Question about HP Photosmart C5180 All-In-One InkJet Printer
Ink system failure erorr 0xc18a0306
Tried turning off printer, unplugging, removing cartridges, plugging back in, turning on, replacing cartridges--didn't work. tried unplugging and plugging back in while pressing help and ok--didn't work
  • 7 more comments
  • peachyboy Apr 03, 2008
    followed that advice and no joy - will sometimes print 2 sheets in a row! others bloody error message every time!
  • Anonymous Apr 07, 2008
    I found the following firmware update on the HP website to work for me. Good luck, Lucian
    http://h10025.www1.hp.com/ewfrf/wc/docum...
  • Anonymous Jun 18, 2008
    I am suffering the same ink system failure but do not understand the link to the patch associated to this post. The patch is for the 8200 series and does not appear to work for the C5810. I am out of ideas as the HP solution makes no difference for me. Any ideas please?
    I did all the above things and I cleaned out the pump tubes and lubed up all the moving parts on the pump, I put it back in and it still has the problem. It looks like it doesn't even try to move the pump as it starts up and then gives the error.
  • sarimac182 Jul 06, 2008
    i tried all of that but it still refuses to work.
  • reddogradu Feb 02, 2009
    The Best Solution posted by Mortdecai worked one time for me, but after I printed two pages I got the same error message. Now no way to print again.
  • Anonymous Mar 07, 2009
    Junk Printer, stay away from it. I changed the ink once and had nothing but problems. I contacted HP, the printer was still under warranty, they refused to repair it. I'll never buy another HP product, ever!
  • topdog200 Feb 20, 2010
    Hp Photosmart c5100 with a 0xc18a0306 problem. Tried everything that has been suggested appart from hitting it with a hammer!
  • Anonymous Mar 25, 2014
    when plugged in works perfectly - when i unplug it, it stays on until i turn it off and than does not go on unless i plug back in
Although it did not work for me, HP offered this as a solution. If it does not work, HP indicate you have a hardware fault that can only be fixed by a service engineer repair.
1. Get the unit into the “Support Menu” by following the steps below :
A. - Press and hold the “left arrow” key.
B. - Press the “Setup” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release the “OK” button.
Display should say “Support” and display the FW rev (something like R0616R)
2. Press and release the right arrow button until the display says “System Configuration Menu”.
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
5. Press and release the “OK” button.
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
Posted on Jun 19, 2008
  • Cor_Jac May 02, 2011
    Thanks a million - worked like a charm, clear step-by-step instructions. Have always used HP printers, but this one is a temperamental one.
    Thank you for taking the time to post this here, much appreciated.
  • gespenstx
    gespenstx Aug 02, 2012
    Great. Thank you so much!!
The error is created by heads stuck by end cleaning station or by paper left in printer by the cleaning station( right side of printer= memory sockets side).
SUCCESSFUL REPAIR STEPS:
1-Check printer for paper piece in print head moving path.
2-Oil printer metal bar (guide= support of heads mechanism) with fine oil use for sewing machine( 2-3 drops left side , 2-3 drops right side of heads).
3-Start printer and open the cover.
4-Lock the cover switch DOWN with a pen.
5-During of self test when the heads moving left to right with YOUR HAND BLOCK HEADS IN CENTER FOR 3-5 sec.= CREATE A ERROR WHICH OVERWRITES THE EXISTING ONE (0xc-----) from printer MEMORY.
6- SHUT DOWN ( Turn Off the Power).
7- Wait for 30-60 sec. to discharge the capacitators.
8- Restart the printer and wait for maintenence cycle.
Posted on Sep 15, 2008
  • 346 Answers
ink system failure erorr 0xc18a0306 - s.gif Exact steps are: s.gif
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Posted on Apr 03, 2008
  • 1,218 Answers
Check the following information.......................
http://www.fixya.com/support/t5587774-hp_photosmart_c5180_ink_system_failed
Posted on Sep 03, 2010
    New Friend:
The first time I had this problem, I munged the buttons on top and somehow got the error " Cartridge # has expired, replace this cartridge" (it was the light cyan cartridge, which was the oldest one on my printer that I had never replaced) I replaced it, and the printer works. Not sure if it was the swapping out of the cartridge, or just that the cartridge error overrode the previous one, if if the expired cartridge did indeed cause the ink system failure (I had seen neither error before, I've used hp printers a long time, but have never had extensive duty cycles) In case it helps......
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_37e6922d40372442
Posted on Mar 10, 2010
    New Friend:
Put new cartridge in and it still says change ink cartridge
Posted on Jun 28, 2010
Help me
Posted on Jun 04, 2008
Same problem, only just got the printer. - But the store wouldnt take it back off my hands.
It did it all the time, got rather fed up in the end and pushed it off the end of the desk.
Worked rite as rain ever since.
Posted on Jun 01, 2008
2 Suggested Answers
SOURCE:
  • 234 Answers
SOURCE: ink system failure erorr 0xc18a0306
It is a the flow of the ink into the printer which fails, and these error cannot be reset most of the times when you turn of the unit and oon back again if it works then it is good again, if not it is better to replace the All-In-One, If the printer is in warranty or extended warranty you will get a free replacement from HP, if not you can get a upgrade option wher you may get some discount from HP Tech support Call 1800 474 6836
Posted on Aug 29, 2008
How do I resolve ink system failure 0xc18a0306?
When powered up press the ink button. This should cause the print head to move to the middle the printer and then back. If it parks properly then everything should be fine. However, if it stops against an ink cartridge it's indicating a problem (no ink/ faulty cartridge). So replace it and repeat the process x3 (ie.for the 3 other cartridges). Once complete the printer should be OK. All this should be covered in the HP user manual.
HP Official Site Laptop Computers Desktops Printers Servers Services and...
Aug 08, 2015 | HP Photosmart C8180 All-in-One InkJet...
Ink system failure error code: 0xc18a0306 what is the problem and the cure
Ink system failures can be caused by a number of things. It could be a temporary error, a bad or dirty print head, or a system failure.
For pictures see: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=en&cc=us&product=1156652#N998 . Expand the section "any other error code" if you need to.
First try resetting the printer. With the printer on, unplug the power cord from the printer then remove the other plug from the wall outlet. Wait at least 15 seconds. (I also pull the data cable from both the printer and the computer when using a USB cable - some power is provided through this cable.) Then plug the power cord into the wall outlet and then back into the computer. Turn the printer back on if needed. Check if the code is still present.
Next try cleaning the print head. With the power on, open the cartridge access door. Wait until the cartridge carrier stops moving. Remove all of the ink cartridges by pressing on the front tab and lifting them up. Then lift the grey handle and pull the print head straight up.
With bottled or distilled water and lint free clothes (coffee filters will work). Dampen a cloth and wipe the electrical contacts working form bottom to top. Do not touch the ink nozzles. Continue until there is no ink left on the contacts. With another damp cloth, wipe the edge between the nozzles and the electrical contacts working form left to right. (Keep your fingers away from the contacts.) With another damp cloth, wipe the ramps working away from the nozzles. Again continue wiping each area (using extra damp cloths until there is no ink left). Then dry each of these areas with a dry cloth. Take another damp cloth, and wipe the contacts inside the printer. Work from top to bottom on these contacts. Dry the area. Replace the print head, lower the gray lever, and reinstall the ink cartridges. Close the cartridge access door.
If the error persists, try resetting the printer by unplugging it while turned on again.
If the error still persists, either you need a new print head or the unit needs service. If you get a new print head, you will not be able to return it if that doesn't solve the problem.
I hope this helps.
Mar 22, 2011 | HP Photosmart D7160 InkJet Printer
What does this error mean 0xc18a0306 on my printer
Press the On button to turn the printer off. Unplug the power cord from the back of the printer. Remove all the ink cartridges.
Wait two minutes. Plug the power cord into the back of the printer. Press the On button to turn the printer on. Install the ink cartridges when prompted.
Sep 23, 2010 | Office Equipment & Supplies
Hp3210 ink system failure
Turn off the machine, unplug the power cord from the back of the machine, remove ink cartridges, wait 2 min, plug power cord back in, press on button, wait until the printer prompts you to replace the missing ink cartridges, then replace the ink cartridges. If this doesn't clear the error you may need to re-prime ink through the lines. There are instructions for doing this at www.ccl-la.com/blog/. Search for HP Photosmart and run through the "ink system failure" #1 instructions.
Mar 07, 2010 | HP Photosmart 3210 Printer
HP c6150 all in one error message Oxc19acff Ink System Failure. Replaced Yellow ink cartridge an still receive error.
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the power button to turn on the machine, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime ink through the system. There are instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jan 30, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, turn the machine on using the power button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error you may need to re-prime ink through the system. There are instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jan 16, 2010 | HP Photosmart 3210 All-In-One InkJet...
Ink system failure. How do I reset a hp 8250 printer?
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the power button to turn on the printer, wait for the printer to prompt that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error you may need to re-prime the ink cartridges. There is a good explanation of how to do this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Nov 15, 2009 | HP - HP Photosmart 8250 printer
I have a HP C5180 All in one and after replacing a cartridge it gives a INK SYSTEM FAILURE message. Error 0xc18a0306 on printer screen. I did all the disconnecting plugs , removing cartridges, waiting,...
follow the steps provided below
  1. Turn off the product by pressing the On button.
  2. Unplug the power cord from the back of the product.
  3. Plug the power cord back into the product.
    1. Turn on the product by pressing the On button.
    NOTE: Sometimes Ink System Failures cause a carriage stall when the power to the printer is cycled. If the Ink System Failure requires the product to be returned, there is no need to resolve carriage stall issues with the product.
  • If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Aug 20, 2009 | Office Equipment & Supplies
    C5180 Ink System Failure CodeOxc18a0206
    Here is what you can try:
    1. Turn off the power and unplug it from power source.
    2. Open the right side of the printer (looking at the front).
    3. Disconnect, by pulling gently, both white flat ribbon cables off the main circuit board.
    4. Plug in the power source and turn the printer on. Wait till you get a error message and push "OK".
    5. Unplug the power source.
    6. Reconnect the flat ribbon cables by aligning and carefully pushing them into the conectors on the main circuit board.
    7. Plug in the power source and turn the printer on (Printer preparing occurred).
    8. The 0xc18a0306 error should now be gone.
    Feb 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
    Aug 29, 2008 | HP Photosmart 3310 Printer
    HP Photosmart C5180 All-In-One InkJet Printer Logo
    14,543 people viewed this question
    Clive
    Clive
    Ekse
    Thomas F. Schneider
