Question about KitchenAid 24 in. KUDP02CR Built-in Dishwasher
Dishwasher, KitchenAid KUDP02CRBSO, doesn't run through the clean
My dishwasher, KitchenAid KUDP02CRBSO, doesn't seem to go throught the wash cycle. I've tried "normal, light china, quick clean-up" none of them actually dissolved the dishwashing soap and the dishes are not clean. Is there a reset or could it be something else?
catriver
  • 878 Answers
SOURCE: Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Posted on Mar 08, 2007
mrboo747
  • 24 Answers
SOURCE: Not all of the soap dissolving, some left in dispenser and bottom
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
KUDSO1DLxxxx
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Gary
Posted on Nov 22, 2008
  • 21 Answers
SOURCE: KitchenAid dishwasher soap door won't open
I took the door apart and found the degertent door solinoid looking like it over heated and melted to the cover flap and the insulation. See picture. I can't post pic as the max is 150kb.
I applied power and it only got hot and wouldn't operate.
Next I go to Kitchenaid for a replacement - FREE it should be.
Posted on Apr 09, 2009
  • 10865 Answers
SOURCE: tablet not dissolving, dishes not clean
Hi Trina. I wish I was nearby as I would come over and take care of this problem for you.
There are two possible reasons for the situation as you describe it: 1. Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
2. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
If you are mechanically inclined you can repair either of these but if you are not you will have to hire it done. Now that you know it is one of two problems you can tell the repairman ahead of time and get a price on the repair. Then shop around for the best price.
Posted on May 08, 2009
  • 72 Answers
SOURCE: KitchenAid Dishwasher Model KUDK03CTWH2 Soap Door won't open
IS IN CLEAN FROM POWDER BUID UP
Posted on Jul 01, 2009
KitchenAid KUDL021R dishwasher. Wash cycle goes for 1 hr. 22 mins. before changing to dry cycle. Is this normal?
Depends on setting. That machine uses very little water but does run longer to ensure that dishes are clean. Power usage is quite a bit higher. Try a short cycle setting.
Jan 05, 2012 | KitchenAid Dishwashers
After rinse fill the pump will not start
Hello, is there water in the bottom of your dishwasher? If there is water in bottom. Then try running the dishwasher throught another washing cycle. Now, if there is not water in the bottom of your dishwasher. Then the dishwasher has finished its washing cycle, rinsing the cleaned dishes. GB...stewbison
Sep 17, 2011 | Dishwashers
New dishwasher...The Rinse Aid doesn't seem to be putting out any liquid. (How is it supposed to work?) Plus, dishes don't seem to be coming out as clean as expected. In your opinion what is the...
You won't see any liquid it comes out and gets rinsed off during the last wash cycle.As for detergant I think your best bet is to use the tablets. Like the three and one "Finnish " Hope this helps.
Jun 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
I am using the same quality products to wash the dishes as I have done in the past when I used this machine effectively but now--it doesn't seem to clean the dishes and leaves a film and food residue. My...
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
See part 1 on this parts list and diagram. http://www.partselect.com/MultiModels.aspx?ModelNum=kuds03ft&searchTerm=img_6G53WSWK&RefineSearch=0&imgMfg=Whirlpool
May 17, 2010 | KitchenAid Architect? II S SERIES KUDS03FT...
I have grit on my dishes after the wash cycle completes, jet dry seems to be working? Dishwasher is draining.
use only cascade complete cleaner, clean unit remove basket motor cover chopper cover clean and vac out trash washer all screens increase water temp. to 130 degrees if no children in home if children in home not over 125 degrees temp. monthly run dishwasher cleaner product through waser cost around 10 $ at lowes
Feb 05, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Water does not seem to pump through the jets to wash the dishes. fills and drains fine.
Go to the store and get some jet-wash. I think that is what its called, but its in the same area as the dish detergent and it is for cleaning the dishwasher. Run a cycle through and this may help.
Sep 26, 2009 | KitchenAid 24 in. KUDP01IL - Multiple...
The wash cycles go on for 2 - 4 hours.
I know is sounds strange, but on a typical Kitchen Aid dishwasher, cycles can go longer because the the dishwasher is waiting for the water be raised to the proper temperature, especially during a hot rinse cycle.
Checking that the heating element is working would be the first thing to check.
If the heating element is working, the probable cause is a failed console (which controls the logic/programming of the dishwasher.)
Good Luck!
Apr 03, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Nov 16, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
Kitchenaid double-drawer dishwasher will not start
i just installed a used dishwasher. It filled up with water then stopped. The lights are still on as far as the cycles but nothing is happening. I did the factory diagnostic test and the service diagnostic test, not sure how long each test was supposed to take because after it seemed to go through each cycle by the lights on the front nothing else happened. I waited over 30minutes because I didn't know how long this was going to take. When all the lights on the front went out I tried to turn it on like to run a wash cycle and nothing is happening and the bottom is still full on water. HELP!!
Oct 24, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
KitchenAid 24 in. KUDP02CR Built-in Dishwasher Logo
57 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
