Question about Zebra Z4M Printer
How can I adjust the label so it will not cut off the information on the left side. Also how can I adjust the label so that it will print correctly from the top. We are using this printer to generate ISBT blood bag labes
  • 4,234 Answers
THe zebra must be set up with the correct label size and teh software that creates the lable must contain the formatting information. The Zebra website contains both the user and programming manuals that completely describe this process. At this stage, the user manual will be the most helpful so you can verify the printer settings. From your description, I would suspect that the label size the printer is expecting is different than the actual label.
Hope this helps,
Dan
Posted on May 04, 2010
    Scholar:
  • 185 Answers
Try to reset the default values, to do this enter the menu. Exit the menu and when it say's Permanent, use the arrow keys to cycle around until it says load defaults and accept that. It will load the defaults and fix the problems you have
Why datamax M class 4208 only prints on one side of the label?
When printing on less than full width media, the printer has a printhead-leveling cam to adjust the right side of the printhead
for even pressure distribution. To adjust the leveling cam:
1. With media loaded in the printer, print a label (press the
FEED + CANCEL buttons simultaneously) and
examine it..
2. While observing the printed labels, loosen the
Thumbscrew and move it to the left most position. (see
Example 1, below).
3. Next, move the Thumbscrew to the right until the
printed labels contain a complete, even image (see
Example 2). Tighten the Thumbscrew.
Apr 30, 2014 | Datamax I-4208 Thermal Label Printer
My labels are printing vertical instead of horizontal
when you click print check your setting you need to make sure the orientation is correct portratit or landscape
Nov 17, 2013 | Dymo ® LabelWriter® 450 Series PC...
My TEC SX4 has decided to do a wrap and my x-axis is offset from 0. how do i correct this problem?
The Wrap is due to the message being too long.
Inrease the width of the label. The 0,0 reference is relative to the paper width. To chage the X axis goto parameter set or adjust set depending on firmware. (X offset)
Nov 13, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
How to adjust horizontal start position of label
is it possible to track the label stock with some guides?? before the printhead sometimes zebras use guides. some zebras also allow you to set a margin in the software or control panel itself.
Jul 11, 2017 | Zebra GX420d Thermal Label Printer
When I print my labels, there are lines that run through it
The lines(voids) are being caused by elements that are worn off the printhead. No energy is getting there to release the ribbon, causing a void area. To see the full extent, just create a label, using your widest label, that prints a thick black line. You will easily see the "void" areas as white lines.
This is common over time due to the constant contact with the ribbon. The elements wear down just like the tires on a car from the constant contact with the road.
The only way to correct is to install a new printhead.
Apr 28, 2010 | Zebra Z4Mplus Label Printer
My 3'' by 1'' label now prints in the middle to the right and cuts of info.
So the left side is blank ? Usually caused by an imbalance across the printhead. Check the toggle pressure on the left side. Each toggle has a dial on top for adjusting the down pressure. Probably less pressure on the left than the right. Quick test would be to use your finger to put some down pressure on the left side of the printhead while printing. If the print is there, you have your answer. If still no printing, then something else is happening.
Hope that helps !
Apr 28, 2010 | Zebra S4M Thermal Label Printer
I want to adjust the printing coz its prinnting on left side my barcode label size is from the right side is having more space
Not too sure what you mean here. If the print on the left side is Ok and faded on the right side, then the position of the printhead pressure toggle may need to be adjusted. Make sure it is positioned over the center of your label.
Hope that helps !
Apr 21, 2010 | Zebra 105Se Thermal Printer
Media problem during printing
If the media is coimng out straight, then look at the cutter mounting.
If the cutter is slightly off angle then it can be corrected on the mounting beneath the right lower side, and the lft upper (head latch) side.
Try printing a barcode or straight line of print on the top and bottom of the label. Look at the print in relation to the cut.
If it is off , it may also be the printhead azimuth.(angle of the head in relation to the platen roller(roller beneath the head).
There is an adjustment fo tthe head to suare it up to the platen.
Jan 27, 2010 | Zebra 105SL Thermal Label Printer
Out of paper error in Zebra 110XiIII plus
There is a small thumb screw under the paper guide that has an adjustable stop to hold the paper. If you load it correctly, you should have one on each side to guide the paper into the printer. Also, the machine has either a roller or a bar to hang the labels on, correct? The bar has an adjustable stop to keep the roll from moving around while you print. You may want to setup the media sensor about 1 cm from the left of the printer to make it less subject to this type of error. They come from the factory very close to the edge of the paper to allow for some card printers to work well out of the box. Most people use labels and this is not necessary. I hope I have given you some helpful information.
May 06, 2009 | Zebra 110Xi III Plus Thermal Printer
Zebra Z4M Printer Logo
252 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
