Question about Garden
Chain jammed wont turn makita chain saw - Garden
  • 4,059 Answers
Make sure the safety chain cut off isn't on. It's on top of the saw and when pushed back will prevent the chain from turning. If that's not the problem take the sprocket cover off and loosen the chain and inspect to see what's wrong.
Posted on Apr 28, 2010
Makita LS 1000 miter bed does not turn freely; probably jammed up with saw dust. What is the best approach to cleaning the rotating bed?
PDF]TECHNICAL INFORMATION - Makita
www.makita.nl/images/files/onderdelen/nl/LS1020-TE.pdf MAKITA 255mm(10") Miter saw. Models No. Description. New Tool ... Optional accessories. The main specifications are common with #LS1000. Saw blade:.Missing: bed
Jul 22, 2015 | Makita Saws
Makita 5012B 12'' Electric Chain Saw file size says it is part #744003-1. What is the equivalent in mm or inches for a metal file?
.325 chain takes a 3/16 file 91 chain takes a 5/32 file Check with your mower shop where you get your chain from
Oct 05, 2013 | Makita 5012B 12'' Electric Chain Saw
Does anyone have the manual for the Makita electric chainsaw model # 5014?
The Makita outlet has 2 different models neither the 5014. Open the saw, Download manual is an option once open.
Dolmar/Makita
http://www.makita.ca/index2.php?event=toollist&categoryid=7
This link has 3 electrics agian none your model.
Dolmar is the actual manufacturer of Makita saws. http://charlotte.preferredpower.com/DOLMAR/Browse.htm
Getting closer 5012 http://www.cpomakita.com/static/manual/www.cpomakita.com-5012b.pdf
HTH
Lou
Jan 23, 2010 | Makita 5012B 12'' Electric Chain Saw
ZAMA carb fitted to Makita chain saw which way
Hello Gordon; We need the complete make, model, and serial numbers with every question in order to fully help you. The IPL for the DCS510-18 can be found on this page: http://www.makita.ca/index2.php?event=tool&id=361&catid=40 Fuel line routing2.gif while pictured isn't clear. In the US of A these are red and called Dolmars. A local dealer may allow you to look at his shop manual if one exists. Sorry to not be helpful. Lou
You must help us if we are to help you!
Sep 11, 2009 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Are chain saw chains interchangeable
Yes, but you have to have the same length/number of teeth, the same pitch and the same gauge chain as the original. If all those match against the original, you can use the chain, no matter what brand. Stick to a good chain brand though like Oregon or Carlton etc
Mar 01, 2009 | Makita 5012B 12'' Electric Chain Saw
Makita 5012B chain cannot be tightened
some chainsaws have different knotches where the bar locks onto the saw. loosen the nuts and see if you can move the bar.
Nov 14, 2008 | Makita 5012B 12'' Electric Chain Saw
Tightening chain
with the electric makita you should make sure the bar is sitting on that oval slide piece on the saw. they should fit together so that the bar will sit flush against the clutch plate and saw. attach the cover with the nut and tighten just enough to hold the cover on. then turn the screw on the nose of the saw, next to the bar, and then tighten the nut the rest of the way. if there's slipping or the chain wont tighten you should inspect the bar to make sure it is sitting flush against the saw.
Nov 08, 2008 | Makita 5012B 12'' Electric Chain Saw
Garden Logo
126 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
