Question about Ecoquest Fresh Air Air Purifier
Living Air Model XL-15C: the red-neon FT ionizer bulb does light.
Does rust on a) the attachment-bolt of the needle ion generator and b)on the antenna cause the red-neon bulb to not light when the unit is running? If so, can cleaning both with steelwool solve the problem?
    Problem Solver:
  • 11 Answers
Corrosion in the cicuitry at the connection are unseen until you take them apart, can cause this. The male and female connectors might be together but rotted inside the boots unseen and not connected. That happens sometimes. Gently pull those connections apart and look inside both connection areas and check.
Posted on Apr 29, 2010
Testimonial: "Thanks for answer. I'll get back to you after I have taken the rusty parts off and cleaned them."
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
I have 2 Living Air XL-15 that no longer will power on. I have checked and the clip that depresses the switch is fine but nothing. How can I tell if the fuse is no good?
Continuity is one way, they need to be able to conduct. If they are ceramic- use a test meter. If they are glass, does the wire reach from end to end or it melted? Does it resemble an old flash bulb that had been used? If so, or no continuity- replace fuse.
Also clean the contacts for the ionizer plate.
Jan 30, 2012 | Alpine Air Air Purifiers
Red light will not go off
The only other light I'm aware of is the light in the back of the machine attached to the radio frequency ionizer. This light lets you know that both of the ionizers including the needle point ionizer are working. When the light is off, it means the ionizers need cleaning or service. When I clean my machines, I always clean off both ionizers w/ a 50/50 solution of Ammonia w/ a paper towel. I do this the same time I clean the ozone plate. If you're machine is still under the 3 year warranty, you can send it back to be fixed for no charge except shipping. I hope this helps.
Jul 25, 2011 | Alpine Air XL-15 Air Purifier
My "prove-it" light indicator does
How long have you owned the machine? If bulb is out, (the one deep inside the machine) it means the RF ionizer or needle point ionizer isn't working. Clean both of them and you should get the bulb to come back on.
Jun 22, 2011 | Ecoquest Living Air Classic Air Purifier
I have an Alpine ZL-3 and we can't smell the ozone any more. Our air doesn't smell fresh any more. My husband has been cleaning the ozone plate with warm water. Does this have anything to do...
OK- The plate needs brushing with a bristle brush to get the oxidized crystals and grime off it. If you don't, it will not create ozone. I never use water any more, it rusts the plate eventually. Rust also stops the process. I use rubbing alcohol. Cheap and safer than ammonia...MUCH safer. Blow dry. The only bulb is the radio wave ionization indicator bulb, attached to the round antenna-looking thing. You should wipe the ionizers off with alcohol every 6 months too. If they are gunked up they don't work nearly as well. Look up the Living Air Classic manual.
May 25, 2011 | Alpine Air XL-15 Air Purifier
I have a Living Air XL-15 purifier which was taken apart for cleaning and repair. I am now trying to put it back together and have one part that I do not remember where it goes. It is a metal needle-like...
That's a needle-point ionizer, should thread into a little arm/fitting in the fairing forward/front of the fan blades. The red wire (high voltage) should attach to this little arm (probably with a spade terminal). It provides the high-power ionization used to attract particulate air pollutants out of the air.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Nov 10, 2009 | Alpine Air XL-15 Air Purifier
I HAVE THE LIVING AIR XL 15C
Check the fuse. You may need a new one.
Jul 22, 2009 | Alpine Air XL-15 Air Purifier
Have a Living Air XL15 > everything works motor, fan, BUT .....
look through the front grill while its "on" you should see a glow from a neon lamp inside. If its not on chances are the circuit card is dead (should have about 350VDC plate voltage).
I have a used but good board if anyone needs one.
dale.gilchrist@gmail.com
Apr 26, 2009 | Ecoquest Living Air Classic Air Purifier
Ionizer
IONIZERS to not PURIFY indoor air. IONS are either NEGATIVE or POSITIVE. In this case, the NEGATIVE IONS are the 'GOOD GUYS!"
An ionizer will usually put some negative ions into the air while trapping, just like positive/negative magnets would do- SOME of your airborne live contaminates onto a metal plate inside the ionizer. When you pull out the plate with this smorgasborg of contaminates to wipe it, some of them can go airborne again, plus you have a dirty cloth ripe with contaminates on which you should then throw away. You haven't PURIFIED your air-you've just added some negative ions to your air, which will make your air feel light and lively- but still not PURIFIED.
Our SUN AIRE purifiers not only PURIFY indoor air SAFELY and EFFECTIVELY like SUNLIGHT, but one of the side-benefits is that we replenish your NEGATIVE ION balance in your air because of our SUNLIGHT process of purifying your air.
We DO NOT LIVE in our ductwork, therefore, our SUN AIRE purifiers purify your air in your living spaces FIRST and then the allotropic oxygen can be sucked through your ductwork.
POINT-OF-CONTACT is the key to our SUN AIRE purifiers effectiveness. We recommend you place your SUN AIRE purifier as FAR AWAY from your cold air return as possible because we want you to use the allotropic oxygen FIRST, before it's sucked through your ductwork.
Thanks for your question. Please let us know if we may assist you.
www.betterair.com
Oct 04, 2007 | Sun Aire Sun-Aire Air Purifier - Stainless...
Ecoquest Fresh Air Air Purifier Logo
320 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
