Question about Uniden BC-785D Base Scanner
2 of my digital tracking channels on my 785D have stopped picking up transmissions. I can't find my manual and don't remember how to reprogram it - can you tell me how to verify what is programed and how to reprogram it.
    President:
  • 2,761 Answers
I'll do better than that. You can download/print the entire manual here:
http://www.uniden.com/pdf/BC785Dom.pdf
For a comprehensive database of active frequencies and systems in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Posted on Apr 28, 2010
New LED tv will not pick up digital channels
Refer its user manual, and make sure that the TV can receive digital transmissions. Refer its specification page. If it says, yes, and the TV doesn't receive any digital channels, contact the authorized service center. Its digital tuner is likely to be faulty. Gopakumar Gopalan Google
May 20, 2014 | Televison & Video
My mom's bc248clt stopped working. adjusted squelch but won't pick up signals. had it to a guy who repaired it in the past but he can't figure it out. Perhaps a programming problem? How can I reprogram?
Press manual,enter the channel number,press manual,enter the frequency you want,press E,if you make a mistake,press CLR twice to erase. ..hope this helps..
Mar 03, 2010 | Uniden BC248CLT Base Scanner
Installed a comcast digital box on the panasonic tv and
Go in menu goto setup pick ch.setup pick cable rescan all channels
Jan 13, 2010 | Panasonic PT-61HX40 61" Rear Projection...
LG 20" memory problem
you will need your mainboard replaced eprom has fail
Nov 30, 2009 | LG 20LS7DC 20 in. LCD TV
The Zenith Digital TV Converter DTT900 needs reprogramming
1) While pressing & holding down the TV POWER button, press CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on or off. 2) Release the TV POWER button when your TV is turned on or off. *Each press of the channel button sends a manufacturer code (1-45) to your TV, one after the other. Note: You may have to do this every time you change or remove the battery, as the remote will reset itself to the default code.
Nov 25, 2009 | Televison & Video
I had all 5 terrestrial channels on channels 1 to 5 on my television and Virgin channels on channel 6. I was sitting watching the television when all 5 channels stopped working and I am left with the...
I don,t where you live & therefore I don't know which transmitter you will be picking but this sounds as if your local transmitter has now stopped transmitting the analogue signal. You maybe aware from a lot of advertising that this form of signal will be getting turned off in different areas around the country so unless you have cable or a digi-box or a digital TV then you will not receive any signal. As you have the Virgin box you will still receive channels 1 to 5 on digital but not on analogue.
Oct 15, 2009 | Televison & Video
Can't get digitall channels
I have the same problem, If anyone could help it would be appreciated.... I have the coaxial cable plugged in which on another TV had all 85 channels, and I changed the TV from analog to digital and reprogrammed it but I still only get like 4 or 5 local channels?
Jul 09, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Recent digital conversion - cannot pick up all local channels
Have you gone into your tv's setup and reprogrammed or scanned the new channel assignments?
BTW, what is your tv model?
Jul 07, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
How do I digitally tune my westinghouse TV SK32H24OS. Lost manua
The easiest way might be to unplug the power from the set for several minutes, plug it back in and then run through the setup procedure. You are specifically looking for the channel auto scan function.
Feb 25, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Uniden BC-785D Base Scanner Logo
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
