Related Tags:
This problem should be removed because:
Problem with HP Photosmart C3180 All-In-One InkJet Printer
change region codess on printer hp c3180
i just red your solution on changing the region code of this printer from the europan zone to the US. I was just wandering if you know by chance the code number to do the same trick but on the opposite: from a US zone to the european,
Thanks
Jose
Solutions (4)
Best Solution
I have moved to Switzerland recently. Have called support spent over 10 hours on the phone, lost the counts of call. Put on hold several times, been told, there's no such thing as region code. They actually told me I should buy a new printer that's compatible with my region (and this was not a joke).
I am pretty much frustrated with HP. If you find a solution or a legal way to compalin about HP let me know.
I am at the point - after 15 years buying HP products to throw all the 3 printers I have away and buy new ones that do not have this stupid region coding. By the way I have found a way, if you buy refill kits then I can continue using my printers... so much for HP ide of buying original supplies...
I have just moved from the US to Shanghai with my HP C7280 printer. Bought some new cartridges from the HP dealer in Shanghai after our US supply ran out. Got the 'Incorrect Ink Cartridge' message on the printer after installing them, which the dealer probably knew I would get and didn't tell me, which I'm assuming is what you got.
My experience was to use the 'Chat' function on the HP.com web site in the Support area. The good news is that they solved my problem, the bad news is that it took 1 1/2 hours and is the most convoluted process I've experienced in years. There is a little 'voodoo' going on the background......... after having me find several values, including cartridge serial number values (no not the cartridge number on the cartridge), reset values, and others I can't remember, he said he had to go 'calculate' and he then came back with 5 four digit numbers I had to enter after going to Windows Control Panel -->Printers and after getting my printer selected and the Preferences screen displayed, clicking on the HP logo while holding the CRTL key down (I kid you not).
Sooooooo, I believe the only solution is to use HP Support and to also write letters complaining about how really, really, really stupid this process is. And being the conspiracy theorist that I can be, HP probably was seeing lost revenue from people buying cartridges that are cheaper in parts of the world and shipping them to where HP is, ahem, making a killing and padding their profits.......
Good Luck
The printer is regionalized in a way similar to DVD and other technology. Cartridges from a different region will not operate in the device. It is possible to change the region of the device. Changing the region can be attempted a limited number of times, it is therefore recommended only for a permanent relocation. If you would like to change the region of your device, you will need to call the local support. You also will need to have a complete set of cartridges for the new region on hand when you call.
This should resolve the issue.
Khaled
Go buy a CIS system from here: http://www.continuous-ink-systems.co.uk
I installed one, June 2008 at about £70, since purchased £30 of ink refill from Promax and have printed 4000+ a4 colour and 1000+ A6 gloss cards and still have 50% of ink left.
Regards Japlah
Regional Codes for Europe
I've read the article on how to set a C3180 european printer to run with US cartridges, posted by paulskiya. "..do a 10 tab test...
Hi, i just red your solution on changing the region code of this printer from the europan zone to the US. I was just wandering if you know...
Need to change region settings
C6180 is set for zone 2 (Europe); have moved to zone 1 (US). Zone 2 uses ink cartridge nos. 363; Zone 1 uses 02. Printer will not operate....
Region Changin
Hi I was wondering if someone could tell me how to change the region from European to US of a HP PSC 2350 ??
Add Your Solution
poor print quality
changed cartrige but continues
HP C3180 ink cartridge jams during installation
I cannot get the replacement cartridge in place. It jams every time instead of clicking into position like the pictures...
HP Photsmart C3180 - no paper jam - paper spits...
so it's still in there. The computer screen for the printer says "Something has prevented the printer...
I have a 3180 All in one HP. The ink level figures...
I have a 3180 All in one HP. The ink level figures on the color & Black ink does not show how much ink is in the...
paper does not pick up to print
Also the check paper light is on..even when the paper is loaded in unit
See all HP Photosmart C3180 All-In-One InkJet Printer Problems
Fix-O-Meter
10,108
10,108 people viewed this problem
- 5 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top HP Printer Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
