Question about Tefal TL6802002 Toaster
Where to buy the thin line toasters - Tefal TL6802002 Toaster
How to clean the inside of a toaster
Slide the bottom door under the toaster and it will open, I would suggest doing it over a waste can or sink. You can take a small thin brush and get the crumbs out. Then your toaster will be back in working order. Crumbs that are stuck in the bottom of the tray is what causes it to burn the toast.
Nov 21, 2013 | Dualit CTS4E 4-Slice Toaster
Spring on dpp2 toaster
The spring went on our dpp2 dualit toaster, when this happens the toaster stays On permanently. I would recomend buying a safer toaster rather than trying to fix this dangerously designed toaster.
Oct 07, 2013 | Dualit Kitchen Appliances - Others
Bread stuck in the bottom of a cusinart rbt 380c toaster
unplug the toaster and either let the bread dry out to the point it will crumble and be released, or use thin tongs/knife/needle-nose pliers to carefully remove the bread.
Dec 31, 2012 | Kitchen Appliances - Others
Where can I find the parts in Ontario for Dualit Toasters? I know I need to replace at least one burner and was hoping to find in Ontario rather than having to order from UK
We believe the best option is from ebay, Dont worry the distance they ship the elements in and envelope since they are thin and light so even uk is not costly and arrive fast.
Apr 19, 2011 | Dualit 40352 4Slice Toaster
Black and /decker toaster model T3550. The outside elements work but the middle ones do not. so only one side of the bread is toaster.And the handle must be held down the whole time to toast
The heating element wire is really thin and there is a great posssibilty of breakage. There is also a spring switch in which the lever locks when toasting. needs replacement.
May 11, 2009 | Black & Decker Toast-It-All Plus T3550...
Dualit 20247 2-slice crumb tray needed
At the Dualit Service Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Jan 18, 2008 | Dualit 20247 2-Slice Toaster
Wanting to buy a toaster
Did you try Wal-Mart... or a good hardware store? They were selling this kind of toaster just a few years ago because it was some kind of anniversary. I have a new one and one that's over 30 years old (and that's pretty good for a small appliance!)
Dec 23, 2007 | Toastess TT-200 Turnover Toaster
Repair manual for T2020WT
Hey annaway, all toasters are repairable, but that only determines what the problem is, If you google teh type of toaster, under the following
1. www.google.ca
2. type repair manual
3. toasters
4. look for your brand name
Dec 01, 2007 | Toastmaster T2020WT 2-Slice Toaster
Tefal TL6802002 Toaster Logo
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Gerry Harvey
Gerry Harvey
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
