Question about Meade LX200GPS Telescope
My New 12? Meade LX200 ACF GPS telescope does not have the two screw?s in the front and the rear of the top of the main optical tube for mounting a dovetail plate to the top center or does it have screws on the right side for mounting the finder scope on ether side like my 10? and 8? scopes had. There is only one screw in the front and back located in the optical tube not the soiled black main back or the soiled black corrector plate ring in the front. Is this the way they are making them now or is this a manufacture mistake, because if this is so you will not even be able to mount Meade?s dovetail mounting plate for all the mounting plates I have researched all have to have two screws that go all the way through the plate and the curved mounting blocks ion to the scopes front and back. If you know anything about this I would like to know because Meade does not even know the anser. Thanks, Laurence
  • 3,186 Answers
You may need to mount just a rail like this one:
http://www.scopestuff.com/ss_mrail.htm
You can call Meade directly and ask:
http://www.meade.com/support/index.html
Posted on Apr 28, 2010
Ime looking for a meade LX200 users manual that comes with the scope
Most Meade manuals are available on their support site: http://www.meade.com/support/manuals/ . Scroll down through the list for the LX200 series manuals (in the Telescopes section). The LX200 manual is listed as the LX-200 Classic. The current link to this manual is http://www.meade.com/downloads/dl/file/id/10/product/0/lx200_classic_manual.pdf .
I hope this helps.
Feb 26, 2017 | Meade Optics
Meade lx200 acf r manual
Many Meade telescope manuals are available here: http://www.meade.com/support/manuals/ . There are several models in the LX200 series. The manual for the LX200-ACF is here: http://www.meade.com/downloads/dl/file/id/11/product/0/lx200_acf_manual.pdf . There is also a model LX200-R; the manual for this model is at http://www.meade.com/downloads/dl/file/id/13/product/0/lx200_r_manual.pdf . I don't see anything about a model with both the ACF and R features in this series.
I hope this helps.
Feb 15, 2017 | Meade Optics
How do I dismantle a Simmons #1210 scope
That is an old Japanese spotter scope. I don't know if I would spend any time trying to fix it Back about a year ago they were selling for $35 dollars or so.
http://www.shopgoodwill.com/auctions/Simmons-Model-1210--25X50-3X-Spotting-Scope-18713486.html
Nov 05, 2014 | Meade Telescopes 12in LX200-ACF OTA...
Procedure to set up a meade 12" LX200R on
It's pretty much all spelled out in the manual. Here:
http://www.meade.com/manuals/TelescopeManuals/LXseries/LX200-ACF_manual.pdf
You should train the drives, and purchase a separate 12 volt power pack with the correct cigarette lighter style power cable. Calibrate motors BEFORE you train the drives with the same power source you will use outside at night.
If this is a GPS model-- and new--- I would execute a RESET on the hand controller-- calibrate motors and train the drives and take the scope outside and get a Satellite link and do a two star automatic alignment.
Make SURE you are centering the correct alignment stars. By the way TRAINING must be done in alt az mode before you put the scope on a wedge-- it cannot be done in polar mode.
Sep 18, 2011 | Meade 12 Inch LX200R f/10 Advanced...
I have an LX200 12",the main circuit board (on base of scope) is blown.Where can I get a new one?
Usually these must come from Meade-- call their customer service department here:
Also you can contact Ron Sampson on the LX200 Yahoo group and he will repair the board if you can remove it and send it to him.
Oct 14, 2010 | Meade LX200GPS Telescope
Meade 14'' LX 200 GPS telescope
If it will not boot-up it's probably the main board. However, I would try a brand new hand controller cable first before I panic.
A fellow by the name of Ron Sampson can repair the hand controller and or the main board circuits. He can be contacted by placing a message for him on the LX200 and the LX90 Yahoo Tech Group.
Hope that helps you. You can send him the hand controller and the main board and he will have a look at it.
Apr 20, 2010 | Meade LX200GPS Telescope
How to replace internal clock in lx90 8"ACF. Meade LX 90 8" ACF with UHTC
Probably just needs a new lithium coin battery - located behind front panel.
Feb 21, 2010 | Meade 8" LX90 LNT Schmidt Cassegrain...
Fist time alignment issues.
Did you calibrate the motors and TRAIN the drives? If not do these first--
During alignment the "alignment" stars may or may NOT be visible in the eyepiece-- CENTER the star. Once you do this with two stars your gotos should be good.
Mar 11, 2009 | Meade Optics
Meade LX200 10" SC Telescope
You have a standard lx200 problem. If you transported your scope a lot with the drives "locked" it damages the RA and DEC drives. If you keep using it, the motors burn out and start drawing too much current. This sometimes blows the motor driver chips on the motherboard which are getting very rare.
The burned out tantalum caps can be replaced with better aluminum electrolytics very cheaply. If the ones in your Autostar burned out, they often burn up the ribbon cable. Also, they often take out U11, a 74LS14 chip on the motherboard. Also a cheap repair. You should take the Autostar apart. If they are burned up, it will be obvious. If your ribbon cable survived, you should replace the caps with aluminum electrolytics. I believe they are 6.8 uf.
So, if you can work an ohmmeter, measure the resistance of the two drive motors with the plugs unplugged. If it is about 14 ohms they are ok. If they are about 3 or 4 ohms, they are toast. Check the worm drives for end play. If there is just a little, you can adjust them. The battery jack on the control panel often breaks the solder joints on the board, causing one of the problems you describe. You can check that and replace/resolder as necessary. The on/off switch often fails and gets intermittent. These are also cheap and can be replaced. I don't repair these for a living but I repair a few of them for friends in the club. These are pretty common problems.
Feb 27, 2008 | Optics
Meade LX200GPS Telescope Logo
161 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Meade Optic Expert? Answer questions, earn points and help others
