Question about Cosco Alpha Omega Elite - Hammer Print
Straps nearly impossible to tighten!
We've had our 3-in-1 seat for about a year now in our spare car, so it doesn't get used very often. In the last few months we've noticed the straps are nearly impossible to tighten. We've adjusted the buckle between the legs thinking this was too tight, but it has not worked. We are ready to purchase a new car seat due to our frustration. Any thoughts?? We do not have it installed with the base, would this help?
If you grab the straps up at the top near the shoulder and pull hard you can get a bit of slack at the bottom, they are ridiculously difficult to pull, I have twins and both seats are the same, there should be a handle to pull at the bottom but it just takes strong fingers to do it without that.
Posted on Apr 03, 2008
SOURCE:
In need the instructions
This is a seat post mounted bag, with attachments for the rails (2) on the bottom of the seatpost.
1. The straps going over the top of the bag will have to come apart. Removing them from the loop they pass through before re-attaching with the velcro.
2. Undo the straps and then feed them over the metal seat rails.
3. Re-assemble the straps in the same manner they were before and loosely attach the velcro. You will later tighten up the tension on these straps to snug the bag up under the seat.
4. Attach the velcro strap on the posterior of the bag to the seatpost.
5. Now the bag should be supported by the seat post strap and the seat rail straps (2). Hanging loosely and oddly from the seat area.
6. Tighten/snug the straps from step three, so the bag is drawn up against the bottom of the seat. Try adjusting all the straps on the bag until the bag appears to sit well under the seat.
7. DONE
Jan 05, 2013 | Avenir Bigmouth Seat Bag
I need to adjust the straps to my car seat to fit my growing baby. I have tried multiple times to thread it through the back, but it will not work! I have tried everything and it seems impossible. Is...
you need to turn the car seat over and on the very bottom there are two gold rectangle-shaped clips holding the straps. You can pop these out and feed them through the hole....not like other car seats where the straps unattach up at the shoulder end.
Nov 01, 2009 | Evenflo Embrace
Driver side 2nd row seat is stuck in my 2002 kia sedona
I have had a similar problem. I solved it by keping the seat back raised, get someone to rock the seat back violently while you pull on the balck strap and try and remove the seat. This may not happen 1st time if not spray WD40, and lots of it all over the seat linkages and locking mechanism under the seat.
When you get the seat out turn it upside down and spray with WD40, do this with all the other emovable seats.
Sep 25, 2009 | 2006 Kia Sedona
Moving of seat belt to a higher level
The straps must be undone from a claw on the underside of the car seat so you have to remove the whole thing from the car. The claw is designed to keep the straps in place and this it does very well but its position on the undercarraige leaves no room for your hands and makes it near impossible to manage.
Jun 13, 2009 | Britax Eclipse Si - Paris Convertible Car...
How do you raise the shoulder straps up to a higher level on the Britax Marathon carseat?
Jun 13, 2009 | Britax Marathon
Graco nautilus 3 in 1 car seat need help with strap installation
Yeah its a bit tricky. ON the fron of the car seat there is a strap that goes intot he seat and has a button to lossen it. Press it down to lossen that strap then flip seat over and on the bottom you will find other end of the same strap and it has a brass t-fitting. Take it and pull it up the back side of seat and the shoulder straps fit into the brass fitting then tighten by pulling strap in front of chair.
HAve fun ;)
May 08, 2009 | Graco Nautilus 3-in 1 Car Seat
Nania Nuevo 3-in 1
hi,
i just had the same problem but there seems nothing out there at all, so i had to try myself and just succeeded there.
so a little step by step guide, i hope its clear enough.
1. i found taking the whole thing apart to be the easiest way. so take it apart, you should have two long straps, two metal buckles, and two plastics things you will need at the end.
2. hang the strap with the shoulder pads around your neck, the way it would lie if around your child.
3. note two whole, one on either side of the seat, inside, near where your childs bum would be. imagine the other strap, the long one coming from there(imagine we are starting form the right here), then it goes through the right buckle.
4. next it goes through the right shoulder pad
5. now in real life it would go thorugh the back of the seat, but its easier to leave this last, in case you pull it through lopsided somewhere, so you can fix it, anyhow....
6. the long strap now goes around your neck and through the other , the left, shoulder pad,
7, then it goes through the left hand buckle
8. lastly, it WOULD go through the hole on the inside left of the seat.
before you do that thought, close the buckle and see if everything is straight
9. now pick one end of your work and pull it through one of the holes in the back of the seat, once its thorugh one hole it should go through a thinner grey strap at the back, this is for tightening the whole thing at the fornt once your child sits in the seat, once thats done pull it back out front through the other hole.
10. lastly, pull the long ends of the straps through the two inside holes either side of the seat, they should come out at the bottom, the two plastic green things are then attached to the ends. there is a right and a wrong way here, one way you can pull them in tight, the other you cant
i hope this works for you and i hope i made sense....
Antje
Mar 22, 2008 | Nania Nuevo 3-in1
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Cosco Alpha Omega Elite - Hammer Print Logo
74 people viewed this question
Top Cosco Baby Gear Experts
Zarir Irani
ROB
paul
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
