Question about Microsoft Office 2003 Basic Edition English (s55-00066) for PC
Creating tables - Microsoft Office 2003 Basic Edition English (s55-00066) for PC
    Guru:
  • 290 Answers
This is how to create a table
  1. Click where you want to insert a table.on you work sheet
  2. click On the Insert tab, in the Tables group, click Table,
  3. Replace the data in the template with the data that you want.i.e the number of rows and columns you want
that is it
Posted on Apr 28, 2010
How can I create a bulleted two column list within a resume document?
This requires you to create a table. Look for a Table menu or menu item in the Format menu. You'll need to tell it you want two columns and five rows in the table. After you've inserted the items you can then highlight everything in the table and right click to choose bullets from bullets and numbering from the format option.
Oct 04, 2015 | Computers & Internet
Having troube with my FOREIGN KEYs on two tables.
I suggest you visit this website you will get the solution, I tried and it worked.
http://bit.ly/1bUVmuW
Nov 25, 2013 | Computers & Internet
How to make a 7 row and a 7 coloum in a spreadsheet
Creating a table in Microsoft Excel 2007 allows you to work with that data independently of the rest of the worksheet. First you must define your table, though, which you can do either from scratch or from data already in the worksheet. The process is a simple one. Read on to learn how to define a table in Excel 2007
  • Start off by doing one of the following: Select the range of cells that you want to make into a table within your worksheet then proceed to Step 2 OR Start immediately with Step 2.
  • Click on the "Insert" tab at the top of the document.
  • Find the "Tables" group, then click on "Table." The "Create Table" dialog box will appear.
  • Type in a range for your table if you did not select a range in Step 1. If you did already select a range then that range will automatically appear in the dialog box.
  • Check the "My Table Has Headers" box if the data set you selected already contains the headers you want to use. If you don't check this box, the table will display default header names, which you can then go in and change.
  • Hit the "OK" button at the bottom of the Create Table dialog box to create your table.
  • Thanks for choosing Fixya............ Sandeep
    Mar 18, 2011 | Computers & Internet
    Can u plz mail me tha easiest way to use Ms Access, like Creating relationship, with the table, creating form, query etc.
    In general you initiate this process by pressing the "Relationships" button on the MS Access toolbar. It is the button with three small boxes arranged in a triangle shape.
    When it first comes up it will give you the option to add tables. You can add any set of tables including the possibility of adding one table more than once (you would do this if you wanted to create a relationship between fields in the same table).
    Once you see the tables you're interested in, you simply drag the field from one table over a field in another table. The fields should be those that will define the relationship. Once done, you should see an Edit Relationships window. You can get back to the Edit Relationships window later by double clicking the line in the relationships window.
    MS Access does a good job of figuring out the relationship type. For example, if you match a field in one table, that is not a key, with a primary key in another table, Access will make this a Many-to-One relationship.
    This can become a very deep subject. Hope this at least gets you in the right direction.
    Dec 18, 2010 | Microsoft Computers & Internet
    When I go to TABLE, the Y part won't show up?
    Press [2nd][+] (MEM)
    Select [4:ClrAllLists]
    Press [ENTER]
    Now you are ready to create a table from the expression of a function.
    Press [Y=] to open the function editor.
    On line Y1= enter the expression of the function
    Press [2nd][GRAPH] (TABLE) to create your table
    You will see two lists X, and Y1.
    If your table is not generated from the expression of a function, but from raw experimental data, you use the [STAT][1:Edit] key sequence to open the Lists L1 to L6 and populate the two you want.
    Mar 12, 2010 | Texas Instruments TI-84 Plus Calculator
    Application and example of relationship in access
    Relationships
    After you've set up multiple tables in your Microsoft Access database, you need a way of telling Access how to bring that information back together again. The first step in this process is to define relationships between your tables. After you've done that, you can create queries, forms, and reports to display information from several tables at once.
    A relationship works by matching data in key fields - usually a field with the same name in both tables. In most cases, these matching fields are the primary key from one table, which provides a unique identifier for each record, and a foreign key in the other table. For example, teachers can be associated with the students they're responsible for by creating a relationship between the teacher's table and the student's table using the TeacherID fields.
    Having met the criteria above, follow these steps for creating relationships between tables.
    1. In the database window view, at the top, click on Tools ---> Relationships
    2. Select the Tables you want to link together, by clicking on them and selecting the Add Button
    3. Drag the primary key of the Parent table (Teacher in this case), and drop it into the same field in the Child table (Student in this case.)
    4. Select Enforce Referential Integrity
      • When the Cascade Update Related Fields check box is set, changing a primary key value in the primary table automatically updates the matching value in all related records.
      • When the Cascade Delete Related Records check box is set, deleting a record in the primary table deletes any related records in the related table
    5. Click Create and Save the Relationship
    Apr 09, 2009 | Microsoft Computers & Internet
    Data From Table Auto Fill
    You need to create 2 tables. Create one table with just the Center Number, County and Center fields, using the Center Number as the primary key, lets call this table Center. Then create the other table with all the other fields you need, lets just call it the Main table for now.
    Then create a relationship between the Center table and the Main table using the Center Number for the relationship. The relationship should be a One-to-Many from the Main to teh Center table. When creating the form, you take the fields from both tables. When you input the Center Number, the County and Center should be automatically filled in.
    Apr 08, 2009 | Microsoft Office Access 2003 (077-02871)...
    No available fields in form wizard
    If you select the correct table from the drop down, the fields should be shown in the box. or keep the table open and try creating form. or create a blank form and on the right side you will get tables and fields, you can just drag and drop required fields
    Feb 10, 2009 | Microsoft Office Professional 2007 Full...
    Creating a table in Ms-Access
    Have you tried to name the table Tiny_tots? it might make it work. Sometimes programs are funny about letting you have spaces in the name.
    Oct 04, 2008 | Microsoft Office Standard for PC
    How to create program in delphi
    i wants to create form for data input
    with the condition
    Mar 13, 2008 | Computers & Internet
    Microsoft Office 2003 Basic Edition English (s55-00066) for PC Logo
    80 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
