Question about Dryers
Gas dryer i have no heat in the dryer could it be the igniter or the thermal fusu
  • william ludolph Mar 24, 2008
    thats what i would try first and check your bias thermostat
  • Jgibila Aug 15, 2008
    My Gas dryer spins, sometimes the ignitor comes on and heats and sometimes NOT. I noticed that the Timer does not move position?
    Jake
There is a little hole bottom left, turned dryer on its all dark in there, if its the igniter how much for a repair man to fix it kenmore 70 series????? please respond any thing else that could be wrong. thanks never would of looked there.
Posted on May 23, 2008
Dryer will not heat gas
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 28, 2009 | Whirlpool GGQ8831L Gas Dryer
Tip
Whirlpool or Kenmore Dryer Does Not Heat
Electric
First , check the circuit breaker to make sure they are on . Be sure to UNPLUG the dryer , while checking with an ohm meter . When checking WITH power , BEST to have another person available in case of emergency . I do know of 1 person killed while working on his dryer .
A dryer operating on 240 volts , sends 120 volts to the timer and 120 volts to the motor . In between these two , are the thermal cut-off , and the element ( this is the basic operation parts ) . The 120 volts from the motor , goes directly to the element if selected for heat . The timer circuit , sends the other 120 volts , thru the operating thermostats , then thermal fuse , then thermal cut-off , then high-limit thermostat , then to the element . Usually , not ALL the time , the thermal fuse ( number 1 ) is the problem . The heating element ( number 2 ) is usually the problem , if the thermal fuse is good .
If the thermostats , element , and thermal fuse check good with an ohm meter , remove 1 wire from the element and check with a meter , which side is NOT getting 120 volts . Trace the wire which will either go to the timer ( occasionally ) or to the motor ( extremely rare ) .
Gas
On a gas dryer , for no heat , or , heats for a short time then runs but no heat afterwords until cooled down , first check that the electronic igniter , glows red . If it does NOT glow red , then check power to the burner ( 2 wires ) . If no power , then the thermal fuse is bad . (On electric dryers , the thermal fuse keeps the dryer from starting . On gas dryers , it keeps the dryer from heating . The thermal fuse , is a 1" long , or oval , white piece , with 2 wires going to it ) . Also if it does not glow red , the igniter itself could be bad . Again , check with an ohm meter . If the igniter glows red and clicks off , but no gas , the sensor could be bad . This sensor , is mounted to the side of the burner box , and when the igniter gets hot enough to ignite the gas , the sensor opens , sending power to the coils , which open dispensing the gas to heat the dryer . To check the sensor , with the drum removed , start the dryer , and after the igniter gets red , pull one of the wires OFF the sensor , and the gas should ignite . Do this very carefully , as electricity WILL be in the wire pulled off . If the dryer heats for a short time then stops heating , the problem will be the burner coils . These coils will get warm from the electricity going thru them , and will " open " ( short ) internally , until they cool down . Then heat again for a short time , then open , until cooled .
Most of the time , either the thermal fuse ( 1 ) or the coils are bad ( 2 ) or the igniter is bad ( 3 ) .
........A thermal fuse is a white 1" long torpedo looking piece , or , a white oval shaped piece , with 2 wires going to it .
NOTE1 : The thermal fuse keeps an electric dryer from starting and keeps a gas dryer from heating .
NOTE2 : If your dryer heats but the clothes do not dry , then a venting problem is obvious , as a dryer either heats or doesn't heat . Pull the dryer out and disconnect the vent from the dryer . Dry a load of clothes and if/when they dry in the normal amount of time , this tells you either the vent hose is kinked , maybe pushed back too far , or , the outside vent is blocked , or , the vent in the wall is restricted to the outside .
Electric Dryers
NOTE3 : If your lint screen is on top of the dryer , the element , thermal fuse , and thermostats are behind the rear dryer panel ....If the lint screen is behind the dryer door , then the element , thermal fuse ( located behind the lint screen housing ( 2 screws ) , and thermostats , are located behind the lower front panel .
on Apr 17, 2010 | Dryers
Kenmore gas dryer 70932, 70942, 70952 won't heat. Dryer turns on and tumbles but won't heat.
1. Gas valve coils
2. Thermal fuse
3. Igniter
Oct 04, 2009 | Kenmore Dryers
The dryer runs, but there is no heat. Gas is
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
Aug 20, 2009 | Kenmore 700 6972 Dryer
Kenmore gas dryer wont heat up
1. Gas valve coils
2. Thermal fuse
3. Igniter
Aug 11, 2009 | Kenmore 73952 Gas Dryer
Gas dryer does not heat up. Gas is on and the
1. Gas valve coils
2. Thermal fuse
3. Igniter
Aug 01, 2009 | Dryers
Turns on but wont heat up
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jul 13, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Alg331raw gas dryer. Runs but no heat. Worked
Check the following to address this issue
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 04, 2009 | Amana ALG331RAW Gas Dryer
Gas Dryer quit heating today
Just click below;
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Whirlpool LGR8648 Gas Dryer
Dryer working but no heat
If it does not heat , and you already checked the burner and the ignitor, then it is probably the thermal fuse at the back of the appliance.
See the following suggestions from Repairclinic:
No heat If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Oct 09, 2008 | Dryers
Dryers Logo
87 people viewed this question
Top Dryers Experts
