Question about Samsung HLM507W 50" Rear Projection HDTV
Samsung rear projection tries three time then goes
Samsung 50" rear projection TV, tries three timed to start then goes off, just will not lite up, picture wheel-running, 2.5 years old. Should I get repaired or not. I'm very good with tech! but where will it end. Patrick from West Ireland
    Sergeant:
  • 171 Answers
For DLP television 70% of the time the problem is coming from lamp they are only made to last 6000-8000 life hours witch is a approx.2-3years of use and I think that is your problem right now I don't think it's necessary to buy the light engine
Posted on Aug 23, 2010
    Novelist:
    Champion:
  • 203 Answers
There are several things in this set that will cause this. I have ran into this problem 40-50 times on that specific unit. Most common problem is the lamp. Next most common problem is the DMD board which is a very expensive repair. Next most common cause is the ballast which powers the lamp. Next is the color wheel but usually that gets noisey before it fails. These DLP televisions aren't easy to diagnose but they're easy to work on. Now here's the thing, all four of these problems can be solved by replacing the light engine. If you are willing to put some money into it, the engine assembly is real easy to change. Just google the exact and complete model number and search prices of the light engine. I'm pretty sure the part number is BP96-00305J. Sometimes you can actually ship the engine from your tv in to be rebuilt. This can save you money. Any repair on this tv will probably cost 200-500 but they get a great picture. I have a samsung DLP in my livingroom. Good luck, Russmann.
Posted on Apr 28, 2010
Screan shuts off after 30 seconds and 3 lights flash on botton near power button.
Contact Samsung tech support, Tell them this info, they should be able to tell you the type of problem you have
Feb 12, 2014 | Samsung HLP5085W 50" Rear Projection...
Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
May 01, 2010 | Samsung HLN5065W 50" Rear Projection...
My tv is a samsung rearprojection and every time i switch it on it gose strate to standby
The first place to start will be the Main power supply. Any time the set shuts down and goes to standby is a symptom of a bad power supply. I recommend replacing the power supply unless you are skilled in component level repair.
Apr 13, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung 50" rear projection tv switches off after a few seconds
probably need to replace the Ballast and Power Supply Board. If lamp has not been replaced, I would replace that too. can call 1-800-samsung for nearest service center.
Dec 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Hlp5063w 50'' projected samsung lamp won't come back on ?
It could be the lamp but don't overlook the lamp door interlock switch. If the lamp door is not aligned properly, you may have intermittent shutdown or no start conditions. You can temporarily cross the interlock switch to confirm that this is the cause.
michtech
Feb 17, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Problem turning On
Same exact problem started 01-08. Any suggestions yet>?
Dec 07, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Open Questions:
Samsung HLM507W will not turn on Alright so here's the deal....I got this TV for free from a guy on craigslist. He said he couldnt get it to turn on. He replaced the lamp, it still didn't work, so he gave up and now I have it. First thing I did was try and turn it on... The TV powered up for about 5 seconds, and then the screen started to flicker all kinds of crazy colors, and it shutdown shortly after with all 3 lights blinking. I figured this probably has to do with the color wheel, so I bought a new one and popped it in. Once installed, the TV started right up, and worked for the entire duration of it being on (approx 7 hours). Now it will not turn on. Here's the startup sequence: -Push power -A couple of audible clicks, and both cooling fans energize. -Lamp does not turn on, and after about 45 seconds of having just the fans running, the TV cycles off and tries to power itself back on. -Rinse and repeat about 3 times total. -After the 3rd attempt, the TV shuts down completely and all 3 lights start blinking in front. -Pushing power does not do anything with the 3 lights blinking. TV must be unplugged and pplugged back in before sequence can be attempted again. Looking for a possible solution/troubleshoot technique. Checked the fuses and they are fine, triple checked all of the connections. Seeing as the lamp doesnt even attempt to energize, Im thinking it could be the ballast, but I'm trying not to dump money into something that might not fix the problem. Thanks for your help!
Jan 21, 2013 | Samsung HLM507W 50" Rear Projection HDTV
Samsung HLM507W 50" Rear Projection HDTV Logo
213 people viewed this question
Henry  Thomas
Henry Thomas
