Question about Minolta PagePro 1250W Laser Printer
White streaks White vertical streaks (lack of toner) at the same location on every printout. Just refilled the toner cartridge and have shaken it gently side to side.
  • 4,924 Answers
Its not the toner..there is something on the developer that blocks the ink in the same spot ...just open it ,,and clean it all..rollers developer..and all and it will be ok ...
Posted on Apr 28, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Tip
Why i get black streaks on paper in laser printer prints?
there are some possibilities for this problem. i will explain it. 1) First of all check out if the toner is full ,half or near to empty. There is no exact procedure to check the powder left in the toner without opening the toner.but in one toner there comes about near to 1500 copies.if you have got about 1200 to 1300 copies.then its quite possible that the power left is near to empty so the streaks comes on the paper due to less powder left.many times in this case removing and shaking the toner then reinserting the toner again and checking the printout helps. 2) But if you are sure that toner is not empty then other possibility is.in the toner cartridge there is a aluminium drum.its easily seen in the cartridge.once you remove the cartridge. if that drum is got very much used then due to that drum the streaks appear.fox example.if the drum is new the print is very dark.if the drum gets old the print gets very light or with streaks or faded print. 3) Now if drum and toner powder both are proper and still the problem then its the fault in the printer.in your printer there is some toner powder got spilled out on the inner parts from where the printing paper passes.so when the paper passes from the part where the powder is fallen or got collected then the streaks comes.in this case the printer needs internal cleaning and servicing. 4) but in some cases it has been noticed that internal powder of the toner becomes moist and very hard to come out from the toner for printing.in this case either toner needs to be refilled or toner needs to be replaced.you can get the toner refilled from local cartridge refilling store or local stationery shops dealing in cartridge refillings.The cartridge refilling shops also have the same printer for checking the cartridge.so at the refilling shop it will be confirmed whether the fault is in cartridge or printer.
This will help. Thanks .
on Mar 18, 2010 | Office Equipment & Supplies
I am getting black streaks on the printout page. must i refill or replace a new catridge
Dirty print out is basically due to cartridge related issues. Take out the cartridge and clean its drum/ (green roller) with a dry, soft, lint-free cloth. The drum is usually located under a cover. Checkout for any spilled toner inside the printer and clean it also. Print a few pages so that the parts get further cleaned. I think, this would solve the issue.
Moreover, black streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. In this case refilling would not help.
So, it is recommended that you replace the cartridge with a genuine one (not any replacement or refill).
Let me know if any further clarification is required.
Hope it helps! Good Luck!
CreativeTECH
Apr 01, 2011 | Canon LASER SHOT LBP-2900 Printer
Printed document has white streaks. I've replaced all toner cartridges AND replaced the toner waste unit. The streaking occurs when I print or copy but is much worse when I make a copy. Is there a printing...
If you are getting vertical white streaks or faded streaks from the top of the page to the bottom. It sounds like the developer blades in the imaging unit needs to be replaced. It cost around $120 to replace, but after a while it will happen again. This is a common problem with this printer. It can be cleaned by taking the unit apart and cleaning the developer blades, if you are handy. I have posted detail instructions in my tips section. or you can click on this link:
http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300.
Hope this helps.
Jun 13, 2010 | Samsung CLX 3160fn All-In-One Printer
Streaking on left side of page
This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | HP LaserJet 1200 Printer
There is a white vertical streak on pages I print.
You can pull out each cartridge and shake it gently to redistribute the toner. Try a half page test to eliminate the various stages of the image formation. The timing on this is not easy but through trial and error it can be helpful.
Jun 25, 2009 | Cannon MULTIPASS C530 Printer
Samsung CLP-300 poor print quality
black developer on drum worned out,need changing.
May 05, 2009 | Samsung CLP 300 Laser Printer
Hp 4550 vertical line down center of page
From the service manual:
Vertical lines or streaks
 Check for a leak where light might be entering the printer.
 Check for circumferential scars on the photosensitive drum. If scars are present, replace the
drum cartridge if the line goes through all colors.
 Check for circumferential scars on the upper fusing roller. If scars are present, replace the upper
fusing roller if the line goes through all colors.
 Remove the imaging drum and inspect main charger or imaging drum for a contaminant, such as
a fiber, if the line goes through all colors.
CAUTION Do not expose the imaging drum to light for more than 15 seconds. The drum is light sensitive, and
exposure to light can cause permanent damage.
Vertical black lines
 The toner cartridge is defective.
 The toner cartridge is not seated properly.
 The fuser entrance is dirty.
 The fuser has scratches on it.
 This might be a repetitive defect. If so, the lines will repeat at a consistent interval down the page.
 The printer needs to be cleaned.
 There is a problem in the heating element.
Vertical white lines
 If white lines or streaks appear only in the black areas of the printed media, print several
configuration pages to clear the anomaly. If this does not clear the problem, check the sleeve
surface to confirm the defect, then replace the black toner cartridge.
 If white lines appear only in a particular color, try printing several configuration pages to clear the
error. If the error does not clear, check the sleeve surface to confirm the defect, then replace the
defective toner cartridge.
 There is a lack of toner or the toner cartridge is faulty.
 There is dirt in the laser path.
 The fuser is defective.
 A mirror in the laser scanner is dirty.
Apr 07, 2009 | HP Color LaserJet 4550 Printer
Vertical Stripes on printed Page, Shaken Toner, Relatively new Belt (Green thing), cleaned the fuzer wire, cleaned the cleaner roller, has oil.
Depending on the type and model of your printer this could be several things mostly related to the cartridge or drum if you have a separate toner/drum system.. Since you have stated you have shaken the toner, I am assuming you have a laser printer. New belt, has me confused. Green thing leads me to think you are talking about the drum. If so, did you purchase a new toner cartridge or new drum cartridge?
Several components inside the toner or drum cartridge will cause vertical streaks. It depends on where these streaks are occurring and how wide the streaks are. We call these repetitive defects and they can be measured to determine which part is at fault.
Also, if this is a multi-unit machine (print/copy/fax/scan) Check the platen glass or ADf feed unit for white out. That has been a major culprit of vertical streaks on the page.
More specifics about the model of machine and cartridges being used would be helpful in trying to solve this problem for you.
Nov 14, 2008 | Brother Office Equipment & Supplies
CLP-500 vertical streaks & a horizontal line with blotches appearing randomly
I've refilled the toner cartridges a few times now and never had a problem with vertical streaks until recently. I refilled both the cyan and magenta and when I ran the test page I had dark vertical streaks on both sides. I fiddled around cleaning things, running cleaning paper through, changing reset resistors but to no avail so eventually decided to buy a replacement refurbished cyan cartridge since the streaks looked mainly blue and bingo... well almost now I just have very light magenta streaks. The issue is obvious when I compared the old and new cartridge, the replacement toner is a much duller cyan and is of the wrong consistency since once it's been in the printer everything gets covered in it which is why I think it causes the banding to occur. I'm just trying to work out now whether to try refilling the magenta again (v. messy) or just go for another refurbished cartridge (£34).
Jun 12, 2008 | Samsung CLP-500 Laser Printer
Minolta PagePro 1250W Laser Printer Logo
202 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
