Question about Garden
I have an old Jacobson riding mower Chief 1200. The mower drive belt flew off and caught in the wiring harness running from the ''dash'' to the starter and spark plug/etc. Everything is in tack except a white wire with a connector tab. It comes from the round unit prior to the spark plug.(distributor?) There is a red, black and white wire connected there. The red is on a single terminal, and the white and black are on the same terminal. The end of the white running back toward the ''dash'' is the one in question. The motor turns over, but will not spark. Current comes through the white wire only when turning engine over. Please help.
SOURCE: Black and decker mower switch wiring
I have a Black and Decker Electric mower #M2370, which I would like to use this year before moving to a condo. Last year, the mower was stopping and starting depending on how the lever was positioned. I suspected the wiring so I removed the on-off switch lever. The wiring appears intact. Part of plastic inside the lever maybe broken. Can i use the mower without the lever by just pushing the black button?
Posted on Mar 31, 2010
  • 143 Answers
SOURCE: Wiring compressor
The two terminal cap is only for the new fan motor. Connect the compressor wire back where you found it, on the 3 terminal cap. It's the terminal marked, "herm". The "common" terminal on the 3 terminal cap must still be connected to one side of the 220 power at the contactor. One side of the 220 goes to the common on the compressor. The other side of the 220 goes to the run winding on the compressor AND the common terminal on the 3 terminal capacitor.
Posted on Jul 22, 2008
  • 71 Answers
SOURCE: Help - I am trying to install a honeywell RLV4300A
You will have to have schematics from the old wiring diagram. Then you will have to confirm its consistency with actual old wiring before you can be sure that the wires run to the proper places on the old heater and a/c system. This sounds like a gas furnace and is simpler than a heatpump. Once you know what distinguishes the wires with the same color, you should label them and then you may call them a different color if they were wired with wrong wire colors. You may be in luck if you go to the furnace control box an look at the terminals.. They are usually labeled with a R for Red and W for white and Bl for Blue and B or Black. If you have other colors on these then it sounds that it was wired with wire spare wire by someone who knew what they were doing but neglected to leave a path for someone else follow.
You may be able to use a continuity tester of circuit tester to id these wires that are in question...
ie, once indintified, you can match with the requirements of the new stat.
Posted on Jan 13, 2009
  • 588 Answers
SOURCE: connecting a motor starting capacitor
New Capacitor
herm start on the compressor
fan start on fan motor
c run or power to both compressor and fan
Posted on Apr 25, 2009
  • 588 Answers
SOURCE: I am replacing the a/c
Motor Wiring
Old Motor
Brown wire is Start
Yellow wire is run or Power
Black wire is High Speed or Common
The other two taps are speed taps, but you have a single speed application
And high speed is what you need ,that’s why there’s not any wires
on Red and Blue if high speed was to much then you would move the
Black wire to one of the other taps RED low speed or Blue Medinm speed
New Motor
White goes to the Yellow wire from the capacitor
Black goes to the Black wire you took off of high speed on old motor
Of course both Brown wires go to the capacitor and Green to ground
If a capacitor doesn’t discharge it doesn’t mean it’s bad
but the capacitors don’t last as long as they used.
Any time you put in a new motor always replace the capacitor
It will save you a lot of time and grief later on.
Posted on Apr 28, 2009
I got a a craftsman DLT 2000 riding mower 48in
look it up on sears.com to get the part number & size
Sep 24, 2014 | Garden
John deere d110
You would need to remove the mower deck so you can gain access to underside of the frame so can check the drive belt path.
Jul 31, 2014 | John Deere Garden
Only starts if mower lever engaged (without drive belt)
Sounds very strange but i would guess either a micro switch or one of the relays behind the dash.
Dec 16, 2017 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Wiring harness
look underneath did drive belt snap in two , rear has white plastic fan on top of it that should be rotating with engine running if not yep you broke a belt , don't know about wire could it be from front PTO they are electric so it will need a wire ,one possibility is that drive belt broke slapped front PTO and broke off wire , that musta been some snow your pushin ooh and a reminder never push a hydrostatic drive tractor without pump turning it will dammage it
Feb 08, 2014 | John Deere Starter Tractor Lx188 Kawasaki...
Broken spindle pulley. changed belt and pulley. Belt continues to smoke. What do I check next?
make sure you routed the belt the right way then make sure the other pulleys are moving freely
Aug 27, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Lawn chief mower throws belt
does the belt feel tight when its on? i would look for belt alignment warn blade mandrels or rotted out deck and the belt tension pulls them apart
Apr 07, 2012 | Garden
Lawn chief riding mower drive belt will not stay on.
Hello
From your Description it Sounds like there is a Bent Pulley of Bent/Missing Belt Guard.
Check All the Pulleys and Make Sure they are Not Bent and that the Pulley Guards are in Palce and Set to 1/4 Inch from the Belt.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 07, 2009 | Garden
Garden Logo
394 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
