Removing printer drivers options
How do i completely remove a driver (and its list of printers) from the "install printer" option in the wizard?
  • Jamie Sta Mar 24, 2008
    Thank you, I guess I need to be more clear. When installing a printer, the wizard eventually comes to a selection of printer mfg'er and a list of printers that mfg'er supports. It is those printers that I wish to erase, not an actually installed printer.
    Genius:
  • 1,913 Answers
HI
SIMPLY DELETE IT FROM IT.
THEN SEE IN ADDR EMOVE PROGRAM IF THERE ARE ANTY PRINTER SETUP REMOV IT
Posted on Mar 24, 2008
HP laser jet 1522nf mfp ( firm ware corrupt ready 2 download)
Perform the following troubleshooting in the order listed:
  1. Turn off the printer, with the communication cable still attached.
  2. Clear the print spooler by doing the following:
    1. Go to Start then choose Run .
    2. Type net stop spooler , and press Enter .
    3. The Windows XP spool directory is located at: C:\WINDOWS\SYSTEM32\SPOOL\PRINTER ; Delete every file within this folder.
    4. Go to Start , then Run , and type net start spooler , and press Enter .
  3. Manually delete and reinstall the driver:
  4. To uninstall printer driver, refer to the following steps:
    1. Open Printers folder and right click the driver that you wish to delete.
    2. Within the menu, select Remove .
    3. For the confirmation message displayed, click Yes .
    4. Right click the Printer Folder and select Server Property .
    5. Click Drivers tab, and select the driver for deletion. Click Remove .
    6. For the confirmation message for the deletion, click Yes .
  5. Install the printer driver manually as follows:
    1. Select the Printers and Faxes option from the Start menu.
    2. Click "Add a printer" then, on the resulting "Add Printer Wizard" dialog, click Next.
    3. Ensure the option "Local printer attached to this computer" is selected. Untick the checkbox "Automatically detect and install my Plug and Play printer". Click Next.
    4. Ensure that the option "Use the following port:" is selected then select the appropriate port from the drop-down choice box. When choosing port, use one of Virtual Printer Ports for USB to which is your printer connected to. Click Next.
    5. Click the "Have Disk..." button. On the "Install From Disk" dialog, click Browse... then navigate to the appropriate directory to which the software/driver extracted.
    6. Select an inf file then click the "Open" button. Click OK on the "Install From Disk" dialog.
    The Add Printer Wizard will start to copy driver files to the PC.
  6. Run the firmware upgrade with the printer turned off so that the printer accepts the firmware only after the entire file is spooled.
  7. In the firmware update program's window, choose your printer (manually installed) and press Send Firmware button, and wait for the firmware to be spooled completely.
  8. Power-on the printer.
  9. During the printer firmware update, the liquid crystal display (LCD) on the printer control panel will display Printing Document and will change to Erasing . After a short while, the LCD display will change to Programming . After a short while, the LCD will display complete The Ready LED on the printer will start flashing. The printer will automatically power off and then back on to reboot, and will make noises similar to that of a power-on operation.
May 11, 2010 | HP LaserJet M1522nf Multifunction Printer...
Why is it that the scanner on my hp office jet says no scan options It says to troubleshoot. then press ok.
For normal scanning you can choose the option of Scanners and Cameras wizard in control panel. But it is better if you have software disk of printer because it contains more option.
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | HP Officejet 5610 All-In-One InkJet...
Cannot scan any documents to computer. Refer to
Thanks.
Have a good day.
Feb 20, 2010 | HP PHOTOSMART PLUS B209A All-In-One...
I disconnected my HP Deskjet 3900 series for awhile and had some work done on my computer now I am trying to install it again and I cannot find my disk, is there anyway I can reinstall it without the disk.
Yes you can
Click on Add a Printer wizard from the control panel - printer and faxes folder
Select the Options as Local Printer and Uncheck the Options which says automatically detect my device- Click on next
Use the First Option -- use the following port and select the USB VIRTUAL OO1 Port or something like that
Click on next
You get the Manufacturer page
Select HP and on the Printers list select HP DESKJET 990c Printer and then click on next and complete the installation
u can print with this generic drivers which are there in your system without even installing the Printer driver
Oct 20, 2009 | HP Office Equipment & Supplies
Need to install on my computer lexmark x125
If you have the disk the best option is using the disk to install the printer
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then ifyou get in troubles, followthe instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:someprinterdoes not work on Vista, if you do not find any driver downloadfor Vista on your model page, that means your model is not Vistacompatible.
Oct 24, 2008 | Lexmark Office Equipment & Supplies
Scanning
No, there is no need of installaing any software.
Try to install the printer oce again using the following steps, it will definitely work:
  1. Click Start and then Printers and Faxes .
  2. Follow the steps in the Add Printer Wizard to add the print driver. Select HP from the list of manufacturers and then locate the all-in-one printer driver or fax driver (if your model can send and receive faxes from the computer) from the list of printers. The models will probably be near the bottom of the list.
  3. The printer port should be selected as the USB001 (Virtual printer port for USB) or the DOT4_00[x] HP (all-in-one series) printer port if the first port is not an option.
  4. Select the option to Keep existing driver when that choice displays.
  5. If prompted for a missing file, have the installation search for the file on the All-in-One CD-ROM.
  6. The installation should complete and a Congratulations screen should appear.
This will surely help u.
Thank u.
May 25, 2008 | HP DeskJet F380 All-In-One Printer
How do I like
Stepts to install Printer Software:
Thank u for the question.
Apr 29, 2008 | HP DeskJet F380 All-In-One Printer
Printer won't work
Try to install the printer again on ur computer. Try these steps to install the software on ur computer again. 8 out of 10 times, it works, so try this:
Thank u.
Apr 28, 2008 | HP DeskJet F380 All-In-One Printer
MP110/130 drivers for vista
You can download the drivers from Canon. Click on driver downloads and pick the Vista driver.
MP110
MP130
Jan 24, 2008 | Canon PIXMA MP130 All-In-One InkJet...
98 people viewed this question
jasbo
jasbo
