Question about Kenmore HE2 Plus Front Load Washer
F21 came on the machine. Unplugged for 30 mins as found on here. Appears to have been reset but now it will not start? Makes the door lock clicking noise, all the lights are on but nothing
  • 5,911 Answers
Although you unplugged and reset the washer CCU, you may still have something wrong that originally generated your error code. If the condition still exists, the washer will not begin or finish a wash cycle. You may want to go back and investigate the cause of the error code.
"F21" is a Long Drain error code which is usually an indication that you may have an obstruction somewhere in the drainage system. Most commonly, there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can become lodged in this area as well causing the drain cycle to fail.
NOTE: A "SUD" error code can often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
These are both very simple repairs that you can perform yourself without the assistance of a repairman.
NOTE: For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and let me know if you have any further questions. I hope you find this information helpful.
Posted on Apr 28, 2010
My washing machine will not lock to wash i have replaced the locking mechanism assembly and the lock lid light just blinks and click near the computer board what els should i try please jelp
How to fix a washing machine door lock in a Hotpoint ...
? 4:21
https://www.youtube.com/watch?v=p14EEa4AYGM
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF In this video, ... How to fix a washing machine door lock in a Hotpoint washing machine ... How to open a washing machine door that won't open normally.
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock the lockand switch assembly might be defective. This is a very ... The Kenmore Elite HE3 is awashing machine by Kenmore. ... Preview my answer. Post my ...
washing machine wont work. the door will not lock to start ...
www.shopyourway.com > Manage My Life > Questions
Manage My Life. washing machine wont work. the door will not lock to start the cycle. all the lights still ... Kenmore HE3T front load washing machine will not start.
How to Fix Washer That Won't Start ' Washing Machine Repair
www.partselect.com/Repair/Washer/Will-Not-Start/
Read on to learn how easy it is to fix the washing machine yourself... ... found on front load washing machine is the door switch and the door lock and strike.
Jan 23, 2016 | Washing Machines
THE DOOR WON'T LOCK THEREFORE THE MACHINE WONT START
Washer Door or Lid Won't Lock - Repair Parts - RepairClinic ...
www.repairclinic.com/...Washing-Machine/...---/Washer-door-or-lid-wo...
Most Frequent Causes for Washer door or lid won't lock. For the most ... Once thewasher door is closed, the washer can begin operating. If the door lock is ...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock thelock and ... The Kenmore Elite HE3 is a washing machine by Kenmore.
Front Load GE washer won't lock / start. ' ShopYourWay
Front Load GE washer won't lock / start. ... Based on your symptom and details it could have a faulty door lock assembly ... GE Washing Machines 3.8 cu. ft.
Washer Won't Spin or Agitate? Washer Door Latch ...
Dec 13, 2015 | Washing Machines
CFEF372BC2 - Oven Door Locked
I would replace it. IF you unplug it and set it to clean it is a hazard if someone opens it. If the safety feature is working it should not self clean with the motor unplugged anyway.
Aug 29, 2014 | Kitchen Ranges
Siemens WM14S392GB - error F61. Help to fix please.
Error E61 means that the door is locked but the sensor is showing as still open.
You may have a faulty door sensor.
May 07, 2012 | Washing Machines
Front load he3 kenmore, control panel had an F now is locked up! Have unplugged for 30 min. no change
I just experienced a similar problem, getting an F21 error and 5d.
F21 error was a clogged drain. Unplug firest, then remove the lower front panel (it may be from the back panel) and look for a drain valve. unscrew and clean out good. I found approx $6 in change, keys, bobby pins, hair clips, etc. then put all back together and run a cycle empty. Save myself $250 I dont have and did it myself. This website is wonderful.
Denise
Dec 17, 2010 | Kenmore Front Load Washer
WHEN I PUSH THE START, NOTHING HAPPENS,NO NOISE AND THE DOOR DOES NOT LOCK. IF I PUSH THE CLEAR BUTTON TWO -- WILL APPEAR AND STAY FOR ABOUT 30 SECONDS AND THEN A BLANK DISPLAY. UNPLUGGED WASHER FOR 5 MIN....
if you had a power failure latly or a power surge it might have knocked the program on the machine.Push and hold the stop/start button for about 10,seconds it should reset if that fails again hold the stop button and another ie rince hold/power save or whatever buttons you have i just cant remember which one there are so many,but try the first option first it should reset.adrian,,,,,,,,
Aug 15, 2010 | Kenmore 44072 Front Load Washer
Front door won't open on 2003 Kenmore Washer and no release
When I had the same issue I tried the following things. It has been so long I do not recall the exact order I did them in or what finally worked but it did open.
Unplugged it for 5 mins.
Turned off everything else in house.
Plugged it back in.
Pushed Drain/spin - start (I could hear it try to click locked)
Then I pushed to stop it (then I hear the door lock click)
I tried all the different wash options and finally one of them allowed me to cancel the wash and the door unlocked. I know I unplugged it at least twice because of the computer needing to be reset. When a tech was working on it a couple of years ago I had him explain a few things and I don't recall the exact # of min's you are supposed to wait so I use 5 min's.
The water was still in my washer and I had to open the bottom and drain it by opening the cleanout to the pump. Large mess on the floor. Make sure you unplug the machine first. It will get on the wiring.
I also learned recently that your house electrical needs to be correct. These machines are extremely picky about their power.
Sep 17, 2009 | Kenmore Elite 45986 Front Load Washer
F21 keeps coming up on the washing machine
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 27, 2009 | Kenmore Elite 45986 Front Load Washer
Lock on the machine
Held in the lock button we found for 3 seconds.
Sep 14, 2008 | GE WSXH208A Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
107 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
