Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
My computers no longer recognize my external hard
My computers no longer recognize my Simpletech 320 external hard drive. I've tried it on two seperate computers. It doesn't sound like the external drive is is trying to "fire up" boot up like it usually does. I hear a couple of whimpers from it but it never really goes into full working mode. When I go to my computer, it is not there. I've tried plugging it in to the usb and then turning on and I've plugged it in while it was on. I've also tried to leave it plugged in and restart the computer.
  • glamb1313 Apr 28, 2010
    I don't know what "slave it to my hard drive" means
  • 157 Answers
Check to see if its still under warranty. Most times they have at least 1 to 2 years. If it isn't, I would remove the drive from the case and slave it to your system to see if will work that way. Doing that will narrow it down if its a drive issue or a USB issue. Good Luck.
Posted on Apr 28, 2010
  • frankdanfelt Apr 28, 2010
    If you system is a laptop, you would eed an adapter. If its a desktop, you remove the cover of the pc and either attach it to an existing IDE cable (if its an IDE) or if it is a SATA drive, hopefully your motherboard will have SATA connectors. Or if its IDE, (or SATA) you might be able to pull the cable from the CD or DVD drive and use that. Make sure you also hookup the POWER as well (its a 4 prong connector if ide or a small cable on sata) I know it sounds confusing, but its really not. Once you open up your external case you will be able to tell which controller cable it needs.
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Upgraded to win 7, now the black cherry, Signature 320 is no longer recognized and will not download a driver, is one available for Win 7, will not run in compatability settings.
No driver is required to use the drive. Try another cable or another port on the computer. If you are using it bus-powered, try using a USB "Y" cable as some computers cannot provide enough power through one port. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Feb 01, 2011 | SimpleTech Signature Mini 320GB External...
Black
Try to go through disk management and see if it works?
Open control panel then select administrative tools then disk management. Then in left column click disk management.
If you locate it may be it must be initialise by the system or need to create partition by formatting.
You can also check all the cables , the power cables the adapter , try to change the Usb cable also..
ok
Good luck !!
Jan 22, 2010 | SimpleTech 320GB SimpleDrive External by...
External no longer recognized
Right click My Computer, Properties, then click on Device Manager.
Select Disk Drives then on tab menu Action, Add legacy hardware. Go through the setup and use CD's that came with Hard Drive otherwise search company site for drivers.
Oct 05, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
Simpletech 250GB STORAGE S
try plugging your HD into another desktop/laptop to see if your HD is functioning well on a different computer. Could be the USB cable problem.
Feb 01, 2009 | SimpleTech SimpleDrive 160 GB External USB...
My simpletech signature driver 320 is not recognized by my PC
I had the same type of problem and found when I took the cover off that the harddrive worked loose from the plug. Pushed back into socket and reassembled, works great.
Dec 29, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Not being recognized by computer
Is that external???If yess just buy new external...
Dec 10, 2008 | SimpleTech SimpleDrive 250GB, 7200RPM,...
SimpleTech 320 gb. Code 10 Problem
i doubt you can do anything about it. Code 10 is a hardware failure, so you will have to return it and get your warrenty.
Apr 28, 2008 | SimpleTech 320GB SimpleDrive External by...
Potable drive not recognized
What is your computer/Operating system?
Oct 21, 2007 | SimpleTech (STI-USB235/400) 400 GB Hard...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
219 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Ricky Ostrom
Ricky Ostrom
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
