Question about Dell M5200n Laser Printer
Dell M5200 printing problem
The printer is on the network and anytime anyone sends a print job you have to go to the printer and press the select button before it will print. The message on the printer says "Change Tray 1 Plain Letter". The paper size setting for tray 1 is universal and it does not give me any other choices.
Soulvisitor
  • 1113 Answers
SOURCE: tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Posted on Dec 18, 2007
printech
  • 159 Answers
SOURCE: Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Posted on Mar 16, 2008
SOURCE: Dell 3100cn Printer will not print
I had to actually change the settings in Microsoft Word to resolve this problem.
If you go to page setup > paper source > there should be lists for "first page" and "other pages".
You can set this to "as per printer settings" and hopefully it should work.
childofsai
Posted on Jul 11, 2008
SOURCE: Dell 3110cn Error 024-695
Had the same problem and found the removable bottom 250 page feeder assembly to be the culprit. Sorry I did not trace the problem to a specific part on the assembly but was lucky enough to have a replacement unit.
Posted on Oct 30, 2008
  • 4 Answers
SOURCE: HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Posted on Sep 18, 2009
Has a code 016-302 and will not work
This error is almost always caused by a corrupt print job or driver. If the machine was working fine it may be as simple as canceling the print job and restarting everything (computer and printer).
Before sending the job to print again, it would be worthwhile to print a test page. If you can, you know the issue is specific to whatever you're trying to print. If you cannot, you know it's a most likely a driver issue.
Other possibilities:
- a recent OS update/upgrade killed the driver. This happened to a fair number of Windows 8 users.
-You're attempting to print from MAC but don't have the printer/driver setup for postscript. Weird but true, even in 2015 PCs and MACS still use different protocols to print to laser printers. (Not an issue for ink jets)
If this is the issue, here are the directions to setup the printer and MAC to work on your network. Notice the printer (wireless or not) should be wired for config-
PRINTER SETUP:
(1) Connect printer to the ethernet port
(2) On the controler of the printer, select menu
(3) with the cursors (down) select Admin Menu, and press ok (the center key)
(4) the text "wired network" will appear. Press OK
(5) Move the coursor down to tcp/ip. Press ok
(6) "get IP address" will appear. Press ok
(7) select panel. Press ok
(8) press "menu" and repeat (1) to (5)
(9) "get IP address" will appear. Move the cursor down to "IP Address". Press OK
(10) with the coursor select write the IP address among the margins of your Router. The Gateway numbers shlould be the same as the ip number of your router. MAsK is always 255.255.255.0
(11) press menu and restart the printer
IN YOUR MAC
(1)Install the 3110cn modules version 2.1.3 Build 5 (usually in the CD, or in DELL site download area)
(2) Open Setup Print Utility and select "Add a printer"
(3) Select IP printer (any of the possibilities you are offered are ok), WRITE THE ADDRESS YOU WROTE IN YOUR PRINTER
(4)In printing using select Dell
You can move the printer to wireless, just keep the IP address the same.
Hope this helps!
Feb 04, 2015 | Dell 3110cn Laser Printer
Develop Ineo+ 360 won't network print
are the paper tray matching the print driver selections what PAPER DRAW settings?? what are the print driver settings?
are the paper weights properly matching? what does the screen say when you send a print job to the copier?
Feb 09, 2014 | Konica Minolta bizhub Office Equipment &...
Can I clear out old print jobs from the menu on the printer?
You can clear print jobs from the computer if they have not started printing yet by double clicking on the printer icon on the taskbar and a list of print jobs appears in the printer window. Select the job you want to cancel and press delete on the keyboard. If the printer is already printing then select 'Cancel' on the printer
Mar 04, 2011 | Dell 3100cn Laser Printer
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
My Dell M5200 printer says 900 Service and RIP Software. I have restarted it several times and checked the menu - all looks o.k., but it won't print. It sounds like it is going to and then the above...
900 RIP error message is a generic error.
In order to understand when it's coming from you have to give more information.
Does it happen when printer is printing a job from a PC, or when it just stands alone idle?
In first case it's probably a job that is generated by the driver which cannot be properly "digested" by the printer. In this case, press select and return on the OP as soon as you get the secondary code message and write it down. Then call Dell support and tell them about it.
If the printer is getting 900 RIP error when being idle, I'd recommend disconencting it from the network for a couple of days to see if the error appears. If it doesn't, then it's something from the network which is causing the problem. Perform the same procedure of collecting the secondary code and contact Dell.
If it still gives 900 RIP error when disconnecting, then it's one of the hardware part which is causing the problem. It might be an option such as a drawer, or a memory unit, or just a main board. try disconnecting one by one the options and see if the problem goes away. Whenever it comes back, collect the secondary codes.
hope it will help, dont forget to thumbs-up
Nov 15, 2010 | Dell M5200n Laser Printer
I just replaced the fuser unit on a dell MFP3115 cn. It now goes into clabration mode and then error to call support
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | Laser 3115cn All-In-One Printer
ERROR 016-720 FOR DELL
The problem correspondent to this error code is: "Error relating to PCL emulation problems occurs."
The solution is: · Press the "Return" buttonto clear the message, cancel the current print job, and conduct the next print job, if any. Press Cancel to cancel the print job.
Mar 30, 2010 | Dell 3100cn Laser Printer
Status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Mar 24, 2009 | Dell M5200n Laser Printer
Printer Problems
Uninstall the printer driver software completely and then download the drivers from the dell website for the Dell 924. Reboot the system and it should be okay.
Dec 02, 2008 | Dell Inspiron B130 Notebook
Dell M5200n Laser Printer Logo
159 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
