Question about Konica Minolta bizhub C450P Laser Printer
I have a bizhub C450 and i am getting a yellow line at the top of my printed page and also 2 pink/red dots in the middle of the page. How can i stop this?
    Sniper:
  • 108 Answers
The yellow and magenta image units may be the problem. Yellow may have worn out on one end causing the yellow line. If the pink dots show up on every page but move around from page to page, there may be damage to the magenta image unit. You can remove the image units from the machine and look at the drums (long green cylinders), this should be shiny and clean. If not, you may need to replace.
Posted on May 13, 2010
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
My bizhub c451 suddenly started printing and copying nothing but colourful dots and lines all over the page. even with a test page i can only see a windows logo and all dots and lines, no text. even
Make sure the ink cartridge is full or new. Get to the "Maintenance" page and try an alinement. (The ink dries and will clog the jets if not used often enough.)
Jan 01, 2015 | Konica Minolta Bizhub C451...
Bizhub C450 strange printing problem. Green data LED is flashing but nothing happens.
Did you try to change the IP address of MFP. Please change IP address of MFP and connect the PC you are sure not giving any problem. If its works fine then connect rest of the remaining PC's
Nov 15, 2014 | Konica Minolta bizhub C450P Laser Printer
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
How to change a Developer for Konica Minolta BizHub 250 Laser Printer, ?
konica minolta c450 how i get test page cyan, magenta, yellow, black separate pages
Jan 07, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
DOTS pattern and WHITE LINE along the page
The Problem is your Copy Print Module it has a scracht on it if you replace the module it will desapear the dots and lines.
Nov 26, 2009 | Xerox DocuColor 12 Printer
The Bizhub C351 is printing the colours wrong the red and yellow comes out pink and a yellow smudge line prints on the top of every page how do i fix it?
print off halftone for each colour
utility/counter,metercount,stop.0.0.stop.0.1test mode.halftone.cmyk start.this will print off each colur, the "failed" one will be easy to see
Jun 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub C450P Laser Printer Logo
640 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
