Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
When machine is running the brush does not turn
When vacumn is running the brush does not turn except when pushed
  • 50 Answers
You need a new belt. In order to change it, turn the machine compleatly upside down and place the head on a counter, handle on the floor.
There is a L shaped base plate to remove that has 5 screws in. Once the base plate is off, you see the brush roller and a silver shaft directly back from where the belt would ride. Remove the brush roller, place the new belt, Dirt Devil Style 5 ( see link below ) on to the shaft. Then insert the brush roller, so the belt is on the raised carved out section of the brush roller. Grab the brush roller at each end and stretch it till you are able to put the brush roller back into the base. Turn the brush roller backwards 3 compleat turns and the same forward to seat the belt.
Replace the base plate and you're done.
Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001 - Free Shipping Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001
Cost $ 8.00
Posted on Apr 28, 2010
Rotary brush does not spin when using on carpet
The brushes are usually belt-driven. You may need to replace the belt.
Dec 16, 2017 | Dyson DC29 Animal Vacuum
The belt is still good but the brush is not spinning. The motor sounds fine. what would cause that?
Have you checked the brush seats???? Where the brush sits in the vacumn head,...is it clean and not full of rubbish/ debris? I mean,...is it free and you can turn the brush by hand freely?
Dec 12, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The vacumn is running but the beater brush is not turning.
This is from the Dyson website. It gives step by step guide for replacing belt and or beater bar.
http://www.dysonmedic.com/DC07%20Folder/DC07%20Belt%20&%20Brushbar%20change.html
Good luck.
Aug 10, 2009 | Dyson Vacuums
The vacumn runs but brush dose not turn belt is good. It's a dyson 110 us c 10417
Now is it air driven or belt driven? It could be the belt that's not turning the brush. Check if the belt is loose or is broken. If it's air driven, then check and see how the condition of the bearings are. If it doesn't roll smoothly then you need to replace the brush roller. If it does roll smoothly then check if there's a blockage in the line.
Jul 28, 2009 | Vacuums
Odd noise coming from central vacumn cleaner
The rattling noise, will likely increase when the head is flipped upside down. Generally means you have a stone caught in the belt or a blown or stripped tooth on the belt.
If you gently squeeze the outside edges of the light housing it will pop off to reveal two screws to remove the lid. Check for other screws at the neck of the power head. Once removed your belt and brush will be visible. Remove the brush roll with end caps and flip the belt inside out rolling it between your finger , look for cracks or a floppy or missing tooth. Replace if any sign of wear.
Inspect the dust caps on your brush. There is a washer under each, likely buried in lint. Do not lose as these are a spacers for each end of the brush. Clean shaft and lube with WD40. Spray caps with the same. vacuum loose grit and dust bunnies away from motor and reinstall, your red button must align with the lid when replacing
Jul 19, 2009 | Hayden Industries SuperVac 2400 Central...
Brush will not turn
The most common problem is the handle isn't screwed in tight enough when the machine was assembled. Try tightening it down all the was and the electrical connections will then seat properly.
Jul 05, 2009 | Bissell Healthy Home HEPA Bagless Upright...
My dyson vacumn is hard to push on carpeting. How do i fix it?
This happens when the bristles in the brush roll get worn down too short. Put in a new brush roll and the machine will pull itself over the carpet, so you hardly have to push at all.
May 19, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Power brush will only operate on push stroke
If the motor runs, the circuit breaker is working. If it only works on the push stroke, you probably have burnt contacts where the handle and/or wands and/or power head connect. When you push, the contacts are pressed together; when you pull, they are separated and the motor loses power. The only solution is to replace the connector parts.
May 06, 2009 | Vacuums
Fantom twister wont work light is on
When you say, "just stopped", did the MOTOR stop operating and there's no sound from it at all? Or, is the motor still working or sounds like it does, and it stopped vacumning?
If the MOTOR stopped, most likely there is a short somewhere in the connection at the motor. Think 'repair shop'.
If the motor still runs and there's no VACUMN ACTION, think Roller Brush which operates by virtue of a rubber belt. Turn the machine on its side and turn it ON, keeping FINGERS !AWAY! from the roller area. If the Roller Brush is not moving it may be that the belt has slipped off or is broken or simply too loose to turn the Roller. Also sometimes debris such as strings, long hair, carpet strands/fibers will become wrapped around the roller especially next to the roller bearing/brace points, to the point of binding so tightly that the roller will no longer be able to actually roll which would now prevent it from 'Vacumning' or sweeping dirt and such up into the vortex of the vacumn chamber. In which case, !!UNPLUG!! the machine, use small scissors to cut away the material wrapped around the roller paying particular attention to the brace point areas.
Apr 20, 2009 | Fantom Vacums FM780 Twister 700LX Upright...
No vacumn action
Is the roller turning, if not you may need a new belt and/or brush roll. Did you check the inlet by the brush roll?
Feb 09, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
1,290 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
