Question about Vtech Cordless 6041 Phone
My vtech phone just says connecting - Vtech Cordless 6041 Phone
I replaced the battery and fully charged it. The display says "connecting" then, "place handset in Base to register". It still does not work
possible bad connection base to phone, sharplely take phone on and off base repeatedly, to try and get good contact, ensure contacts(probes) on base are not stuck in or out ,
press the helpful button
VTech Phone User Manuals VTech Cordless Phones
VTech Answering Machine User Manual PDF documents
Feb 04, 2016 | Lands Phones
Vtech phone does not ring on incoming calls
hi I have new vtech cs6859 just I buoth yestarday the doase not ringing
Jul 23, 2010 | Vtech 5.8 Ghz Handset Cordless Phone...
Phone screen just say connecting
If is says connecting then most probably its not getting a connection from the base. It could also be your telephone line. Check if the line is active.
Please rate if helpful.
Thanks
Apr 19, 2010 | Vtech Cordless 6041 Phone
Phones stopped working. They only read
first step is to unplug all power and phone connections from the wall for all Vtech phones and bases.
Second,plug each set and base in the wall for power one at a time.
Go back to the basics and pair the handset with the base of the unit.
Do this for all sets one at a time.
May 29, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
I'm not familar with the Vtech but I would suspect that all 4 units work off of the answering machine base. It sounds like it is seeing a dial tone.
Take a working phones like the wall phone, if it is easily removed, and use a known good connecting cable between the good wall phone and the jack that the Vtech is plugged into.
If that works, take the connecting cable loose and replace it with the Vtech connecting cable. If that works check the jack on the Vtech for crossed wire. If non found, connect it to the jack the wall phone was plugged into. If this doesn't provide satisfaction, let me know exactly what you did and what happened and we will go from there.
May 28, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Phones stopped working. They only read "connecting"
The phones need to be unregistered and then re-registered, which you can find in the troubleshooting section of your User Mannual or go to theis webpage http://www.scribd.com/doc/4088938/Vtech-i6789-phone-manual-i6789-manual-i3
Mar 11, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
VTech 2420 handset will not promp me to key in the base ID
If the other three handsets work ok then you have a defective handset.
Mar 17, 2017 | Vtech VT 40-2420 Cordless Expansion...
Vtech cordless phone/ detc 6.0
This worked for me. Unplug the power to the base for 10 seconds then plug the power back in. That did it for my "connecting....." problem. Good luck!
May 19, 2008 | Vtech Cordless 6041 Phone
Vtech not working
Have you tried putting in freshly charged batteries and registering the handsets to the base station?
May 01, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Vtech Cordless 6041 Phone Logo
891 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
