Question about Aiptek Video Cameras
Trying to record from tv cable is pluged-in properly av-in is selected message of "no signal" is displayed what could be wrong?
  • Aiptek Master
  • 19,396 Answers
Hi.
Ensure that the cable is running from AV-Out (not in) on TV to AV-In on camcorder, or the whole thing will not work.
If that is not the problem, try the following:
  1. Turn off TV and camcorder.
  2. Disconnect TV power cord.
  3. Remove and put back camcorder battery.
  4. Start the camcorder.
  5. Connect AV Out on TV to AV in on camera. Some TV does not have AV out.
  6. Connect TV power cord and restart TV with the camcorder attached.
  7. Check if camcorder LCD display is showing the picture.
If that does not work, try switching the camcorder settings between QVGA and VGA, test a different cable, and if possible, test the output from a DVD or a game console.
Regards.
Posted on Apr 28, 2010
Why does the menue not display?
Is the RF tuning set up for coaxial?
Sep 11, 2014 | Televison & Video
I can no longer use Timer Record on my LG RH397D
use free to air tv aerials app (google or iphone in store) on your phone or tablet, this will help you line the aerial up with the transponder, that app also tells you the signal strength you should receive. as from recording on timer from av that was never a thought when recorders were made only transfer signal only.
Jul 02, 2017 | Televison & Video
Why won't my TV accept the Av signal from my VCR?
A couple of possibilities. First a faulty cable or socket on either the TV or VCR. Next the VCR is plugged into the wrong AV connection.
Jul 24, 2013 | Televison & Video
Scheduled a timer recording of a program on a DVD+R and when I went to play it back all I got on the screen was noise and snow. I now realize that I used the wrong disc (should have used only DVD-R). ...
Hi,During timer recording adjustment you must have selected what ever you want to record..i.e: Tuner Channel , or ,Video1 input ,or Video 2 input etc..This problem is related with Source selection but not with - + type Disc..wrong disc will refuse to record at the beginning..
The noise and snow shows that your recorder was Recorded an unadjusted RF channel..thus no TV signal was available during recording ..
I assume that your DVD recorder has built in TV tuner in...To correct the problem,first you make an automatic Ch set up ,search the available channels either on the Cable (if you have ) or RF local channels thru Arial Antenna..
than you try to record again by carefully selecting ..you will record TV RF channels successfully. Or you can attach another video source to your Recorder thru the RCA cables on the back panel and by selecting the respective SOURCE in accordance withe cabling you have made than you will record the AV signals available on your Receiver..
If you need more help pls let me know for further advise.
Aug 10, 2011 | Toshiba DVD Recorder
I cannot record from a Daewoo DVD recorder ( 8150P) through my Viera TV ( model TX-L32S20B ). The screen says No Signal and instructs me to check inputs. I've tried using all cominations of AV1 and AV2...
If you want to record from the TV to the DVD recorder you have to first select a channel on the TV that you want to record and then take an AV cable ( Yellow / Red / White ) and connect from the Monitor out socket of the TV to the AV in of the Daewoo DVD recorder. Drop a blank DVD select AV on the Recorder and press the record button.
Mar 08, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I am trying to connect my Onkyo DS-A3 ipod dock to my Onkyo TX-SR508 receiver and I cannot get the TV to display the ipod menu. I've connected the red and white (R/L) and yellow video cable to the...
Is OSD set to ON? See below
Set the OSD (onscreen display) mode before you start using the RI Dock. 1. Plug in the AC adapter. 2. Turn on your TV and amp, and select the appropriate inputs on your TV and amp. 3. Insert your iPod into the RI Dock. 4. Select the video output mode depending on the video connection. While pressing the remote controller's [SETUP] button, press the Up [ ] button for the component video connection, press the [ ] button for the composite (default) connection. 5. Use the remote controller's [MODE] button to set the OSD mode. On: Playlists (artists, albums, songs, and so on) are displayed on your TV, and you can navigate and select your music or video while looking at your TV. While this mode is selected, your iPod displays the Onkyo logo. Off: Nothing is displayed on your TV and you navigate and select your contents by using your iPod's display.
Mar 15, 2017 | Onkyo Audio Players & Recorders
Although the Freeview box is correctly installed with my TV,when the men button is pressed the only message to appear on the TV screen is No Signal,HELP!!
Ok, if you have "No Signal" that can only mean you must be selecting the wrong INPUT, when it is hooked up yo the TV, essentially the TV, is just a Display Monitor, and it doesn't use "Channels" anymore, it uses the AV, or EXTERNAL Inputs, any channel changing is done on the Freeview box. Make sure you are connected color to color, cables are connected. The antenna, goes into the freeview, the AV cables go to TV, taking the Video 7 Audio, from the Freeview box, to the "Screen" TV, set to the External input, that the "Box" has been connected too. Check your manual out.
May 08, 2010 | Televison & Video
Video transfer not working
  1. connect VCR(recorder) to TV, select TV proper channel to get signal from VCR
  2. connect Mini DV to VCR, for example, you are using AV1 input on your VCR
  3. on you VCR, select channel(or input) to AV1, insert a blank tape
  4. turn your Mini DV to play mode and play, press REC on your VCR
you should get picture now.
May 08, 2009 | Panasonic NV-DS60 Mini DV Digital...
No picture
Look under your tv settings for the pal ntc settings if you are using the av wire, if not please tell my what yoiu are using, also mak sure that youve pluged the av wire in the yello conecter av out on dvd/vhs and @ the tv AV in
Jan 03, 2009 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Cable hookup and av hookup
Connect your TV to AV1 and you SAT/Cable Decoder to AV2.
on the video select the AV2 channel and it will record whatever is connected to AV2. The AV channel selected it is the input the one not selected is the output.
Some PPV Movie channels are copy protected with some service providers. But most channels are recordable.
The aerial lead coming in your house connects to the SAT/Cable Decoder 1st, then connect the output socket on that to the Video/DVD then the output on that to the TV. As long as the leads you use have different ends on you CANNOT plug them into the wrong socket. As the the aerial passes through each device, the device adds its own RF channel to the feed, so you should be able to tune both a SAT/Cable and a Video/DVD channel onto the TV set aside from using AV/Scart.
Dec 27, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Video Cameras Logo
44 people viewed this question
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
prouddad_1
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
