Question about Vizio VO47L 47 in. LCD TV
Picture has thin on bottom of screen
Thin many colored line flickers and some time picture flickers
  • 1 more comment
  • cheryl_paxto Apr 28, 2010
    is the image processor one of the circuit boards?
    the expert said it could be the image processor if you agree is this one of the circuit boards,if so which one.the av panel or the main board or tcon
    if i change the main board will that take care of the problem
  • Vizio Master
  • 12,061 Answers
Www.vizio.com/documents/downloads/hdtv/VO47LF/Manual.pdf
Ok, this may be a simple antenna problem, please check all connections, on the set, Sometimes, things like this are just a bad signal, or interference, you will have to troubleshoot, and determine exactly what is causing this to happen? I have given you a servicing manual above, this should help you set it up correctly. Sometimes lines like this spell a going faulty screen,. IF you cannot sort it out yourself, have an engineer have a good look at it. get it looked at by a Vizio approved service center, ring Vizio head office, and ask for a referral, then, ask the repairers for a "Quote" before proceeding with any repairs.
Posted on Apr 29, 2010
    President:
  • 1,768 Answers
You may have a LCD controller or inverter that is malfunctioning.
the main board needs to be serviced by a tech to pinpoint the area of concern for this issue.
Posted on Apr 28, 2010
  • Vizio Master
  • 11,800 Answers
If it behaves like that whatever the input you are using then the image processor is dying and it should be replaced. This is a job for a professional and it will be expensive.
  • Azrael SRL Apr 29, 2010
    Yes, it's in the mainboard. If you replace it -  it will fix it of course. But, as i said, it will be expensive and complicated.
Horizontal line about 1 from bottom of picture
The t con board or LCD panel of the tv is faulty. Can confirm by replacing the t con board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 13, 2016 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
7inch vertical color lines right side of screen all th time
Hi.
This website has the service manual ($7.79) with instructions to diagnose the boards. Unfortunately I am afraid that the problem is not a board but the panel itself.
Thin vertical lines in the middle of the picture mean that the panel is gone. Here an example of lines from bad panel in Toshiba LCD:Line Picture. (discussion: Avsforum). Sometimes the lines can be dark or in bright color.
The panel costs $339 (LCD PANEL ASSY).
Because of the price of the panel, the TV is not worth repairing unless under warranty.
Even if the TV is out of warranty call Toshiba and report the problem. As you can see in AVSforum page above the problem is affecting many users.
If Toshiba doesn't offer special conditions on repair (or discount on new), the TV is not worth repairing. Replacement of the digital board will hardly be a solution.
Only if you have wide bands, scrambled or flickering, then the problem is digital board (main board) or panel.If you have the thin pixel lines, then the panel is gone.
Dec 10, 2011 | Toshiba 40RF350U 40 in. LCD TV
I have a Mitsubishi WD-62525. In general the picture is great from all sources (cable, component, and hdmi). However, there occasionally are very thin, horizontal lines that flicker across the screen....
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
Jan 16, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Thin yellow line on the right of the LCD Screen
If it's a straight line from top to bottom panel could be defective.Not much you can do as cost of panel will compare with a new monitor.
Samir
Jun 08, 2008 | Gateway FPD1975W 19" LCD Monitor
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Laptop screen flickers and color is distorted
Sounds like the CCFL is failing.. (Backlight)... Pink hue is common when these start to go out..
Dec 14, 2007 | Computers & Internet
Television has no picture
That TV uses the PTK195 chassis, and the fact that you see only a thin line for each color near the bottom of the screen tells me your vertical output IC has stopped working, and is putting a small DC voltage across the yokes. I have seen this caused by a defective vertical output IC and I have also seen vertical problems caused by a small CRT coolant leak which drips onto the main board near the vertical output IC. If you do not have experience servicing the PTK195 chassis than have a qualified tech handle it for you.
Jul 12, 2007 | RCA P52937 52" Rear Projection Television
Flickering Lines
I recommend you call a shop and ask them how much it will be to replace the Convergence amps STK-392-110(2are in the set) 99%shure thats your Problem Good Luck Walter Grzybowski
Sep 24, 2006 | Toshiba 50H82 50" Rear Projection...
Vizio VO47L 47 in. LCD TV Logo
60 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
