Question about Asko W6441 Front Load Washer
Won't drain, f1 flashes - Asko W6441 Front Load Washer
    President:
  • 1,554 Answers
Make sure the drain hose is not kinked or clogged. Remove the needle trap door to access the needle trap and unscrew it from the pump assembly. Clean the needle trap including the pump housing to make sure no debris is blocking the water from being pumped out. Set the washer to drain and check the pump motor if it is running or not. Inspect also the pump impeller; replace the pump assembly if the pump motor is not running or if the impeller is broken.
Posted on Apr 28, 2010
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
Our fisher and paykel dishdrawer won't wash. It comes up with F1 and flashing light on control panel.
the dynamo dishwashing stuff has caused foaming which reached the base of the dishdrawer unit causing the flood switch to trip. This gives F1 error.
Not sure how much foaming has occured.
Best to turn off power and take power cable out from socket. then empty the drawer using towels. pull out the bottom drawer and wait a day or so to let the foam disappear from the bottom of dishwasher (under the bottom drawer). Connect the power and see if F1 had gone. If not, you need more work. Post a comment based on the above suggestion and I will guide you further if required. Always use Finish dishwasher power only (recommended quantity) as the drawers are small and don't need much detergent.
Dec 27, 2012 | Fisher Paykel Dishwashers
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
F1 flashing on both doors on my Fisher&Paykel dishwasher. Just turned on by themselves.. was not running either top or bottom at the time.
F1 - on dish drawers means there is a H2O leak on the machine which has activated the flood sensors.. Causes
Lid not closing.
??¢ Overfilling.
??¢ Foaming.
??¢ Not draining.
??¢ Lid seal damaged.
??¢ Dispenser or water softener or their seals leaking.
??¢ Damaged water inlet or drain hoses.
??¢ Leaking heater plate or motor seals, or drain o-ring seals.
??¢ Yoke jammed or broken.
??¢ Inlet hose to inlet valve connection loose.
??¢ Inlet valve body leak.
??¢ Heater plate damage (chipped enamel).
??¢ Dry F1 - PCB mains filter, harness or connectors, electronic controller
May 09, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
Kenmore elite flashes f1 code and stops
If I remember correctly? It is stopping after the wash cycle and won't spin? If this is correct you need a new pump. I found out that front load washers have a filter that is behind that front cover and it needs to be cleaned every 6 months or more often if you have lots of strange items that show up in the wash like coins or toys or if you have lots of furry pets. Mine did that with out the code and I replaced the pump and check the drain every 6 months or so. I was told a good indicator that the drain filter is getting clogged is when your washer has an odor. Just a rule of thumb.
Jun 15, 2009 | Kenmore Elite 45986 Front Load Washer
Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 01, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel dishwasher
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin.
If a flood condition is detected, both draws will activate the drain motors and flash F1.
Remove the bottom drawer by pulling the lock pins on each lower side corner. Slide down and remove front cover. Release the drawer slide clips and remove drawer then dry the catch basin.
There are three possible scenarios for this error code;
1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
Jul 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel dd-603ss
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin. If a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
There are three possible scenarios; 1. Defective lid motor(s)...Each drawer has two lid motors that pull the lid tight to the drawer when the cycle is started. (this was very common on early models) 2. Something too tall was placed in the drawer preventing the lid from closing completely. OR 3. (only seen this once) the drain hose developed a crack causing water to leak only when draining. Hope this helps....
Jun 06, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Asko W6441 Front Load Washer Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
