Question about Whirlpool RF364 Electric Kitchen Range
Stove top or oven does not work however, clock
Clock and keypad and lights work however, elements on stovetop or oven will not heat up
  • 574 Answers
Check your 220v outlet, you could have 110v and not the needed 220v to operate the elements. If you only have 110v at the outlet the one side of the double breaker is bad
Posted on Apr 28, 2010
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Using oven and there was a pop and it went dead...oven, stovetop burner, clock panel, oven light!
Your element has burnt out. Reset the breaker, and get a new element. You can usually see where it has gone.
Some older stoves have glass fuses hidden behind the front panel.
Apr 16, 2016 | Kitchen Ranges
Stovetop & Oven not heating but clock, lights, & vent fan are working
It sounds like you are getting only one side of the power to your stove. the lights will work but no heat. your power breaker has two sides for an electric stove. It may be one side isn't reset properly. make sure that you snap the breaker completely off and then completely back on. if that doesn't work perhaps an electrician is in order or one side of your power cord has burned off at the terminal block. I have had this happen.
Apr 28, 2013 | Kitchen Ranges
The clock is lit but the elements do not heat up
What is the make and model number of your unit?
Apr 06, 2013 | Kitchen Ranges
None of the elements work, stove top or oven, stovetop light 'surface heating' will come on but nothing heats. Oven light on panel doesn't turn on but light in oven is off unless both dials are on or a...
Remove the panel on the top of the back of the stove - check for grease residue on connectors plugged into circuit board - clean connectors and circuit board with electrical contact cleaner - reassemble and test for correct operation. The oven vent at the rear of stove sometimes leaks grease filled vapors into the area of the control circuit board.causing bad or intermittent electrical connections to oven temp sensors and front controls on the oven.
Dec 22, 2017 | Kitchen Ranges
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Whirlpool RF364 Electric Kitchen Range Logo
225 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
