Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Was embroidering this morning, something hung it snapped the needle and pushed the bobbin case up out of the machine. Reseated the case but it will not sew now. Catchs after a couple stitchs
This is what the machine does. My has been fixed over and over and still I only sew about 15 minutes or less and it happens again. This a lemon and I hate my machine. Singer will not do anything, so I have a very expensive machine that I cannot use.
Posted on May 16, 2010
    Genius:
  • 1,116 Answers
The timing has to be adjusted. This needs to be done by a sewing machine technician, preferably Singer.
Posted on Apr 28, 2010
Machine locked up with needle down in the machine
If you can, try to remove the needleplate and the bobbin case from the machine. Once the bobbin case is removed, the needle should be free.
Embroidery Problems Brother Sewing Machine
Dec 05, 2015 | Brother PE-500 Embroidery Machine
Needle is hitting something
look down in there there is a hook to grab the top thread may have gotten bent or loosend , you may also try comparing the new neddle with the old and be sure it is correct, look for a small latch under the grab foot, please rate -jeff
Sep 04, 2008 | Bernina Bernette Deco 600
Keep the thread from collecting on the arm that holds the bobbin case in? My Brother LB-6800 sews quilts, and embroiders great until yesterday, The thread wraps around this small arm every time now.
Try taking the bobbin case out and re-insert. It sounds like the case that holds the bobbin is not inserted correctly. You might also try checking to be sure that the needle is inserted properly. Sometimes the needle gets loose and drops down too low. unscrew, push the needle up as far as it will go, then tighten the screw.
Jan 24, 2015 | Brother LB-6800PRW Project Runway Limited...
Messages about safe device activated & press the needle position button
The noise is because the machine is trying to raise or lower a needle and can't move. Several things to check. Did the needle break and jam in the bottom thread? Is the needle bent or jam? Did the thread jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom carefully cut the threads until you can free the hoop and material. Then check to make sure all pieces of thread and fuzz has been removed in the bobbin case. If it happens again check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping.
Nov 27, 2013 | Brother PE770 Computerized Sewing Machine
I have a janome 11000. it jammed while embroidering a project. The underneath was rats nest and my needle bent and gouged up my bobbin case...Replaced the case and now the machine makes a clicking noise...
sometimes when a needle gets bent, it can cause the sewing machine to need a adjustment by a technican.
sometimes a jam can be caused by the thread coming off the thread take up lever
or the bobbin is turned the wrong way in the bobbin case
or the bobbin was not thread correctly
Sep 12, 2013 | Sewing Machines
Bobbin case problems
Oh wow. That's definitely not good. Well you'll need to replace the bobbin case, and needle plate. Even the slightest burr can cause havoc. you could try smoothing down burrs with some fine sand paper but you'll need to replace the case eventually if you can't get this problem identified and fixed.
Next look for a build up or stray threads under and around the needle plate/bobbin area. Make absolutely certain you have the right needles for your machine.
Sep 06, 2012 | Janome Sewing Machines
Fabric stuck in hole where bobbin is underneath
Turn off the machine and remove the needle.
Lift the presser foot and remove the inner hoop and then the rest of the hoop.
Move the fabric to one side and cut the threads with a seam ripper.
Open the needle plate.
Remove the bobbin and bobbin case.
Clean away any thread or lint in this area.
You should repeat the last three steps routinely as lint and thread snips can accumulate in these area and cause mis-stitching.
Replace the bobbin case, bobbin and needle plate.
Use a new needle.
Jun 29, 2009 | Simplicity SE3 Computerized Sewing Machine
Singer ce350 bobbin thread on top
Be sure when you are threading the top thread that you ALWAYS RAISE the presser foot. This releases the tension disk and allows the thread to seat properly.
Have you gone back and re-tested on your test fabric? Does it work okay on the test fabric? If so, then there's a suspicion that it has something to do with the fabric, needle & thread of your project. Is your project fabric very dense, heavy... Are you using a stabilizer? A hoop--is it taut, not stretched? Make sure the fabric is not trampolining. Could be an incompatibility. The needle & thread may be having difficulty piercing the fabric. Try a different weight needle, perhaps a microtex or embroidery needle.
Mar 23, 2017 | Singer CE-100 Futura Computerized Sewing...
Once I set up my design card and select design, the needle moves
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
  1. How long have you had your machine?
  2. How long have you been doing machine embroidery?
  3. Do you have a manual for your machine?
  4. Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
  5. Have you taken lessons for your machine or for embroidery?
  6. When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
  • Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
  • Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
  • Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
Feb 03, 2009 | PfaFF Creative 7570
A brand new Singer Quantum Futura CE 200 Sewing/Embroidery machine, have not been able to embroider or sew a single stich, all I have been able to do is wind the bobbin. When I'm going to start...
Dear Magarita, The safety device is activated when thread gets entangled around the bobbin case. First check by removing the plastic see-through plate. If necessary remove the 2 scews on the metal needle plate and remove the bobbin case completely. Put it back and test by turning the handwheel. It should turn freely.
Hope this solves your problem.
Dec 08, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
106 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
