Tevion lcd tv lcd4203 cutting out especially when scart input is sellected
    President:
  • 1,768 Answers
There seems to be a logic circuit on the main board that is defective or voltage regulator at an IC that is not keeping the voltage steady and therefore when the input is enabled the circuit cuts or shorts the connection. You will need to have the unit serviced to tell where the specific components are.
Posted on Apr 28, 2010
Input changes.
if you watch it via scart what you need to do is cut pin 8 in the scart leads as this is the one for the power to switch over inputs
Feb 28, 2014 | Emerson LC501EM3 50" 1080p 60Hz Class LCD...
How to connect laptop to LG 65LM 2500-TA
that" easy thing. first you need to check both of them --- lcd tv &laptop what kind connection have ? hdmi ? vga? rca? to find out which one. then you use one side connect to lcd tv . another side connect to laptop. & you need to sellect which one input for lcd tv. that" s it . good luck!
Sep 07, 2012 | LG 65LM6200 65 Inch 3D 1080p 120Hz Smart...
I have a tevion lcd4203 42inch that wont turn on the standby button just flashes
So what is your TV: LG 42LC2D or LCD4203?
I'd check the exact model on the back if I were you.
In LCD TVs this could be caused by either bad power board or bad main board.
In plasma TVs this can be caused by other boards as well.
If it's an LCD the first step is to verify the power board.
if it's a plasma it's usually to start eliminating other boards by disconnecting them from power to see whether and when will the auto-shutting (the blinking LED) disappear.
Probably the easiest thing to do is to send the power board to someone who knows how to test it independantly.
If you want to do that feel free to contact us or just find a local provider.
Aug 25, 2012 | LG 42LC2D 42 in. LCD HDTV
Cant use scart socket
Press the "TV/AV/PC" button to display the choice of input sources, move to the required choice (SCART in your case) using the channel up/down buttons, then press the volume + or - button to selectyour choice.
Feb 18, 2010 | Televison & Video
Lg 42' lcd cant get video signal i can get sound and menu pictures all come up. but no output from cable or ps3
I guess your either using the scart socket or the HDMI socket. You have gone into the menu and changed your input source to either HDMI or Scart havent you? Does your TV aerial input work when switched to Antenna on the input source menu. If these dont happen then you have a faulty main pcb.
Feb 13, 2010 | LG 42LH40 LCD TV
Video output from tv to recorder
You can buy Scart connectors that work either solely as an out put, where you can buy some that are solely an input, look for the type of Scrat with a small switch on it, normally means that it is input/output switchable, it may also depend on the tv's scart plug. if the tv says out put or input then you may encounter a problem.
Nov 27, 2008 | Philips 23PF5320 23 in. HD-Ready LCD...
I have NO earphone outlet on my new Tevion TV. Is it possible to get an adapter that will allow me to fit into one of the scart connector?
R.N.I.D. have gadgets which allow connection thru scart. Will cost in excess of £100.00 with adapters. Pearce.
Nov 05, 2008 | Televison & Video
I have an LG LCD TV (LG 37LG5000 37IN). I also have an older DVD Home Theatre System (SONY DAV-DZ100). It seems that the surround system works well with DVDs but I cannot get the sound to work with DIGITAL...
It works fine if you plug the surround system SCART lead into the AV2 input. I believe this is a 'smart' scart plug (same as SONY but it is not mentioned as in the literature). The AV1 is only good for inputs NOT outputs as well.
Oct 04, 2008 | Televison & Video
I have an Onn 15'' LCD TV Model No OLCD1504 and am trying to connect a DVD player that only has an AV out.I have tried connecting it with a Scart to Av lead in all combinations i.e. via freeview box,direct...
Some dvd players do not have the switching line fro your tv to automatically select scart input but you will be able to select via the tv remote if there are no buttons marked av it can be an oblong with an arrow pointing inwards or you may have to select via the source menu on the tv if you have your original handbook it will give a helpline number for Asda.SUPER8.
Jul 31, 2008 | Televison & Video
F-scart conectio to a open box (satelite)
there may be input settings on the tv that need to be changed, there should be an option to change inputs from HDMI to DVI, or scart
Sep 05, 2007 | Hyundai Electronics E320D 32 in. LCD...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
