Question about GE WBSR3140DW Top Load Washer
Water continues to fill does not stop - GE WBSR3140DW Top Load Washer
  • 4,070 Answers
PRESSURE SWITCH
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Posted on Apr 28, 2010
Water level
Probable causes:
Faulty water inlet valve - unplug washer, if water continues to fill
replace the valve.
Water level switch, hose or dome faulty - service the assembly.
Timer faulty - unplug washer, if water stops filling test timer.
Regards,
Dennis
Aug 22, 2014 | Simpson Esprit 750 Top Load 7.5kg
Water continues to fill after it should have
first does it over flow.if not pull your drain hose up from the drain till it is aleast the same level as the back of the waher control panel.
If the Drain hose is to far down in the pipe this will cause the water to drain out by gravity.the other least likely problem is a bad fill pressure switch.
Sep 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
WILL NOT STOP FILLING
Hello Friend, You either have a bad water level/pressure switch or your water inlet valve is bad. If you unplug the washer from the wall and the water stops filling the washer then it's not the water inlet valve. If it only continues to fill when wash cycle is started then you will need to replace the water level/pressure switch behind control panel. This should solve your problem. Happy to help, Tim.
Jun 30, 2009 | GE WHRE5260E Top Load Washer
Water fill never stops - never! on Kenmore Model 665-16379301
I had this problem and the drain hose had become disconnected. I had a flooded basement.
Jan 10, 2009 | Kenmore 16919 Built-in Dishwasher
Water doesn't stop filling
If you turn power off to machine (or unplug) and washer continues to fill, you need to replace the water inlet valve. (the part the hoses connect to) If cutting power stops the water fill, you have a problem with the water level switch or the tubing leading to it.
Oct 28, 2008 | Whirlpool Washing Machines
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Laundry washing machine
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 26, 2008 | Washing Machines
Washer continues to work even if water is not filled to top and even if i try to stop continues to spin
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub. The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
Dec 07, 2007 | GE WBSR3140DW Top Load Washer
GE WBSR3140DW Top Load Washer Logo
78 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
