Question about Canon imageCLASS MF8170C All-In-One Laser Printer
System error e021 - Canon imageCLASS MF8170C All-In-One Laser Printer
  • Mike davis Oct 02, 2013
    Mike_MCS's solution worked. I have been unplugging/plugging this thing for months. The toner cartridges weren't rotating on their carousel, and why this would resolve it is a mystery to me. I just spent an hour making copies for delayed correspondence. Thank you Mike..
In my office this error message E021 came up today,too. So I called customer service to solve this problem.Operator advised me to shut off the power suply with pull out source plug about 5 minutes,after that, put plug in socket again.
If error message E021 still comes up,it needs repair(fix) by cannon support because of breakdown.
gambatte!!(^^)/
Posted on Oct 07, 2010
This is really the answer after days of searching and testing.
Remove the drum cartridge. Just below it there is a plate with two screws, remove it. under that there is a roller about 3"-4" with. Sand it! Really! The error is caused by the paper not arriving at the next sensor in time because the paper slipping in the rollers. They get glazed (common with the old HP4s) use 400 grit paper and scuff it side to side to break the glaze.
Also use the HP2500 service manual easily available on the net. It's the same engine (bottom half of the Canon).
Posted on May 27, 2012
    Guru:
  • 571 Answers
I had a similar problem come up, and the best advice I can give is to reseat the various parts (drum and toners). I am not sure exactly how, but the printer functioned again without having to replace any parts.
Posted on Apr 28, 2010
2 Suggested Answers
bilua
  • 102 Answers
SOURCE: I am getting a System Error E021, what does this
In my home office this error message came up, E021. I opened the Printer cover, closed it, unplugged and replugged and got a Paper Jam message. I removed the paper jam and did the cover/plug routine. Now I have a message CHECK PRINTER OPEN AND CLOSE COVER. But I can't find anything wrong! I have been searcing for an explanation of the error message online, but haven't found that either. my printer may be infested by aliens.
The best advice I can give is to reseat the various parts (drum and toners).
Thanks
Posted on Aug 17, 2009
Solution for canon 1180 clc error code E021 0401
Most Probably Your Black Color Developing asssembly is overloded with excess black toner and might not be rotating. Check it
Oct 15, 2011 | Canon CLC 1180 Copier
E021 error
hello,
this is error for the faulty developing rotary mechanism ( the mechanism that rotates the toner units ).
As remedy, you can try to check for broken parts, check if the motor turns the rotary assy, ... or call service!
Hope that helps!
Apr 27, 2011 | Canon imageCLASS MF8170C All-In-One Laser...
Please I have canon copier IR3170C but it has been giving me this error code E000021 - 0001 any time i on the machine and it is being boot. Please help me out. thanks
getfile.asp?rid=1258 May 8, 2006 getfile.asp?rid=3215 Product : imageRUNNER C3100 / C3170 Title : E021-000x Error Code Error :
E021-000x Error Code: Developing rotary does not rotate and abnormal noise comes from motor.
E021 can be displayed when an error occurs in the developing rotary.
The detail codes are:
0001: The developing rotary home position cannot be detected.
0002: The intervals of flag detection during rotation is too short or long.
0003: The sensor does not detect the flag when the developing rotary stops at development point
As a result of inspection, it was found that the DC Controller PCB was unable to control the motor because it was faulty.
Workaround :
1. Check whether or not the developing rotary receives any physical load.
Rotate the developing rotary in a counterclockwise direction by hand to see whether it rotates smoothly. If any abnormality is found, eliminate the root cause. No problem is found, go to the Step 2.
2. Make sure that the connectors are securely fitted between J313 on the DC Controller PCB and the Rotary Motor (M8) or there is no pinched wire. No problem is found, go to the Step 3.
3. Replace the DC Controller PCB with a new one. If the symptom still recurs, go to the Step 4.
4. Replace the Rotary Motor with a new one.
DC Controller PCB: FG3-3846-030
Rotary Motor: FM2-0080-000 Canon USA, Inc. Systems & Technical Support Division
Jan 20, 2011 | Canon Office Equipment & Supplies
Canon iR 3100 Problem Error Code E 20081
HELOW SIR UR PROBLAM E 20081 IT IS A RONG CODE?SO U WILL WRITE THE CURRECT CODE SUPPOSE EXAMPLE E021-0001
Nov 12, 2010 | Canon iRC3100 Printer
Error code E021
I think that E021 is caused by the rotating unit not rotating or the sensor that detects the rotation is not working. check to make sure that all the colour units are in correctly and not stopping the rotation or maybe something else obstructing it.
Oct 15, 2010 | Canon LBP 2410 Laser Printer
How do i fix EO21 error code on a CanonLBP 2410 and what is an EO 21 error code Many thanks
E021 = DEVELOPING ROTARY MOTOR FAULT
Please check the connector of the developing rotary motor.
Maybe you will need to replace the DEVELOPING ROTARY MOTOR or DC CONTROLLER PCB ASSY.
Apr 17, 2010 | Canon imageCLASS MF8170C All-In-One Laser...
I am getting a System Error E021, what does this mean?
Thanks
Aug 17, 2009 | Canon imageCLASS MF8170C All-In-One Laser...
Canon C2100 copier going into a E021 error code and display says drum yellow
Make sure you have the developers correctly installed ... E021 means you have a rotary error.....
Jun 27, 2008 | Office Equipment & Supplies
Service Call e021
I believe that is a dirty sensor error message.
E021. Transfer Belt Cleaner Contanct/ Rease Problem.
Cleaner pressure flapper solenoid, Belt cleaner detect sensor, engine PCB.
Feb 23, 2008 | Canon imageCLASS C2100 Laser Printer
Service require E008
E008. Is a Main Motor Problem.
Main Motor, Engine, power unit
Make sure inside on unit, has no toner spilled in it.
Feb 14, 2008 | Epson AcuLaser C1900 Printer
Canon imageCLASS MF8170C All-In-One Laser Printer Logo
1,526 people viewed this question
old marine
old marine
