Question about Swintec 7040 Typewriter
How do I change the code associated with the printwheel on a swintec 4040. I changed the wheel but now the keys are not synced with the new wheel.
  • 16 Answers
Make sure the slide switches are all in the proper settings, turn the machine off then back on, the print should be ok
Posted on Apr 28, 2010
I'm typing words, but the typewriter is typing jibberish, how do i fix?
make sure the lang button is set for the print wheel try pressing lang and typing
Feb 29, 2016 | Swintec 7040 Typewriter
HOW I CHANGE THE LANGUAGE OF THE SWINTEC 7000 TYPEWRITER
To print in a different language, your best option is to get a printwheel that contains your preferred languages special characters. You can see a list of them here:
Swintec Printwheels
May 16, 2014 | Swintec Office Equipment & Supplies
Replacing printwheel in swintec
Remove the ribbon, pull back on the black lever on the R. edge of the print wheel.
DickyO
Dec 07, 2013 | Swintec 8014-s Electric Typewriter...
I have a plastic on my print wheel do i remove it
Your description of plastic is not clear. If you mean the plastic case it comes in, then remove the printwheel from the case. Other than that the printwheel should be just the plastic fingers on a hub. You can see a sample on the www.swintec.com website. Hope this helps.
Oct 15, 2013 | Swintec 7040 Typewriter
I brought a swintec 7040 and on my print wheel there is a plastic on it do i remove
If the plastic is packaging, do remove it. The printwheel should be inserted as a black hub with black hard plastic fingers. The hub snaps into place on the hub wheel either by you snapping it into place or by you sliding it into a slot and pushing a lever to put the printwheel carrier into home position. You can see a sample of the printwheel on www.swintec.com.
Oct 15, 2013 | Brother ML-100 Typewriter
I need to change the font and do not know where to go on the Swintec 2600 typewriteer
To change the font you must change the printwheel. You can change the pitch by moving the slide swith on the L. side of the keyboard.
DickyO
Jun 20, 2011 | Swintec Office Equipment & Supplies
We need to change the font on our swintec 640
  1. Remove ribbon
  2. pull printwheel release lever toward you
  3. remove and replace print wheel
  4. push printwheel release lever forward - away from you until it snaps in place
  5. replace ribbon
  6. adjust pitch selector on keyboard if needed.
Dec 08, 2009 | Swintec 7040 Typewriter
How do I change the font and type size on a swintec typewriter
To change the font you must change the printwheel. Remove the ribbon and L/O tape, Pull the lever just to the right of the print solenoid. Remove the printwheel by pulling on the knob in the center. To change the pitch move the slide sitch on the L. side to the setting you want. DickyO
May 30, 2009 | Swintec 7040 Typewriter
Need to change the font size
you would have to buy a new printwheel and change the pitch setting (which is a switch on the left side of the keyboard tha has 10, 12, 15, PS printed next to it) or just changing the pitch setting may get you the desired results. it won't hurt anything to change the settings, it just changes the spacing. The PS setting only works on a PS printwheel, any other kind will just print the wrong letters.
Nov 18, 2008 | Swintec 7040 Typewriter
Swintec 7040
If what you are saying is that you get 2 vertical lines instead of a letter start with a new printwheel, what you are seeing is the hammer face when it misses the printwheel.
DicktO
Aug 30, 2008 | Swintec 7040 Typewriter
Swintec 7040 Typewriter Logo
106 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
