Question about Samsung WF203ANW Front Load Washer
Acces water and mold
We are getting mold smell, acces water in seal around door and mold under the seal. What can fix this
  • Samsung Master
  • 43,501 Answers
Here is a tip that I wrote that will help you out there...
http://www.fixya.com/support/r4356970-clean_washer
heatman101
Posted on Apr 28, 2010
Hi, can u show me how to clean my washer to get rid of that moldy smell. there's also mold around the rubber ring around the opening and it feels slimy. Can u please help
First you should reach deep into the front door seal and run your fingers around. There is probably slime in there. You will need to thoroughly clean this with a bleach water mix about 50-50. You might need to pull the seal almost inside out to get in there good. If after scrubbing you still have black in the rubber the mold will come right back, in that case you will need to replace the seal. They are not to hard to replace but a little tricky. Here is a link that should help if you need to replace the seal or if the wire ring pops off when cleaning. Now if all cleans up well or you replaced it be sure to wipe out the seal after each use (deep in there) and /or leave the door open.
If the seal is clean and no mold present and it still smells then you likely have a clogged drain pump filter or pump. Here is a link that should help cleaning a drain pump or try this one for cleaning a ge drain pump filter and this one for cleaning/replacing a Kenmore drain pump
Oct 07, 2010 | Maytag Neptune MAH9500A Front Load Washer
Terrible odor from rubber seal around door. Don't know how to remove seal
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Oct 14, 2009 | GE WSXH208A Front Load Washer
Slimy mold in rubber seal
Hi, Just dry the seal after a wash and leave the door open just a little. Leaving the door cracked will also help with the smell allowing air to circulate through the machine. ALL front loads have this problem with mold and that strange smell.
Sep 05, 2009 | Washing Machines
I have mold on the rubber door seal
This is a comon problem In areas where miosture is high and the tempiture is warm. Try using bleach to clen it off with or you can use super clean to remove it from the rubber. Not touchingthe seal with your hands and clothes will help some to.
Aug 31, 2009 | LG WM-2277HW Front Load Washer
Sour smell coming from washer even when door is
If you have a front loader it will hold water around the seal of the door and after time it will mold and start to smell.
Jun 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
The seal around the door molds. And my clothes
Just send me your $19.95 and I'll share my secret with you!!!
Jun 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer stinks - smells like mold or mildew
You have to kill the mold. To do that mix one cup of clorox liquid bleach into one quart of water and wipe all aroung the rubber. Let it dry and do it again. That will solve your problem
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
Smelly Water Draining
Try getting the new whirlpool affresh washer tablets. They clean the mold and are supposed to make everything in the washer smell better and keep it clean. They are only around 10 bucks and is worth a shot to clean your smelly drain.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
SMELL IN WASHER MODEL #MAH5500BWW AND BLACK MOLD
If you are using a high efficiency front loader than you suffer from the same symptoms that these front loaders typically have. The infamous bad smell and mold.. This is quite common because the front loaders actually seal the wash tub area with a water proof gasket around the door and left closed, the leftover water that gasket will get musty and if left untreated, may develop mold. Home Depot sells AFFRESH tablets that you cycle thru the qwasher about once a month and that usually does the trick.. The less desirable method is to wipe the gasket area with a towel or equivalent and leave the washer door open or partially open to air dry. That's been my experience.. Hope that helps !
Jul 24, 2008 | Maytag Washing Machines
Samsung WF203ANW Front Load Washer Logo
172 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
