Question about Canon PIXMA iP1800 InkJet Photo Printer
Not printing when i select print the printer starts but the paper is getting chewed up as its going through the printer
  • amishgirl Mar 31, 2008
    I go to print on the Canon PIXMA iP1800 as well, and the paper gets chewed up also. I think maybe there must be something stuck in there, but I haven't the foggiest of how you're supposed to un-jam it, because the problem seems to be out of reach.
Try cleaning the rollers:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=184&modelid=14991#SupportDetailAct
Posted on Apr 07, 2008
Epsom stylus sx610fw insists there is a paper jam - none to see, but will chew up ordinary paper when working. is there any way to open it up more to look for torn paper that could be registering as a
Yes it can be repaired, but it will most likely take a sensor to do it, this is a common issue. I think the way it works is it senses the force required to turn the roller, if the sensor or the chip it sends its signal to is defective a false paper jam is triggered and the printer stops printing. The problem here is with printers being so cheap to buy why not just replace it. The last time i got a printer it was free with the rebate, and it was a Canon "all in one" that was far better than the HP it replaced. Your decision.
Jan 19, 2012 | Office Equipment & Supplies
Printer chews up paper when it is printing. Can this be rectified?
Step 1: Take half test page check is there any symptom what you are getting? If yes replace with another cartridge check...( How to take half test: Give fully mattered print command while printing switch off the power remove cartridge take out printed paper check the printed matter on page) Step 2: If found cartridge is OK, 95% suspected Teflon sleeve( a cylindrical sleeve which is coated grey colored Teflon), replace it if available if not replace with new fuser assembly..
Nov 18, 2011 | HP LaserJet 3015 All-In-One Printer
How to print legal paper in 1210 printer
canon lbp 1210 printers
has a probleam a legal page setting
plese answerer legal page setting
May 11, 2010 | Canon LASER SHOT LBP-3000 Printer
Printing on premium glossy EPSON paper. It gets to the last inch and the edges are chewed and the printing is awful. It's just in that part on that paper. Everything else prints fine!
that sounds like a machine defect... if its new... go get it replaced... if its not... call a service tech... thats not an issue that you can fix...
Dec 21, 2009 | Office Equipment & Supplies
HP Laserjet 4plus chewing us paper
This is most likely cased by a dirty paper feed path so it will need cleaning and blowing out. Make sure that all the internal paper guides and separators are free of obstruction. Make sure that the fuser area is clean that the internal paper guides are ll in place and operate freely. Also clean it with a vacuum with a soft haired brush tool to avoid any damage. Also fan the paper before using it and do not overload the print paper tray. Also check that the pick up rollers are not work or contaminated with dirt / debris etc. Also make sure that the print tray is not overloaded and make sure that the paper is not to tightly held by the tray side guide.
Sep 30, 2009 | HP LaserJet 4 plus Printer
How do I change the default paper size from Letter to A4 in my HP Officejet Pro 8500 Wireless?
Don't set by using the "Print" option.
Go to [Start]
[Printers and Faxes]
right-click on the HP Printer entry
! Don't select "Printing Preferences"! from there
Select [properties]
Select [Advanced] tab
Select [Printing Defaults]
[Advanced}
(I know, the screen looks the same, but it functions differently this way)
Change paper size to "Letter"
[OK, OK, OK]
*done*
Sep 25, 2009 | Office Equipment & Supplies
Printing to 4 x 6 paper
Hello oyam26,
For any paper mismatch issue, first thing you do is try to set the paper type to plain. This will fix the issue in most of the cases.
gud luck
Nov 01, 2008 | HP Photosmart C4280 Aio Printer
Legal size paper on LBP-1210
For printing the Legal Size (8.5′x14′) in cannon LBP-1210, follow the instruction:
Step 1- Go to start
Step 2-printer and faxs
Step 3-select printer(Canon LASER SHOT LBP-1210)
Step 4-go to file
Step 5-select Server properties
Step 6-select creat new form (for legal page)
Step 7-give form name legal 1
Step 8-give paper size width 8.50in, hight 14.00
Step 9-give paper margin top 0.30in, left 0.30in, right 0.30in, bottom 0.30in
Step 10-select save form Step 11-then select advanced
Step 12-select informational notifications for local printers
Step 13-select apply
Step 14-then close
Step 15-select Canon Laser Shot LBP-1210
Step 16-select printer
Step 17-select properties
Step 18-select-select forms
Step 19-select change forms
Step 20-select legal 1
Step 21-select OK
Step 22-select apply
Step 23-select OK
Remember: 1 U need to set paper size (8.5′ x 14′) manually in the word documents and befor printing you need to set in printer properties “Legal 1′ for printing. Print preview may not show the whole page but the printer will print the whole page.
All the best.
PARVEZ [ info(at)parvezbd(dot)com ]
Jun 22, 2008 | Video Cameras
R265 chewing paper
Suggest a small piece of paper or dirt is stuck in the print path near the print heads. Use vacuum tube to **** out any dirt
Mar 19, 2008 | Epson Stylus R265 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
48 people viewed this question
old marine
old marine
