Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Chronotherm III displays 32 deg for room temp, which is really around 70 deg. No action called for by the instrument. Batteries had died and replaced. My first guess was the actual temp sensor was actually bad. If the sensor is located in the base, perhaps some of the contacts were 'making'. 32 deg is displayed whether or not the removable part is on the base or not.
    Guru:
  • Honeywell Master
  • 588 Answers
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on May 12, 2010
My chronotherm III repeated flashes replace batteries after I've replaced them
Did you make sure the batteries are brand new? Batteries that has been sitting around and then used may not be powerful enough. They lose power over time. Get fresh batteries and try again and make sure that you have put the batteries in the right direction as listed in or around the battery holders. Good Luck! (note: it just might be possible that if you put the batteries in the wrong way, it messes it up. But this is rare to happen.) Check your manual if you have it.
Aug 30, 2014 | Heating & Cooling
Honeywell chronotherm iii died
did you check for correct positioning of new batteries ? also when but back on base is it securely attached?
Nov 19, 2013 | Heating & Cooling
I have some problem with our machine scotsman mv450 is to long product ice very slowly
Min freeze time 6 minutes and max freeze time 45 minutes. the 6 minutes is with perfect conditions. Example: Cycle time water temp was 50 degrees coming in to the water sump tray from water supply and the Ambient air temp surrounding the machine was a constant 70 deg than the machine should make ice every 10 - 12 minutes.now we know that the water temp from the water source is not going to be 50 deg and room temp will not be 70 deg all the time so the warmer water temp and ambient air temp is the longer it takes to make ice. one thing you wont to check is the water inlet valve to make sure it is not letting water seep through causing water temp not to cool down from running across evap plates. make sure the condenser coil is clean this will slow down production of ice.
Apr 17, 2013 | Kitchen Appliances - Others
My honeywell chronotherm III says -AC any ideas
The problem is your 24v power source. I am unsure as to why you put "other than power source or batteries". If you did indeed check that your thermostat is receiving 24v, then I would say that you have a bad thermostat. Hope this helps
Jan 22, 2010 | Heating & Cooling
I have a Honeywell Chronotherm III Thermostat and in instead of showing the temparature in the display it shows -AC. I've replaced the batteries, and tryied adjusting Temp up and down for cooling and...
It would appear to me that you have lost the 24 volt power supply to the thermostat. In referencing the manuals for this thermostat, available @ www.honeywell.com, I've found that when the thermostat is not connected to the wall plate (plate mounted on the wall, that the thermostat either snaps or screws into), it will display the -AC. This being said, either the thermostat is loose on the wall currently, or your 24 volt transformer has died. Hope this helps.
Dec 23, 2009 | Honeywell Power Humidifier: Furnace...
Display and buttons not working
replace t-stat if there is power to inside unit
Oct 22, 2009 | Honeywell Electronic Programmable...
-AC appears in the display of chronotherm III
I have had the same problem- twice. It was a similar but different problem each time. The -AC means the ac control voltage isnt making it to the thermostat. In my case both times it was a switch in the control circuit that wasn't closing properly. The easiest was the front cover switch. If the front cover is removed from the furnace or has vibrated loose, the switch will open, preventing the furnace from running. The other instance I ran into was a flow switch on the exhaust blower which ensures the there is flow OUT the chimney. The switch wasn't functioning, so the furnace wouldn't start. The blower would come on for a short time, but the burners wouldn't light.
Hope this helps,
Dec 12, 2008 | Honeywell Programmable Thermostat Heater
Try this link:
http://yourhome.honeywell.com/yourhome/Applications/TechLit/TechLitSearchResults.aspx
It looks like there are a variety of model numbers for the Chronotherm III. Hopefully you can locate your model number.
Dec 17, 2007 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
282 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
