chain to Oregon. My Husky is maintained by Stihl mechanics and gets Stihl 2-cycle oil; please do not tell her, she may never run for me again. LOL
Lou
Apr 24, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I need a manual for homelite chain saw 14" ut no. 10655 ser.
50:1 if you use good oil (i.e.Husqvarna, stihl, echo)
32:1 for lesser quality oil.
Download manual here. have UT# available
http://odref.com/homelite/chainsaw/index.html
Apr 02, 2009 | Garden
Homelite ZR10926 16 Chain Saw Logo
138 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
