Question about Lincoln Electric K1297 AC/DC 225/125 Stick Welder
I have a lincoln 225 welder and when you plug a grinder or band saw into it and you lay the band saw on a metal table beside the welder after your done using it it arcs on the table, and a grinder does the same thing.
  • 438 Answers
The first thing with this situation is be vary careful this can KILL,
insure that the ground contact to your welder is of good quality, you might have a voltage induced in the metal frame of your welder by the large transformer(inductor) used to modify the voltage/current to a value you can weld with, with a good ground this will not happen, if the ground contact is poor, and you repair the contact, plug it in and it trips the barker, your welder is faulty by way of the primary coil in the inductor contacting the metal body of the welder, this is not worth repairing, also look for any wires that may have worn off its insulation and are contacting the mettle frame of the welder, a good ground will save your life, insure that all your power tools that have a 3 wire cord have a ground contact. good luck and always be safe
Posted on Apr 28, 2010
I am getting no flow of fuel from the fuel tank to the fuel pump. Have installed new fuel filter and full tank of gas. Does this have fuel shutoff valve or a screen in the fuel tank.
[PDF]Ranger 225 Product Info - Lincoln Electric
www.lincolnelectric.com/assets/global/...1/e689.pdf
Lincoln ElectricENGINE DRIVEN WELDERS ... 50-225A DC 15-25V CV Welding ... Ranger® 225) for aluminum and other alloy welding. .... equipped with valve for gas flow.
Oct 09, 2015 | Lincoln Ranger 225 Engine Driven Welder...
How does dall 1612-3 power feed work?
Consult your manual. If you don't have the manual , check bandsawmanuals.com ,they have free downloadable manuals.
Aug 13, 2014 | DoALL 1612-3 Vertical Band Saw W/ Blade...
Lincoln Arc Welder AC 225 Wiring Diagram
won't have reverse polarity. There are only 3 wires, 2 power and one ground. It does not matter what power lead goes to what side.
Apr 19, 2012 | Lincoln Electric K1170 AC-225 Stick Welder
Coming out of the breaker box going to the welder plug what size wire should i use to run a lincoln 225 welder
It depends on how far away you are going to be away from the breaker box, using a #2 wire should be fine for your welder.
Nov 04, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Welder doesnt turn on...
Have you connected the feed from your breaker box to ADJACENT lugs on a dual pole breaker? By code you must use a ganged breaker.
You should use a voltmeter to verify the plug is getting power on teh desired pins.
Sep 25, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
Jul 30, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln Electric K1297 AC/DC 225/125 Stick Welder Logo
536 people viewed this question
Top Lincoln Welding Tools Experts
Steve
joe2639
Level 1 Expert
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
