Question about Konica Minolta magicolor 2300DL Laser Printer
Printing t shirt transfers
Can I print t shirt transfers on this printer and if so where can I get the transfer paper?
    Genius:
  • 1,447 Answers
I believe that printer does not support this option since it is using toner and toner printer has different technology where it creates electromagnetic reaction to paper itself and toner when printing . What you need is an inkjet printer. You can check Epson products and consumables and Kodak too.
Hope this helps
Posted on Apr 28, 2010
3 Suggested Answers
enuro12
  • 116 Answers
SOURCE: printer
What printer and software are you using?
Does it do this for anything you print. Example a word document.
Posted on Oct 10, 2007
  • 823 Answers
SOURCE: TRYING TO PRINT ON A
The easiest way to set it on mirror image is by going through the picture or document itself that you are trying to print on the t-shirt.
Open the picture or document you wish to print. Go to the upper left side of your screen and find the word "File" and click on it. Then slide down to "print" and it will open a box that shows your printer chosen to use with an arrow next to it and near that area there is a box that says "preferences". Click on preferences. Depending on the operating system you are using (i.e. windows xp or vista ect.) there should be tabs to click on in this area which take you to different choices for preferences in printing. Click on the tabs until you see your choices for mirror image. It should be near two sided printing and the dark and light choices for your image.
If you are unable to locate it with these instructions, go back to your original question posted on Fixya and use the "comment" or "reply" words in blue to send a clarification message to me. I will help you solve this problem.
Posted on Dec 06, 2010
Can HP Officejet 5740 print mirror image onto transfer paper?
Most printers don't do well with t-shirt transfer check HP web site for spec's on your machine
Oct 21, 2015 | Office Equipment & Supplies
How to select mirror image or reverse image on printer to print t-shirt transfer
When you go to print, select your Lexmark 5200 Series printer, then click (Printing) Properties to open the Lexmark control panel.
Click the third tab on the left, marked Print Layout, then choose the Mirror radio button (see picture).
Click OK to apply the setting.
Note: if your printing program has a setting for t-shirt transfers, it may automatically reverse the image. Use only the setting in the program or in the printer- if you use both, the settings will cancel each other out.
Jul 16, 2011 | Lexmark X5270 All-In-One InkJet Printer
How do I do mirror (or reverse) printing for a t-shirt transfer? Thanks.
If you are printing text only, you can create it using wordart in word and then use rotate or flip command to reverse the text.
If you are printing a JPG with text, the easiest way will be to use photoshop to edit the image and add text if desired, then use the mirror utility, The picture and text get reversed and the transfer is printed in reverse to become "positive" when you iron it on the Tshirt.
hope this helps.
Mar 07, 2011 | Canon PIXMA MX870 Wireless Office...
Printer is printing documents backwards
Go to control panel and printers, in properties for your printer, select printing options or preferences. Turn off
mirror image printing. It is used to print on a transfer sheet to transfer to t-shirts and such.
Dec 30, 2009 | HP Officejet J5780 All-In-One InkJet...
Can the Canon MX310 print on transparencies?
Manual does not mention Transparencies.
Manual states that It will print T-shirt transfers:
T-Shirt Transfers TR-301
This paper is used to create iron-on transfers. The image is printed inverted.
Paper Support Load Limit: 1 sheet
Paper Output Tray Load Limit:
We recommend that you remove the previously printed sheet from the Paper Output Tray before continuously printing to avoid blurs and discoloration.
Paper Thickness Lever: Right
Media Type:
Printer Driver Setting: T-Shirt Transfers
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | Canon PIXMA MX310 All-In-One Printer
Printing dark tshirt transfers - can't override the flipped image
Hello I think I can help you. I Would not use T shirt transfer when you make up your print I would select poster print or any other form that does not automatically reverse the image. The reason your software is designed to do this is on the regular transfer paper your laying the image down on the shirt, so for it to come out right it has to be reversed. With the dark T shirt transfer paper your peeling off the backing and putting the image face up on the T Shirt.
Dec 23, 2008 | Canon i80 InkJet Printer
Iron on transfers lexmark x1290
In your printer driver, select the highest dpi setting and the correct paper setting for your type of printer:
Iron-ons are very waxy and the ink may not adhere if not put on thickly. Bellow are some suggested printer settings. For the best results check your printer manual or with your printer's manufacture. CANON: T-shirt transfers.
EPSON: High quality glossy paper or special coated paper, depending on the model.
HEWLETT-PACKARD: High quality glossy paper.
Lexmark: T-shirt transfers.
IMPORTANT: Then set the paper thickness lever on your printer for standard paper. You want the ink nozzles very close to the page.
Jul 23, 2008 | Lexmark X1290 All-In-One InkJet Printer
Choosing a paper type
Un fortunately it is often a trial and error thing. I would try all "special settings", even cardstock ect.
Mar 17, 2008 | Ricoh Aficio SP C410DN Laser Printer
Printing t-shirts
Unfortunately, you can't print directly on to t-shirts. You have to print onto transfer paper, which you then iron on to the shirts.
Regards,
Javabytes
Nov 18, 2007 | Compaq A3000 All-In-One InkJet Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
235 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
