Question about LG WM-2277HW Front Load Washer
LE light flashed, now the machine is doing nothing and there are clothes and water inside.
  • LG Master
  • 8,220 Answers
Their could be a problem in the wiring harness. The wiring going to the Hall sensor may be broken. You can test this from the main board connector down to the connector on the hall sensor by checking continuity. There is an intermediate connector down by the motor/hall sensor so you can isolate the problem even more. The problem might be in the short wire harness that connects directly to the motor and hall sensor. It is recommended if you cannot not find the open point of the wire, add a new red wire and integrate it into the harness. WM2277 service manual
Posted on Apr 28, 2010
  • Dan Webster
    Dan Webster Apr 28, 2010
    It might be the red wire or others, vibration does a number on these harnesses,It might be that the connection is loose ot corroded.
  • Dan Webster
    Just add this: you MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
    Nearly all brands of "HE" detergent have incorrect usage instructions.
    The correct amount is as follows:
    HE: (2) Tablespoons Per Wash load
    HE 2X (double concentrated) : (1) Tablespoon
    HE 3X (triple concentrated): (1) Teaspoon
    This reduces/prevents:
    1) Musty Odor
    2) "LE" Error/Interrupted Cycle
    3) L-O-N-G Cycle Times (longer than time displayed)
    4) Insufficient Cleaning Results
    5) Small Water Leaks from the air vent behind the washer or at the
    front door gasket
    6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
    7) Reduced Spin Speeds (laundry not spin-dried effectively)
    Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
    Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
    This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
    The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
    This is a very,very frustrating mistake that gives owners much grief.
    After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
    After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
    It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
    Once a tub has become heavily contaminated--normal methods of performing a TUB CLEAN cycle won't "cut it".
    Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
    Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
    Wait for door to lock.
    Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
    Press the START button two more times--this will enable the tub to tumble.
    After 3 hours--turn "off" the washer.
    Turn the washer back "on".
    Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
    This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent useage.
    After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
    Most digital-controlled front load washers have a software feature that consumers are unaware of.
    If excess suds is detected by the MAIN BOARD (which monitors motor electrical load during rinse & final spin) the "suds kill mode" will be enabled.
    This causes the washer DISPLAY CLOCK to stall.
    The washer makes an attempt to reduce/remove suds--usually a futile attempt--and ends the cycle much longer than was originally shown on the DISPLAY.
  • LG Master
  • 43,501 Answers
This tip will help you with that...
if you can't get it working after it sits and the suds go down then it may be a sensor problem...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
The LE error code keeps flashing why?
LE means level error. The water fill timer timed out before there was enough water in the machine to clean the clothes. Try this:
  1. Turn the hot and cold water supply taps, located at the end of the fill hoses, as far as they will go toward the "Open" position.
  2. Move the washing machine away from the wall, and examine the hot and cold water pipes for kinks, twists or other obstructions.
  3. Unscrew the fill hoses at the washing machine, and inspect the small plastic screens inside for signs of an obstruction.
  4. Check the water pressure in your home; a reading lower than 30 psi might cause the fill times to extend beyond the time the washing machine is programmed to wait. Slow flowing faucets and shower heads are a sign of low water pressure.
  5. Call for service.
Apr 20, 2015 | Maytag Neptune Washing Machines
LE error code has popped up & suddenly the control lock is on, I have pressed the control lock & it counted 3,2,1 & nothing happens, won't unlock & LE is still there
if the door locks and wont unlock
LE error
then your machine still has water in it from the last spin/ wash
i think its a blocked up waste outlet
or the pump is blocked up
you need to check the machine is draining correctly and in a timely manner.,..
or it will fail
you need to fully drain the machine then turn off the mains
wait 5 mins and the door will then open
then check the drainage...
Feb 08, 2015 | Washing Machines
Machine won't work.
Robert. You have a bad water valve OR completely clogged up filter screens on the valve. My past experience with this machine with this type of problem is to replace the valve assembly. part Number W10364988
Apr 09, 2014 | Maytag Bravos Series MVWB300WQ Washer
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
Jan 17, 2013 | LG WD-1080FD Front Load Washer
How do I open a lock LG WM 1832 CW front end washing machine with water and clothes inside?
First you will need to get the water out and really the only way to do that if the unit won't drain it is to open the filter to get the water out and besides that, there is probably a blockage at the filter that is preventing it from draining in the first place. You will need a lot of towels handy or a wet/dry vac at the ready!
Nov 28, 2012 | Washing Machines
Lg 801 3f washing machine. 15 seconds after selecting any cycle a
I had a similar problem i unplugged the machine and left it stand for 8 hours .. it works ok..
Apr 22, 2009 | LG WD-16115FD Front Load Washer
LGWM2277H LE light came on does the motor have a reset button i need to push
Hello momof3611
Welcome,
You said, Your LGWM2277H washer LE light flashes. Troubleshooting guide says overload in motor. Is there a reset on the motor that needs reset or does something else need done. washer was working fine until we put a big load of jeans in to wash. when we checked wash soapy water was in washer and I can't get it to rinse. drum is not turning.
If you overload, with to much clothes the weight will trigger this error your having in most washer.
Take some clothes out.
Then try this:
Unplug the washer for 5 minutes, or if you can't reach the plug, turn the breaker off for 5 minutes and then the system should reset itself!
Let me know.I'm looking right now for any reset code in the repair manual too!
Huuum
Please remember to leave a rating.
Oct 07, 2008 | LG WM2277H Front Load Washer
Problem with LG washing machine Model number wm1480fhd. The machine drum reluctantly turns and in about a few minutes it displays error code LE (flashing).
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 22, 2008 | LG Washing Machines
LE Error??
your handbook should say what "fe" (a fault code) is. it may be not draining. have you checked the filter? on many machines the door can not be opened if water is still inside. try putting the drain hose at floor level into a bucket. otherwise undo the filter and let the water out that way - you may have water everywhere!!
Mar 19, 2007 | LG WD-3274RHD Front Load Washer / Dryer
LG WM-2277HW Front Load Washer Logo
266 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
